LEAKING FUELTANK!? - Diesel Forum - TheDieselStop.com
Old 08-19-2007, 03:34 PM   #1 (permalink)
LEAKING FUELTANK!?
Hello all,
I have been running B100 in my truck (2004 6.0) for around 20,000 miles and I have not had a single problem. However, the other day I noticed a black spot on my concrete drive. After sliding under the truck to inspect it looks as if the fuel tank is leaking. The frame rail, skid plate, etc. are all damp. I think it must be coming from the top of the tank & seeping down. I thought that all new vehicles used rubber compounds that were ok with biodiesel. I don't know if it matters but I have a tool box tank (91 gal.) I have been keeping this full for the past couple of months. It just feeds the tank via the filler neck, keeping the stock tank full at all times. I shut the tool box valve off so that the main tank level would drop and hopefully so would the leak, until I can fix it. What do you guys think?
2004 F350 CREW CAB - LONG BOX
REINB is offline
Old 08-19-2007, 05:56 PM   #2 (permalink)
Spencnaz's Avatar
My Photos: (14)
Re: LEAKING FUELTANK!?
I don't think it's a problem with biodiesel eating hoses. Sounds like you're front tank just got over filled from your tool box tank.
I've had this happen with my setup. Did you perchance use that kit from Northern Tool that is supposed to automatically shut off? I manually turn the fuel shutoff and don't rely on that check valve, it's never worked right anyway.
Spencnaz is offline
Old 08-19-2007, 10:22 PM   #3 (permalink)
Hey,
Thanks for your response. It only has one tank. It is an F350 Crew Cab - Long Box. Yes, the tool box kit was purchased from Northern Tool. It is very simple though, it does not use a check valve. It has around a 3/8 or 1/2 inch outlet line that runs into the a "Y" adapter that is inserted into the fill neck. When the tube gets full the flow is stopped. All of those connections and hoses look very dry. It has been in use now for almost a year. I just wonder why now. I don't even know what is on top of the fuel tank to leak? It may have a bad spot in the plastic? Any ideas? [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/shrug.gif[/img]
REINB is offline
Old 08-20-2007, 08:31 AM   #4 (permalink)
FTG-05's Avatar
My Photos: (25)
At least three or four people (or more) here have reported leaking OEM fuel tanks at that same location. At least one did not have an aux fuel tank; his leaked when he filled to the OEM fuel door.
The leak is probably coming from the OEM fuel tank vent. It's supposed to have a check valve (like the RDS gravity feed) but it appears to fail sometimes.
The dealer should fix it if you're still under warranty. See if you can get him to do the harpoon mod while he's in there.
Good luck.
Al
'06 F-350 SRW 6.0 PSD
FTG-05 is offline
Old 08-20-2007, 09:31 AM   #5 (permalink)
I just recently installed a new camper shell on the truck. Is it possible that the shell has allowed the tank to become hotter than normal and build excess pressure, causing the check valve not to work? It has also been very hot here latley. (90 plus days!) Should I take the time to drop the tank and investigate or should I just clean it up and try different approaches to see if it is still leaking. The truck is out of warranty, so any work I will have to do. Also what is harpooning the tank, I have heard about it many times on here but I don't really know what it is or why it is an improvement?
REINB is offline
Old 08-20-2007, 10:47 PM   #6 (permalink)
Others have reported salt/gravel getting under the straps and wearing/corroding through the top of the tank. Just something else to look at.
1997 F250 HD PSD 4x4 OR Auto 3.55LS CC SRW SWB 265x75x16 Michelin LTX DP 211K mi.; Ford AIC; Fuel milege; 20.3 mpg @ 70 mph. 12.5 mpg pulling my boat,12.5K, along two lane rural roads. A number of mods ordered from DaleI. Nice round replacement DP. FS2500 by-pass oil filter installed. Fumoto drain valve. Tymar Intake installed! HX mod from Tymar installed. TFI fillneck kits installed. Auto-Rx cleaner in engine & transmission done. Switched from Rotella dino to Rotella synthetic. Amsoil 5W-30 Series 3000 installed!
FS-2500 Bypass filter installed.
Velvet rides installed. Joe Servo IDM mod installed. Rear air lift springs.
Sparkydm is offline
