mixing diesel with wvo BEFORE final filtering?? - Diesel Forum - TheDieselStop.com
Old 08-29-2005, 11:26 PM   #1 (permalink)
I'm new to all this, absorbing what info I can before I start.
Any comments, advise, or experience etc. about cutting the WVO with diesel to thin it, to lessen the viscosity BEfORE filtering down to the final microns??
Just curious, thanks.
Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways, champagne in one hand, strawberries and chocolate in the other, body thoroughly worn out and used up, screaming WOO HOO-WHAT A RIDE!!
Mike3 is offline
Old 08-29-2005, 11:56 PM   #2 (permalink)
Re: mixing diesel with wvo BEFORE final filtering??
what kind of filter are you gonna be using
markrules444 is offline
Old 08-30-2005, 01:09 AM   #3 (permalink)
If I were going to cold blend, I probably would mix it first, then settle before filtering. Three reasons;
-1 If there is any wax or sediment from a reaction with the WVO and diesel, it will get removed before you get it in the truck.
-2 Any waxy solids that may get disolved by the diesel will do so and pass thru the filter instead of clogging it.
-3 Thinning will allow solids to settle out much faster.
JOAT is offline
Old 08-30-2005, 08:49 AM   #4 (permalink)
Re: mixing diesel with wvo BEFORE final filtering?? "what filter"
I'm not entirely sure yet... I intend to pre-filter with something like a 200 micron screen before adding diesel, then letting it all settle, then maybe filtering through an air filter type then on down to the 3-5 micron I've been reading about.
I found some 200 micron screens on eBay that fit over an open 55 gallon drum that look promising.
I have access to new and used poly tanks and Shurflo pumps (12 volt or 115 Volt) so pumping and storage are no problem.
I just assume that a thinner mix would flow easier once I got started and that with proper filtration I wouldn't have to woryy about messing up my good (read expensive ) diesel.
Mike3 is offline
