How many miles on WMO? - Page 2 - Diesel Forum - TheDieselStop.com
Old 08-12-2008, 09:10 AM   #16 (permalink)
I have been running it for about 7500 miles. I have had no problems but like they said filter it to 2 microns.
Morning Wood is offline
Old 08-13-2008, 09:39 AM   #17 (permalink)
gamudslinger88's Avatar
They say atf burns hotter than wmo but I never noticed a difference, then agin I usualy run a wmo, hydrolic fluid, atf ****tail. My truck runs the best on #2/wmo at 50/50 with a little 2 stroke motor oil.
2001 F250 4x4 long bed extra cab 6 speed hand shaker . DIY Tymar, 4" turbo back straight pipe w/ 5" stainless tip, DP tuner F5 w/ stock, high idle 1200 rpms, 60hp tow, 80hp econo and 120hp performance. Auto meter Boost and EGT gauges on an A pillar pod. 203* thermostate. BRV+, CCV mod run to the back between fuel tank and skid plate. 2.5" leveling kit and running 315/75/16 Hankook MT. Cobra CB with dual 3' whips. 12000 miles + on WMO and ZERO problems.
Huge make over on the way.
6.5 Procomp lift, 20" Motos wraped with 37x12.5 Procomp Rubber.
Soon to follow. Ranch hand bumpers, GT38R turbo, High performance HPOP, Head studs, 6" miter cut stacks.
gamudslinger88 is offline
Old 08-18-2008, 08:23 AM   #18 (permalink)
JohnnyReb's Avatar
I'm up to 1800 miles on a 50/50 blend. I only commute 30 miles a day.
1981 MB 240D
JohnnyReb is offline
Old 08-24-2008, 08:29 AM   #19 (permalink)
recon26's Avatar
Filtered WMO
So I guess I am supposed to filter it to 2 Microns, that's what everyone keeps saying. And I will have no other issues on a stock or even a modified engine running this up to 100%. I want to save money, I don't get paid enough to drive....
Recon26
SOLD:2003 XL 7.3L 2WD RCLB
SOLD:2009 GMC Sierra Z71 ECSB 5.3L
2006 XLT FX4 4WD ECSB
recon26 is online now
Old 08-24-2008, 09:51 AM   #20 (permalink)
mankypro's Avatar
Methinks it's extreme folly to think that a new-ish DI brainiac diesel will run 100% WMO without any issues. I would proceed with caution were I you. The tolerances in these newer engines are much tighter than in old IDI's. I'd be very concerned about it.
It's like comparing an ak to an ar.
I run high concentrations of waste oil, but seeing as one of you injectors probably costs much more than what I paid for my truck. Well...YMMW.
Good luck, and proceed slowly, you could be in for a few surprises.
mankypro is offline
Old 08-24-2008, 12:13 PM   #21 (permalink)
arthurgoboom's Avatar
So far I have about 250 miles on 50-66% WMO in my 6.9 IDI, seems to run better than on #2 diesel. I do have the heavy gagging smoke at startup/idle.
I had one scary moment where I was accelerating from a stop and all of a sudden the engine seemed to be struggling, and my EGT was up about 200 degrees from the maximum I usually see, but after easing off throttle for 10-15 seconds the EGT dropped back to normal and the usual level of power seemed to return. Has anyone else experienced anything like this? Maybe the blend is settling in the fuel tank?
Where are you guys finding 2 micron water filters? At Menards and TSC where I have purchased filters, they lowest they have is a 5 micron.
1986 F250 2WD Super Cab XLT Lariat w/ 1996 front clip. Dually bed & van rearend (2" wider, allows spring clearance). 6.9 w/ approx 120,000mi. Banks non-wastegated turbo system, Wellman G088 glowplugs, Delphi BB injectors, Kenworth pyrometer, vac/boost gauge, electric water temp/oil psi/voltmeter mounted in dash. 3" Mandrel-bent open exhaust. C6 trans, 3.54 gears. Okiegringo idler pulley. R134a A/C conversion. WMO/diesel blend in one tank.
arthurgoboom is offline
Old 08-24-2008, 01:23 PM   #22 (permalink)
mankypro's Avatar
There's an ebay seller that sells 50-1 micron blown poly filters for a buck a piece - you need to buy in quantities of 25 though.
completefiltrationservices I believe the handle is...
mankypro is offline
Old 08-24-2008, 08:04 PM   #23 (permalink)
firemediceric's Avatar
I use the GE whole house water filters that I purchased at Home Depot. GE has a carbon 1-2 micron nominal rated carbon filter that I use in the second housing.
1999 7.3 F-350 and 2004 6.0 Excursion
Truck: Tymar type intake, Zoo Dad, muffler delete, By-pass coolant filter, Dahl 100 fuel filter Harpoon & Hutch mod, upgrade to 3/8" fuel line and HP oil X-over, Oil by-pass, Scan gauge II.
Excursion: All stock, so far.
firemediceric is offline
Old 08-25-2008, 04:21 AM   #24 (permalink)
recon26's Avatar
Mmmm.....
Well, I think I will give it a shot once I get home from my "business trip."
Old 08-25-2008, 08:30 AM   #25 (permalink)
LunaTech's Avatar
Check out this thread for some good info. On the first page I have some pics of my filter set up and a link to summit racing for a 2 micron fuel filter/water separator. Working great so far. Here is the link.
WMO Info
Hope this helps out. I've got a little over 6k miles on a 75% WMO blend with no problems. BTW Recon26, read my last post in the above thread to answer a few other question you might have. Actually read the entire post. Some really good info there.
1994 F350 IDI with factory Turbo, crew cab long bed with dual tanks
LunaTech is offline
Old 08-25-2008, 08:57 AM   #26 (permalink)
recon26's Avatar
LunaTech, I actually subscribed to that one after I had read this one. I am looking at all this very seriously because I like Trucks, and even if I was forced to buy a car, it would be a diesel if at all possible. I want all the info that anyone has about cheap supplies of the WMO/ATF/etc. and all the tricks out there so I can figure out what works on my set up. Now I just need to hook up with Jody for some tunes.....
Old 09-23-2008, 11:09 PM   #27 (permalink)
Guys, I have a little bad news. I have been using the 5-micron rope-wound filters for my final filtering stage, and I went on a trip a few weeks ago that needed more than my tank's fuel supply, so I filled a couple 5 gallon fuel cans with my 66% mix as well. No worries, the trip was fine and the truck ran completely normal. The only thing that bugs me is that I noticed about a week after I got back, when I was going to refill the fuel cans for another long trip, that there was some black sediment in the bottom of the fuel cans. I'm not sure if the rope-wound filters are letting some particles through, or if the sediment I was seeing was all less than 5 micron, but the filter isn't catching everything.
I think we all need to get those 2 micron filters if we don't already have them.
Old 09-24-2008, 07:08 AM   #28 (permalink)
LunaTech's Avatar
Yea, I agree. I start my filter setup at 5 micron and end at 2 micron. Check the link in my earlier post (about 3 up) for the link to the WMO info thread. The setup I have is working great for me so far. No problems and over 8000 miles (and counting) on a 75% WMO 25% diesel blend.
LunaTech is offline
Old 09-25-2008, 01:59 PM   #29 (permalink)
soupdog's Avatar
its all i use,,bout 50/50 sometimes 75% went straight 100 % one toime to pick up some cows cuz I didn't have any fuel and all I had was oil that i'd filtered and I didn't want to run out,
Don't know how many miles i've accumulated but its some. I use sock filters from veggie dot com and they are to one micron, Jus wanna say it runs just dandy on anything I put in it and I only have one tank so I have to start on it, it is a lil slower startin but starts even in winter at 50/50 but with a lil heat from the block heater, even use it in my 856 50/50, that ole varmint likes it better than my ole idi, but like i said on my other post, these old idi's are a different breed from these newer ones and can take it where these new ones with their fancy injectors can't. so beware
oh even ran aromatic lamp oil,
she sure smelled good idlin
91 f250 4x4,, e rated tires,,cab lights,,,straitpiped to rear,,,,brand spankin new cd player,,,flatbed with gooseneck,,,one hellava bale hauler,,,
International 856 wide front and a super h wide front ,, both have three points for haulin those bales.
63 w200 power wagon 17.5 inch e rated tires,,4 spd, 410's plus a six popper, she's a lil slow but she'll go anywhere yu point her
New to fleet 95 dodge 3500 EXT CAB 4x4 5 spd cummins power, 4 inch exhaust,
also new 88 f350 4x4 non turbo 5pd straitpiped long bed 410's
soupdog is offline
Old 09-25-2008, 02:47 PM   #30 (permalink)
stevedunham's Avatar
My Photos: (6)
I must've been living under a rock for the last few months I guess... What's "WMO" and people are actually mixing used Trans Fluid in with their Diesel now...?
** SMD '04 F250 SD King Ranch delivered 8/19/04 **
28% Tint, Leer 100XL Cap, DR Edge 8.5" hybrid lift w/ 5" rear leafs, 37x13.5x17 Swamper M16's, Draw-Tite portable winch mount, WARN xD9000i, WARN Pocket Flares w/ Durabak, MBRP Duals, 4.56's w/ F&R ARB's, original motor blown @ 31,000..! Dynatrac Dana 60 35 spline stubs kit, PIAA 520 ATPs, Xenon HID's, Powerslot Cryos/Hawk LTS, SCT X3, blown Turbo replaced with II 60FORDHY, 58V FICM PICS
stevedunham is offline
