Go Back   Diesel Forum - The Diesel Stop.com > Other Topics > Bio-Diesel and Alternative Fuels
Old 04-05-2006, 12:45 AM   #1 (permalink)
Kerosene or Winterized Diesel for Winter Blending?
I was wondering if it is more effective, in your experiences, to use pure kerosene for blending with home brew biodiesel in the winter or just to use winterized diesel (which I guess contains a lot of kerosene too). I ask this because kerosene is typically 20 - 40 cents per gallon more expensive than diesel in the winter. But, if I only had to use half the amount of kerosene to cut my biodiesel… for example if I could run a 80/20 (biodiesel/kerosene) or a 60/40 (biodiesel/winterized diesel) at the same cold weather performance, the kerosene, although more expensive initially, would be more cost effective since I would have to buy less of it and also could in turn use more biodiesel all winter.
Any thoughts?
The fleet: 2002 F-250 7.3L PowerStroke Diesel, 2003 F-350 7.3L PowerStroke Diesel, 2005 Jeep Liberty CRD
tpendergraft is offline
Old 04-05-2006, 11:18 AM   #2 (permalink)
Spencnaz's Avatar
My Photos: (14)
Re: Kerosene or Winterized Diesel for Winter Blending?
What type of temperatures are we talking about? Remember that bioD made from soy will start to cloud at about 38 degrees F. Canola is much better at 25 degrees.
As for mixing, I would just mix 50/50 biodiesel and winterized #2 with an amount of diesel antigel. If you are going to get really cold at night, plug in your truck, run 60/40 with kerosene and antigel.
I haven't seen any antigel yet for biodiesel around here in the Seattle area, doesn't mean it doesn't exist though.
When mixing, put in your petro products first and then put in your biodiesel, biodiesel is slightly more dense than #2 and will settle down through the #2 to make a complete and thorough mixture in your tank. As you are driving, fuel circulation from the IP of your engine back to the tank will promote further mixing.
I had to learn this the hard way last winter when some commericial B99 gelled up on me during a cold snap here in Seattle.
The POWERSMOKE
1986 F250 4x4 XLT Lariat Explorer, 6.9 with Hypermax Turbo and cowl induction.
221k miles and climbing, C6 Transmission. Gear Vendors. Dual tanks with 50 gallon tank added to bed, locking canopy. Dana 50 TTB with Ford 10.25 rear and 3.55:1 ratios. Running B100 with no ill effects. Homebrew BioD. 80 gallon biodiesel processor with custom machined vacuum venturi
1973 Dodge Monaco aka 'Elwood', 64K original miles, Dodge steel cop rims with dog-dishes. 400 B-block with single exhaust, due for dual exhaust. Up for sale.
Other wheeled 'secret weapons' in the works.
Spencnaz is offline
Old 04-05-2006, 03:41 PM   #3 (permalink)
The lowest temps I can expect to see around here are the low twenties, very rarely does it get into the teens for an extended period of time. With regard to the biodiesel antigels they do have some avaliable for B100, but none that I have seen are cost effective even if they work as advertized. At the current prices winterized diesel or kerosene are much more effective biodiesel antigels.
Thanks for the blending tips, I will have to remember to add the diesel first. Plugging in my truck really isn't an option since I have to part in a parking lot over night.
So my question remains... is kerosene a more potent "antigel" than winterized diesel or are they about the same? Please share any experiences that you have.
Old 04-05-2006, 10:35 PM   #4 (permalink)
I found this additive. I've read on some European forums that it works really well...I am trying to get some so I can try it and if it works I want to sell here in the US. Might help though.
Kevin
http://www.biofuelsystems.com/wintron.htm
www.abqaltenergies.com
Biodiesel, Straight Vegtable Oil, Biodiesel and Petro Diesel additives.
forrestkk is offline
Old 04-06-2006, 12:13 AM   #5 (permalink)
Wintron is a promising additive but it is just simply not cost effective.
Look at the totals, 1 liter treats 100, or about 26.5 gallons. For a total price of $1.50/gal for WVO processed fuel (including all expenses and utilities) + ($51.35/liter for wintron + shipping) for a total price for 26.5 gallons of fuel at: $91.10/26.5 gal
If I had a B50 mixture of biodiesel and regular diesel say at $2.50/gal the total is: $53 for 26.5 gallons
If I had a B25 mixture of biodiesel and regular diesel say at $2.50/gal the total is: $59.63 for 26.5 gallons
Even if the Wintron works 100% as advertised, and I haven't used it... it is still just not economically feasible, its nearly twice as expensive.
http://www.biofuelsystems.com/shop/p...products_id=37
29.38 British pounds = 51.350364 U.S. dollars
Old 04-06-2006, 11:05 AM   #6 (permalink)
we hacd a cold winter here nad it was regularly down to the low single digits. I was running roughly 30% bio and had no problem. I started out with 50/50 but had to stop every half a mile to put a torch to the filter to thaw the fuel. I won't do that again. Oh by the was that is on #1 dino diesel or as some p[eople refer to stove or furnace oil.
Sold it!!! 1993 F350 rebuilt 7.3IDI Turbo Crewcab running 4.10 and 35x12.50x16. Who needs mufflers... straight pipin' with banks downpipe upgrade and 3 in exhaust all the way back and gettin 18mpg if my foot wan't so dang heavy. Biodiesel home brewer and convertion to WVO almost ready for install. Electric Facet fuel pump conversion.
2006 Dodge 2500 Megacab Cummins...stock...for now..hehehe
ak_cowboy is offline
Old 04-08-2006, 07:41 PM   #7 (permalink)
I second the thanks on blending tips. I fuel up in Fife and the Bio-diesel station is located before the Flying J, so I've always done the Bio first. Since I hardly ever frequent this forum there is a very could chance I've missed things about anti-gel. Howes makes a very good ani-gel product. Is this kind of product not what you guys are talking about?
01F350 CC 4WD 6SPD Arrow Canopy, 305/70/16's on 16"X8"wheels, HX mod, IAH plug, AFE Stage I w/pro guard 7 filter and overcoat. Evo tuner, WW, 4"exhaust,zoodad, Amsoil, Isspro gauges, GOS headlight harness,coolant filter
Endowment Member NRA
01crewcabtg is offline
Old 04-08-2006, 08:31 PM   #8 (permalink)
Spencnaz's Avatar
My Photos: (14)
The only antigel products I've used were for petrodiesel used in a 50/50 mixture with biodiesel.
CRC makes a very good antigel product with added lubricity for use with kerosene, I think it comes in a grey bottle.
The POWERSMOKE
Spencnaz is offline
