As the title suggests, I am curious as to how many of you have real world experience with running JET A in your Powerstroke. I may have access to 'some' unused jet fuel, and need to know the pitfalls.
I know it is a very 'dry' fuel, but don't know the sulfur content. Is there a lubrication issue?
Can you run it straight?
Or you you need an additive?
Add some 2 stroke oil.
Add some regular motor oil?
Add a jar of peanut butter???
Any tuning differences?
EGT worries?
Thanks for any input.
Bill.
2000 F-250 SuperCab XLT, 7.3, Man 4x4. 169k. (No Longer)Box Stock.
35x12.50-16.5 BFG T/A All Terrains on 16.5x9.75 polished 8 hole Eagle Alloys.
Faded Red with dents.
Now I got MODS:
'02 Lariat leather 40/20/40 seats
Foil Delete
IAH Deactivation
ZooDad Mod
No problems running Jet A in a 7.3 MrBill1. You do need to put some kind of lube with it. I used used veggie that I had filtered. If I had a lot of Jet A, I would put in 5 gallons of veggie and fill it the rest of the way with Jet A. If not, I would put in more veggie.
My brother had a Jetta TDI and he just mixed it 50/50 with diesel.
You will notice that the Jet fuel stinks pretty bad so the vegitable oil does help the smell some. Other than the smell I couldn't tell any preformance differences.
I put about 400 gallons of Jet A and 300 or so of veggie through in the past with no problems and I have about 165K on the clock.
Cheers.
1999.5 F350SC SRW Lariet, Black, No Decals, 4x4 Manual Hubs and Transfer Case, 6 Speed Manual Transmission, DP Tuner Econo Tune PCM, Tymar Air Filter
I've run a lot of JetA through both the 7.3 and the VW TDI, and have a lot of friends that have as well with zero problems. As stated by the previous poster, veggie would work well as a lubricity additive. I've worked with guys who have used SAE30, Marvel, transmission fluid, 5606, you name it.
My choice is 2-stroke injector oil (the type used on later model outboards and jet skis). I rarely ran either on pure JetA- the mix was usually 50/50 with diesel or a little more in favor of the Jet. I'd use veggie or biodiesel in a hearbeat if I had it available to me.
The smell has never bothered me; I'm quite used to it having been around it for over 30 years......
The stuff runs incredibly clean and odor free in kerosene heaters as well....
Jim
2002 Excursion Limited Ultimate 4x4 in black w/ all the goodies-DVD & lmtd slip. 285 BFG's, muffler delete, DIY Tymar, 2x4 glass lifts, etc, etc, etc
Thanks to all that responded.
I have been a little under the weather this past week , so I didn't spend much time on the computer.
But I really do appreciate the feedback.
Bill.
Now I got MODS:
Foil Delete
IAH Deactivation
ZooDad Mod
I used literally tons of it in my old duramax and my current 03 Excursion.Some times ran staright do to nothing to mix with.With the duramax I saw a slight increase in EGT but well within normal.I started using stanadyne lubricity treatment with it all the time.
Just a note, be careful about who you tell that u run it.Jealousy is a *****, and makes individuals do real stoopid things.
2003 -- Excursion LTD 7.3 Powerstroke 4x4
-10K mod,Maintain DIY air filter, CHP Cold Air Inake,Home made 4" side exit exhaust-
Where are you guys getting this stuff? I hear about folks running it all the time, but I find it hard to believe that airports are just giving it away to whoever asks...are you guys aviation mechanics?
