how to prime cummins diesel - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 05-05-2008, 09:17 PM Thread Starter
I have a mercedes 300td that has a primer pump right at the injectors. How do you set up a priming system for an old dodge diesel with no primer at the injectors?
any other advice on a veggie system for an 89 dodge cummins would be helpful... i have done one home conversion on the mercedes but this is a different system....Tapping into coolant lines? Hooking up a six port switch?
doy liver is offline
post #2 of 3 (permalink) Old 05-26-2008, 05:44 PM
on the 93-02 dodge diesels you need to back off 2 of the injector lines and crank the motor to purge air out of the system.
not sure if I answered your question.
jkidd is offline
post #3 of 3 (permalink) Old 05-27-2008, 06:34 PM
fedexpsd's Avatar
on all of the 5.9's that i work on has a cam operated fuel pump on the left side of the engine. On that pump there is hand operated pump that will help? I use compressed air (50 lbs in the fuel tank) to help prime if your pump is weak.
Red, 2000 F-250, 7.3, 4x4 Lariat, 35" BFG, 4" lift, Hyperteck chip,BTS Awsome trans. 4" exhaust, Bought new, 2005 Front end,cab lites, little ears, 2008 F-250 6.4 4x4 Lariat, crew, cab lites, moonroof, 20" wheels, 373 gears, instance heat,chome pkg. Sold the 2008, Burnt the 2000, Now have 1999 Ext. Cab 4x4 6" lift 2005 grill and bumper and 2002 Excursion, ALL 7.3's No more 6.4's in this house. Current Ride. Early 99, 255,000 miles. Swamp 175/146 injectors, swamps tunes. 4" exhaust, Swamps air cleaner. Adreian HPOP, Boost & EGT Gauges. 5 Speed.
fedexpsd is offline
  Diesel Forum - TheDieselStop.com > Other Topics > Bio-Diesel and Alternative Fuels
