Go Back   Diesel Forum - The Diesel Stop.com > Other Topics > Bio-Diesel and Alternative Fuels
Old 09-25-2008, 05:24 PM   #31 (permalink)
arthurgoboom's Avatar
This isn't really relevant but I thought it was funny. Today I was driving around uptown and one of the big local towing companies' 2.5 ton rollback was in the oncoming lane, taking off from a red light. Just as I went by a cloud of blue smoke came out from under it and wafted in my window, with the same exact smell of my WMO/diesel blend.
1986 F250 2WD Super Cab XLT Lariat w/ 1996 front clip. Dually bed & van rearend (2" wider, allows spring clearance). 6.9 w/ approx 120,000mi. Banks non-wastegated turbo system, Wellman G088 glowplugs, Delphi BB injectors, Kenworth pyrometer, vac/boost gauge, electric water temp/oil psi/voltmeter mounted in dash. 3" Mandrel-bent open exhaust. C6 trans, 3.54 gears. Okiegringo idler pulley. R134a A/C conversion. WMO/diesel blend in one tank.
arthurgoboom is offline
Old 09-26-2008, 07:03 AM   #32 (permalink)
gamudslinger88's Avatar
Yes sir, Waste Motor Oil (WMO) and auto trannie fluid along with other petrolium products will run in a diesel engine. You have the 6.0 and I have heard mixed results with it due to the weak fuel system. I have been running WMO and Diesel mix at 50%/50% and even up to 75%/25% with NO problems. The best my truck runs is on 50/50 with #2 diesel, when I run ULSD by itself I can tell a difference in how my truck runs, louder and dont pull as strong. Do a search on WMO and you will come across some interesting stuff.
2001 F250 4x4 long bed extra cab 6 speed hand shaker . DIY Tymar, 4" turbo back straight pipe w/ 5" stainless tip, DP tuner F5 w/ stock, high idle 1200 rpms, 60hp tow, 80hp econo and 120hp performance. Auto meter Boost and EGT gauges on an A pillar pod. 203* thermostate. BRV+, CCV mod run to the back between fuel tank and skid plate. 2.5" leveling kit and running 315/75/16 Hankook MT. Cobra CB with dual 3' whips. 12000 miles + on WMO and ZERO problems.
Huge make over on the way.
6.5 Procomp lift, 20" Motos wraped with 37x12.5 Procomp Rubber.
Soon to follow. Ranch hand bumpers, GT38R turbo, High performance HPOP, Head studs, 6" miter cut stacks.
gamudslinger88 is offline
Old 09-26-2008, 08:28 AM   #33 (permalink)
What are all these acronyms for? WMO and WATF????
And when you burn this stuff what comes out the tailpipe?
Racer-X is offline
Old 09-26-2008, 09:18 AM   #34 (permalink)
LunaTech's Avatar
WMO= Waste Motor Oil
WATF= Waste Automatic Transmission Fluid
As for when you burn it, exhaust comes out the tailpipe (sorry, I couldn't help myself). Seriously, nothing out of the ordinary. If you get your WMO blend really high, you might see a little more smoke. ATF is one of the best injector cleaners for a diesel engine you can use. My IDI runs great on both.
1994 F350 IDI with factory Turbo, crew cab long bed with dual tanks
LunaTech is offline
Old 09-26-2008, 09:33 AM   #35 (permalink)
Time to do some more research on this. My brother works on transmissions for a living!!! I think I could get all the WATF I need.
Y2K F250 CC 4X4, NVK5, Line-X, ICI Stainless wheel to wheel nerf bars , Delta Chip 78/95, AFE Mangum , 4" turbo back exhaust, Vent Visors, Amsoil bypass filter, Amsoil everywhere in the drivetrain, Lund bug shield, ICI stepshields, SportMasters bed cover ,and Eclipse 650W stereo, Billet pedals...more mods to come.
Stump is offline
Old 09-27-2008, 12:52 PM   #36 (permalink)
I guess my question was whether this stuff is harmful, as in carcinogenic. I wouldn't be driving a big diesel if I was a tree hugger - but at the same time I would rather not be afraid to breathe in my own exhaust fumes!
Racer-X is offline
Old 10-03-2008, 07:47 AM   #37 (permalink)
You dont want to be breathing ANY exhaust fumes, diesel or gas. Gasoline is not the gasoline of yesteryear. Most if not all combusted petroleum sources produce carcinogens(cancer causing stuff), so nooooo snifffing the tailpipe
1993 Crewcab 4x4 coverted extendcab,7ft bed , upgraded rebuilt E4OD w/ shift, new shocks, 3.55, Eagle aluminum wheels,1996 bumper, front buckets, ATS turbo w/ 4inch custom exhaust in process,60 gal aux tank for alt-- err extra fuel
1984 300SD single tank mix doing great
1998 Mountaineer FOR SALE
1994 Bronco w/ 1995 Lightning motor..wa hooo
jski55 is offline
Old 10-03-2008, 08:28 AM   #38 (permalink)
georgia diesel's Avatar
I have a 03 powerstroke with 104,000 miles. We have been running WMO for about 50,000 of those.No problem.I run about 70% oil to 30% diesel.Our d-max has ran it since the day it was brought home It has about 35,000 miles,It is running a extremely built motor.No problems there either
03 f-250 6.0 custom tunes sct
2 trips to the dealer ship to fix the same problem
got tired of wasted trips
fixed it my self ARP headstuds, EGR blockoff plate and guess what (no more problem !!!)
all work done by me
georgia diesel is offline
Old 10-03-2008, 09:56 AM   #39 (permalink)
x2 on the no-sniffing-the-exhaust. It probably is very bad for the environment. *shrug*
Old 10-07-2008, 08:53 AM   #40 (permalink)
I have made up a centrifuge filter that takes the fluid down to 1 micron.Used the bowl advertised on this site.
I have put a water/diesel mix through it and complete seperation.
WVO results in a creamy sludge being seperated along with soot etc. Who would want to eat chips etc!
WMO results in a fine black sludge but the oil is still black. Microns below 1?
The advantage is no filter purchases or blocking.
So far the brews have been used in a small 4 cylinder work truck. Still not commited to the expensive 7.3 but it is not too far off.
2000 F350 king cab 4x4,No engine mods,Roo Bar,Headlight and bonnet stone protectors,Inlet snorkel,flares on front,Engine driven air compressor and receiver,Hot water tap,tyre temp and pressure monitor,95 ltr fuel tank under right hand side,aluninium side steps,flat trayback,50ltr water tank under left hand side,heavy wired front and back for 4500lb electric winch, Bilnstien shocks,converted to right hand drive,battery conditioner,electric trailer brakes,heavy duty tow bar,synthetic oil in tranny,extra tranny coolerand filter ,tranny temp & pyro,
Ride-Rite airbags all round.Full flow muffler outlet at rear of vehicle.Engine breather mod.HHO generator
knapp is offline
Old 10-27-2008, 03:43 PM   #41 (permalink)
So far I've got 600 miles on mostly WATF with some WMO mixed at 80% oil 20% #2.
it ran great, I drove it for a week and a half myself to make sure it was doing alright. And today was the first day of my wife driving it and dropping my off at work and picking me up. With only using 20% diesel my MPG for purchased fuel is 70 MPPG (miles per purchased gallon)!!!!!!
I'm fillitering though a wix 16 micron fuel/water seperator and then a wix 2 micron fuel filter twice. Once into my mixing tank and then again as it goes from mixing tank to truck.
Starts good even in cold (~35 - 45 degrees) weather. Will plug it in tonight as it is supposed to drop down below freezing.
Thanks,
Justin
'96 F250 HD Crew Cab Short Bus, built E40d, 4.10 ls 305s on stock Alcoas IDM mod
DixieJeeper is offline
Old 10-30-2008, 12:15 AM   #42 (permalink)
any other people on here have newer trucks? I have an 04 psd with 6.0, I have used 100% wvo for a few tanks, then heard of the wmo that you are all running, I just brought home my first 55 gls from work, but after reading this thread I wonder about the newer DI motors. I am only planning on running at most a 50/50 mix probably more like 60/40 so who has run this stuff in di motors and how has it been.
jimyz250 is offline
Old 10-30-2008, 08:44 AM   #43 (permalink)
If your only asking about DI (direct injection) motors it works great as all 7.3l powerstrokes are DI. But I amsuming your asking about 6.0 motors and what not. There are a few in this thread that are running wmo in a 6.0, some say that it is not recomended because of lower injection preasures, but I really don't know. I do have a buddy running 100% waste compressor oil through his duramax. While it does run, his is hard to start cold and sluggish till it warms up. However my 75% waste oil 25% diesel mix starts great and doesn't seem to suffer even when cold.
So I've got just over 800 miles now. I am on my second 55 gallon drum of oil and my first 55 gallon drum netted me 76 MPPG (miles per perchased gallon)!
Justin
Old 10-30-2008, 05:29 PM   #44 (permalink)
thanks justin, all the info I can get is appreaciated. jsut have to sort through it and hope you accept the right info, these forums have so many diferent ideas and ways, it is hard to see the truth sometimes..
jimyz250 is offline
Old 10-31-2008, 09:15 AM   #45 (permalink)
I've been reading on here and other sites for months now about running WMO. I started out wanting to run WVO, but after reading about how hard it was getting to find as well as all the steps it takes to properly filter it, then heat it to run in the trucks, WMO just made more since to me.
I have made no modifications to my truck. I can filter and mix an entire 55 gallon drum in just over an hour (if its warmer, about two hours it its cold cause the oil is so thick). I've got about $300 in pump, filters, and plumbing. By the time I bought heaters for both the filtering and for the truck and all the extra plumbing for the washing of the oil etc.... I would have nearly been double the investment not to mention the extra time it takes. I just wish I had done this years ago.
Justin
