JET A fuel in our trucks ?????????????? - Diesel Forum - TheDieselStop.com
Old 10-16-2004, 11:07 AM   #1 (permalink)
This was posted up on the 97's till i saw this fuel forum
Should i be concerned with using it. I treat it with additive to lube it. It's free so i gave it a try. A couple of freind's have been useing it for over a year with no problems. What else can i use to treat it so it has more or less lube? currently useing stanadine, someone recomended ATF.
what do you think?
Thanks,
Brian
97 F-350 XL crewcab LB 4x4 5-speed bone stock 117,00 mi
diablo1 is offline
Old 10-16-2004, 11:16 PM   #2 (permalink)
Re: JET A fuel in our trucks ??????????????
stanadyne should be ok, ATF is NOT ok.
Jet A is pretty harsh stuff, with virtually NO lubrication quality. Would be a good candidate to mix some Bio-Diesel in I would think!
Ford_Forgotton is offline
Old 10-17-2004, 01:54 AM   #3 (permalink)
Super_Dave's Avatar
We'd spike our trucks in the army with JP4 from helicopters.
I know a lot of people that use ATF in their diesel as a lubricant to extend the pump life.
Can you elaborate why it's so bad?
Super Dave
2006 E350 6.0PSD
2003 Excursion Limited 4WD 7.3PSD - Sold
1996 E350 Super Duty bus 7.3PSD - Sold
Super_Dave is offline
Old 10-17-2004, 11:57 AM   #4 (permalink)
the burn characteristics are unknown, plus, who knows what pollutants it is creating also. Ford SPECIFICALLY states not to add oils such as ATF to the fuel.
ATF was an old IDI/non turbo trick used on older diesels. The newer electronic controlled diesels with the "unit injector" your not supposed to do that. Lubricity is a good thing. But get it from Bio-D or true "FUEL ADDITIVES" not hydralic oil, atf or engine oil.
Old 10-17-2004, 05:14 PM   #5 (permalink)
What's the difference between JET A, the JP fuels.
diablo1 is offline
Old 10-17-2004, 05:21 PM   #6 (permalink)
dbennett48's Avatar
The label is the difference. Military uses JP and commercial uses Jet A. They are the same.
Dave
2004 F-350. Standard Cab, 4X4, 6.0 with Torqshift, 3.73 w/LS. <font color="red">(((XM))) Satellite Radio.</font> Lo Jack, 6608 lbs wet. Born on 8/4/2003. Engine 07/23/2003. 3" Lift. Grover Air Horns!!!
http://community.webshots.com/album/85108545NlXNsD
1993 F-350 4X4 7.3 IDI with 5 spd. Gone now.
1976 Kenworth C-500 with Detroit Diesel 8V92TA with 3 spd Jake, SQHD's and RTO 12513 10 Wheel Dump Truck. Sold.
dbennett48 is offline
Old 10-17-2004, 07:46 PM   #7 (permalink)
Here is a bit of info on aviation fuels. Jet A and JP-8 are both kerosene style fuels but differ in additive packages. I have no idea how it compares to plain old diesel fuel though I can tell you JP-8 and Jet A sure smell different from Flying J diesel.
01 F-250 PSD, CC, AIS, FTVB, Autometer Cobalts, Truck Cover USA Bed Cover, home brew coolant filter, Dieselsite spin on tranny filter
Anglo is offline
Old 10-17-2004, 09:44 PM   #8 (permalink)
I work on an Air National Guard Base and all our diesel equipment uses JP-8 all the time (on road and off road). It compares closely to #1 Diesel and will not jell at any temp that could be encountered on the surface of Earth. I have spoken to our Vehicle Maint Manager and he tells me that adding a lubricant is helpful for prolonging injection pumps.
hweaver
1990 F-350 7.3 Crew Cab Banks Sidewinder Turbo E4OD 4X4,
1984 F-250 6.9 4X4 4Speed Old Style Banks Turbo (gave to daughter, but still in family)
1988 F-250 7.3 4X4, C-6 Auto, Banks Sidewinder Turbo
hweaver is offline
Old 10-23-2004, 08:55 AM   #9 (permalink)
Thanks for all the info
Brian
diablo1 is offline
Old 10-23-2004, 09:11 AM   #10 (permalink)
With Jp-8 you have to adjust the timing. The first 2 or 3 tanks you will probably need to replace fuel filter, because it cleans out the system. I know we went from Ft sill to Ft hood with a humvee with the old 6.2. We had to stop and get regular diesel man it ran like crap.
85 f-250 ext cab 4X4 with a 93 cab Line-x underneith,2" body lift,6.9 bored 20 over,1999 P.S.wastgated turbo,Banks power elbo,2002 P.S.intercooler,K&N filter,ARP head studs,hypermax pistons,Hypermax piston pins,crane reground cam,Moroso 3qt oil accumalator,210 Deg fan clutch,Powershot 2000 propain, ZF-5 speed with luk clutch spicer 3 speed Aux 2.14 low 1-1 direct .74 overdrive, 2003 axles 3.73 ratio limited slip,PS steering box and arm,1 ton front springs,Firestone air bags front/rear, 3" strait pipe,A piller guages,carter electric fuel pump
woodie is offline
Old 10-23-2004, 08:31 PM   #11 (permalink)
any body know if any one is doing this in a cummins?
thanks
diablo1 is offline
Old 10-23-2004, 09:26 PM   #12 (permalink)
We have cummins in out aircraft tow tractors and all they run is JP 8. Don’t seem to have any problems but then they don’t get many miles put on them either. JP4 is basically JetA. JP5 is used on board ships because it has a higher flash point i.e. lower fire danger and JP 8 is primarily used by the USAF and most military shore bases. JP8 will not jell in cold weather/high altitude applications.
bluefxstc
2000, F250 PSD, Island Blue/Gold, CC, 4X4, SWB, Auto Trans, Diablo Sport, Isspro EV Gauges, Oil Guard Bypass Filter, Amsoil synthetics, Evans NPG+ coolant and filter, Dahl fuel filter, pre pump and tank mods, 3.73 LS, P265 AT, DLX Alum Wheels, Privacy Glass, Keyless Entry, Elec SOF, Off Road Pkg, Trlr Tow Pkg, Sliding Rear Window, Bug Deflector II, Roll-n-Lock Top.
bluefxstc is offline
