mixing B99 and #2 diesel - Diesel Forum - TheDieselStop.com
Old 12-19-2007, 07:59 PM   #1 (permalink)
fddriver2's Avatar
Hey eveyone, I've found B99 in hialeah Fl. What is the max ratio I can mix with the truck in my Sig?????
I have a philosophy? Who knew. Ok, where's the beer?
2002 F-250 XLT CC SB\HPX\ITP prepump mod\Harpoon\DI 65psi fuel shim\4" SS turbo back Magnaflow\Fumoto\FTVB\Edge Evolution2\Zoodad\2008 Diff cover\V-10 Transmission cooler
fddriver2 is offline
Old 12-19-2007, 08:18 PM   #2 (permalink)
Re: mixing B99 and #2 diesel
Start out with a small ratio like B10 (10% of bio to 90% of dino) and then move up 10% a tank. Then u can run B100 like i do. Just coax ur engine with bio or else ur filter will plug up quick. Dont be suprised when it does b/c it will, considering its a cleaner
01 F250 EC LB PS: DP-tuner 80-100-120, pricol gauges, tymar, zoodad, fuel pressure shim kit, 4in turbo back,hpx, AIH delete, 203* thremo & billet neck, Home brew bio, 4 in lift with 35' mudders
baroy68 is offline
Old 12-19-2007, 08:28 PM   #3 (permalink)
Send a message via AIM to VD350
Just run B99 then change your filter when it needs it. The filter will plug if there is stuff in your tank no matter what
1986 F-250: 6.9L XL 4x4, 4.10 rear, 4 speed, Wellman GPs, 127,000 and chuggin along like new
1985 Mercedes 300SD: Daily Driver, straight piped
www.Fordemblem.com
My Truck and My Yamaha Tri-Z
VD350 is offline
Old 12-20-2007, 04:37 PM   #4 (permalink)
fddriver2's Avatar
Thanks guys, I'll probably start 5 or 7 gallons per tank to start and see where it takes me.......
Old 12-20-2007, 06:11 PM   #5 (permalink)
I just went straight to the B-99 when it became available in San Diego. I had a spare filter in the truck just in case. Never had a problem. Just changed out the filter at 15,000 miles like always.
2002, F350, Lariat, CC, LB, PSD, QLJ5, A/T, ESOF(with hub disable switch), LS, Off Road pkg, AIC, Jordan 2020, X-monitor, IAH removed, Fuel pressure shimmed, DP-Tuner 80 econo, acetoned badges, 315 BFG's on Alcoa's, 4"DPPI exhaust, Sonnax/Tricumulator, DIY BIG air filter with ZooDad, Bilsteins, EBV removed, WW, Proflex SS sleeves over the orange manifold hoses, MAP connected to adjustable pressure regulator, EBPS connected to intake manifold, Red line disconnected, Modified factory wastegate, 200 amp large case alternator, AutoEnginuity, Chris Thompson, SoCal Biodiesel Users Group member, Soon to have a bunch of goodies from Riffraff Diesel.
Duzitall is offline
Old 12-22-2007, 12:27 PM   #6 (permalink)
Ragdude's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Duzitall</div><div class="ubbcode-body">I just went straight to the B-99 when it became available in San Diego. I had a spare filter in the truck just in case. Never had a problem. Just changed out the filter at 15,000 miles like always.</div></div>
Where is bio available in San Diego? I travel there occasionally and I prefer bio.
Protect the 2nd Amendment!
It's the original homeland security act.
'96 F350,Dually,CC,5 spd.,stock.
'02 Excursion Limited, stock
B100 baby! Bring it home, to the American farmers!
Remember 9/11, and don't become complacent again
Ragdude is offline
Old 12-22-2007, 01:31 PM   #7 (permalink)
hheynow's Avatar
Pearson Fuels
4067 El Cajon Blvd.
San Diego, CA
619-521-2469
B99
'97 F-350 7.3L PSD RC LB 4WD E4OD - Plant Drive VO kit
'84 Mercedes Euro 300D NA - Custom two-tank VO
Running on Veg Oil and Biodiesel since May 2006
hheynow is offline
Old 12-22-2007, 02:59 PM   #8 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Ragdude</div><div class="ubbcode-body">Where is bio available in San Diego? I travel there occasionally and I prefer bio. </div></div>
hheynow is correct. Pearson fuels is the only retail outlet for BioWilly. We have 2 wholesale places too.
http://www.socalbug.org/info.html
Duzitall is offline
Old 12-22-2007, 09:00 PM   #9 (permalink)
F350_6's Avatar
I started with B20 in my 02 at around 155,000 and never had any filter issues, but I carry an extra just in case. Don't be too surpised when the truck seems to just smooth out a little as soon as the Bio hits the injectors.
Be sure and post back and let us know how you like it.
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 393,000 & counting.
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
F350_6 is offline
Old 12-25-2007, 11:55 AM   #10 (permalink)
Ragdude's Avatar
Thanks hheynow, I'll check that out next time thru.
Ragdude is offline
Old 01-02-2008, 10:48 AM   #11 (permalink)
I run 100% homebrew in my 02 and haven't had a single problem in 20K miles....
Just carry a fuel filter or 2 with you and you will be set.
taxmame is offline
Old 01-03-2008, 05:31 PM   #12 (permalink)
To run full-on bio, don't you need to make some adjustments to timing or somesuch?
austin1972 is offline
Old 01-03-2008, 08:01 PM   #13 (permalink)
Ragdude's Avatar
nope, I've been running 99% for the past year with no problems.
Ragdude is offline
Old 01-04-2008, 01:59 AM   #14 (permalink)
You do not need to adjust anything, I have over 60,000 miles on homebrew. The next time you replace the CPS use one from a DT466, it will advance the timing about 2.5 degrees.
Norman
97 F250 CC PS Tymar intake, 3" downpipe, 4" exhaust, turbo muffler installed backwards, 299,000 miles, running B100 when possible. "NEW 90 F450
StorminNorman is offline
Old 01-04-2008, 07:32 AM   #15 (permalink)
BlueMule's Avatar
My Photos: (12)
<div class="ubbcode-block"><div class="ubbcode-header">Quote:</div><div class="ubbcode-body"> The next time you replace the CPS use one from a DT466, it will advance the timing about 2.5 degrees.
</div></div>
How did you determine that?
BlueMule is offline
