mixing B99 and #2 diesel - Page 2 - Diesel Forum - TheDieselStop.com
Old 01-04-2008, 08:24 AM   #16 (permalink)
Re: mixing B99 and #2 diesel
By noting the two had exactly the same mounting and asking until somebody came up with the specs for each. It "seems" like the power improved when I replaced it, but that may just be my mind justifying the expense. I know the mileage went up about 1 mpg.
Norman
97 F250 CC PS Tymar intake, 3" downpipe, 4" exhaust, turbo muffler installed backwards, 299,000 miles, running B100 when possible. "NEW 90 F450
StorminNorman is offline
Old 01-04-2008, 12:49 PM   #17 (permalink)
O.K., I'll ask. What's a CPS, what do they cost and how easy are they to replace?
06 F-250, 6.0L, Rhino liner, Jack Rabbit cover, harpooned tank, Shaker 500, MBPR cat back, XCal 2, Commander, Amsoil bypass. Ravelco security, 100% home grown biodiesel.
9/20/09 56k miles, 1384.1 hrs
The more I know about biodiesel,
the less I know about biodiesel.
"You have reached Mr Medic. Please leave a message after the beep. If you would like to hear this recording in a language other than English, take your ass to a country speaks it"
mrmedic is offline
Old 01-04-2008, 01:38 PM   #18 (permalink)
Paul H's Avatar
My Photos: (10)
Cam Position Sensor
On front of engine below waterpump.
Used to be about $90 at International
Paul H
OWNER
2004 Ford F350 6.0L Dualie 214.000 miles with Edge Insight, Early Build 8/03 with 03 engine problem child
1996 Ford F350 7.3L Dualie 337,000 Tony Wildman custom burn,5 inch stacks, good ole girl
FOKISD CLUB MEMBER
FOKISD CLUB SITE WEBMASTER
http://www.fokisd.org/FICM.html
My Pictures
Paul H is offline
Old 01-04-2008, 02:37 PM   #19 (permalink)
$110 at IHC dealer, cheaper elsewhere. My engine is a 7.3 Powerstroke. I have no idea if this works on the 6.0 or 6.4 liter diesels.
Norman
Old 01-04-2008, 03:07 PM   #20 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: StorminNorman</div><div class="ubbcode-body">By noting the two had exactly the same mounting and asking until somebody came up with the specs for each. It "seems" like the power improved when I replaced it, but that may just be my mind justifying the expense. I know the mileage went up about 1 mpg.
Norman </div></div>
Hmm that'd be VERY interesting if that was all true..
Edit:found a PN# 1807339C92
Found the part on :http://www.thedwilsons.com/powerstro...t_Numbers.html
The part at my local International dealer was ~96$.
Link to some hard data:
http://forums.thedieselstop.com/foru...te_id/1#import
Seems to retard timing...smoother idle but less effecient? Give and take...
'95 XLT-302-39.5 IROK's, D60/10.25-Detroits/4.88 ~7" lift
'95 4dr Bronco C150 351, '05 60/10.5 swap with 4wheel discs. ~5" lift on 315's
'95 4Dr Bronco C350 PSD-AFE stage 2 intake, Tymar 3-4" DP, 4" exhaust, EBPV delete, FPR shim, IDM mod, and Wildman 4pos chip.
JoeBob1901 on Supermotors for pics/info
JoeBob1901 is offline
