JP-8 - Diesel Forum - TheDieselStop.com
Old 11-22-2005, 10:26 AM   #1 (permalink)
JP-8
what should i mix with JP-8 Jet Fuel 50/50 with No 2 or 2stroke oil or what
2000 7.3L 10" Full Throttle lift, 38" Toyo's 20"rims. 4" MBRP Downpipe (YEP, just the dwnpipe,dumped after front wheel), 3stage TTS chip, Bullydog shift kit, 4:56 gears, clarion tv, pioneer deck, and speaker.
paul20 is offline
Old 11-22-2005, 11:37 AM   #2 (permalink)
Spencnaz's Avatar
My Photos: (14)
Re: JP-8
JP8 with biodiesel is a great combination. I would recommend an 80% JP8 with 20% bio combination to make up for the lost lubricity of JP8.
Spencnaz is offline
Old 11-22-2005, 03:23 PM   #3 (permalink)
Re: JP-8
[/ QUOTE ] no bio available
paul20 is offline
Old 11-22-2005, 04:09 PM   #4 (permalink)
Spencnaz's Avatar
My Photos: (14)
Re: JP-8
Ok then I would get some Powerservice product in that fuel.
JP8 doesnt have the lubricating ability like #2, you may also see a drop in fuel mileage as well.
I would suppose using one bottle of Powerservice to each tank of JP8.
Spencnaz is offline
Old 11-23-2005, 08:17 AM   #6 (permalink)
Re: JP-8
or 2 qts of 30weight non-detergent oil added to the tank full---
94_turbo is offline
Old 11-23-2005, 12:46 PM   #7 (permalink)
Re: JP-8
Or, a couple/few gallons of well filtered/settled used motor oil, or WVO or new VO.
2001 XLT 4WD Crew Cab Long Bed. 170k - Mostly stock except: In-tank and pre-pump (and harpoon),AIS (zoodad and fender sleve to come soon). DP tuner.
macinco is online now
