check this out more power less egts.Click here: CHEC HFI Hydrogen Fuel Injection system reduces emissions and improves engine efficiency, reducing fuel consumptio
99cc f350 4x4,bts trany,ultra wheels,tymar,pac brake,fomoto,95gals total b-20 fuel on board,banks chip,3 inline air to oil trany coolers,bushwacker flares,pillargages tymar,xm radio,3 red tops,j&jvertical grill,b/w goose hitch with winch mounted to hitch,34ft toyhauler loaded with atvs pull at 6000ft to 10000ft
goofed on the click on here.im interested in more comments on hydrogen fuel injection.thanks catmech
It uses 4 kg of water per 10,000 km?
That's 5 grams of hydrogen per hour.
I find it incredible to suggest that mixing 5-10 parts per million of hydrogen with the incoming air would have any effect at all, let alone 10% fuel savings.
Douglas Campbell
November 5, 2008: The fat lady sang. Back to actually working for a living.
1986 Isuzu P'up, 177,673.8 miles. Hella headlights, (highly recommended) DOT C-2 back end. (also recommended) R-12 air conditioner converted to R-406a. 4.1:1 rear axle converted to 3.4:1.
9/22/2007, age 21: Still running well when reluctantly sent away for reincarnation due to rust.
must work like another gas.ten percent isnt alot of saving unless its big numbers.
H2O - did anyone notice where the 'o' got to? ( couldnt find any reference on their website as to whats done with the oxygen molecule from the water) I'm wondering if its also introduced into the incoming air stream to give a more compelte burn ? (again - would that low of a volume be enough to notice ??)
probably not worth asking, but what would happen to the combustion pressures ( and hence power output) if WATER was introduced in controlled minute quantities? higher chamber pressures as it turns to steam? cooler egts? higher gas flows through the turbo? on gassers its used to control detonation problems...but the % is so low in this setup [img]/ubbthreads/images/graemlins/shrug.gif[/img]
c.
'52 S1 96" Land Rover MB 240TD conversion
sounds similar to methanol/water injection systems. There are a few companies out right now selling these bolt on meth/water systems for around $400-$600 and it is a 50/50 mix of h2o and methanol. Just my .02
Sold it!!! 1993 F350 rebuilt 7.3IDI Turbo Crewcab running 4.10 and 35x12.50x16. Who needs mufflers... straight pipin' with banks downpipe upgrade and 3 in exhaust all the way back and gettin 18mpg if my foot wan't so dang heavy. Biodiesel home brewer and convertion to WVO almost ready for install. Electric Facet fuel pump conversion.
If you wanted to inject a water-methanol solution, you could run another hose from the windshield washer for a lot less than $400-$600.
Douglas Campbell
H2O - did anyone notice where the 'o' got to? (couldn't find any reference on their website as to what's done with the oxygen molecule from the water) I'm wondering if it's also introduced into the incoming air stream to give a more complete burn ? (again - would that low of a volume be enough to notice ??) ...
A 12-liter truck engine will suck in about 800 kg of air per hour; the CHEC HFI hydrogen injection system will liberate about 0.04 kg of oxygen per hour.
You'd experience more variation in oxygen concentration driving from the forest to the city and back.
Douglas Campbell
