Re: % of lye
Roebic is 100% NaOH.
I highly recommend that you think about using KOH instead. It will not form hard soap if you screw up a batch and can of course be obtained in 50 pound sacks for about 50 dollars.
What I do is purchase a 50 pound sack and then divide the contents among 2 sealable paint buckets like what you get at a hardware store.
