How to seal fittings against WMO - Diesel Forum - TheDieselStop.com
Old 11-11-2008, 02:38 PM   #1 (permalink)
jstrauss's Avatar
What are y'all using to seal up your pipe fittings on your WMO filtering rigs? I used regular teflon tape, which worked good at first, but now the WMO is eating the tape and I am getting lots of leaks. Wondering what kind of pipe thread sealer y'all are using that can stand up to the WMO?
1991 F150 SC 4x4 7.5L/ZF5
1991 SAE Bronco 4.6L/4R70W
2002 F350 CC DRW 7.3L/ZF6
2005 Escape 2.3L/CD4E
jstrauss is offline
Old 11-11-2008, 05:50 PM   #2 (permalink)
DIESELDUTTON's Avatar
I use Loctite PST on everything, at work we have two 275 gallon waste oil tanks at work that have valves in them which are sealed with PST and they have not leaked in 18 years. Good luck
Frank
http://community.webshots.com/user/dieseldutton
2004 Pitbull Motorsports rigid chopper
121 TP 130rwh 250 avon
04 CRF250 mine
02 CR80 sons
03 XR100 daughters
425 Polaris magnum
500 Polaris sportsman and 300 lakota everyones
1998 27.5 Wilderness 5th wheel
DIESELDUTTON is offline
Old 11-12-2008, 12:03 AM   #3 (permalink)
arthurgoboom's Avatar
I haven't had any trouble with teflon tape yet. If you're using steel/brass pipe/fittings, maybe they have stretched and you need to tighten them up some more. I'm using PVC on all of my stuff and other than the stem seal in one of the PVC ball valves leaking, I haven't had any trouble.
1986 F250 2WD Super Cab XLT Lariat w/ 1996 front clip. Dually bed & van rearend (2" wider, allows spring clearance). 6.9 w/ approx 120,000mi. Banks non-wastegated turbo system, Wellman G088 glowplugs, Delphi BB injectors, Kenworth pyrometer, vac/boost gauge, electric water temp/oil psi/voltmeter mounted in dash. 3" Mandrel-bent open exhaust. C6 trans, 3.54 gears. Okiegringo idler pulley. R134a A/C conversion. WMO/diesel blend in one tank.
arthurgoboom is offline
Old 11-12-2008, 08:02 AM   #4 (permalink)
ReefBlue's Avatar
I use teflon tape without issue.
ReefBlue is offline
Old 11-13-2008, 10:33 AM   #5 (permalink)
My Photos: (6)
The yellow teflon tape for natural gas applications is thicker and seems to work well.
ToddT is offline
Old 01-14-2009, 07:07 AM   #6 (permalink)
What fittings I use a tuthill pump designed for WMO so no worries.
97 dodge 2500 4x4 cc lb 12V auto 3.54 pillar gauges 215 nozzels
31'TT at 8000 lbs
94 explorer
shorthair is offline
