Just bought a 6.9 truck and want to run WVO ? - Diesel Forum - TheDieselStop.com
Old 11-04-2004, 08:29 PM   #1 (permalink)
Hello - I just bought a 6.9 F250 and want to supplement diesel with WVO being very convervative at first ( like maybe 10% ). I really don't know where to start . This sounds sort of silly but what are the best sources for "quality" WVO - eg chinese vs italian etc ? - thanks
rkpatt is offline
Old 11-06-2004, 02:19 AM   #2 (permalink)
Re: Just bought a 6.9 truck and want to run WVO ?
Chinese restraunts have the best oil. Make friends with your local restraunts and get a supply of oil. Store them in containers, one for settling out the particles, and one for filtered oil. You'll have to play around with your filtration system. Right now i run a particle seperator, and a commerical grade water filter. Air pressure drives it all. If you have it filtered well, you will be fine. I've run some crazy blends but i'm in warm weather. Good luck and happy veggin.
Patrick
2002 F150 7700 Supercab lifted 6.5in w/ 32V 5.4L swapped in. Powered by Ford and Procharger (2nd "bulletproof" transmission and 3rd rear end, getting another motor)
1991 F350 Crew Cab dually 2wd ZF5 and missing 2 cylinders. (RIP thanks to a Suburu)
DazedNConfuzedV8 is offline
