Most effecient machine for removing oil ? - Diesel Forum - TheDieselStop.com
Old 12-27-2005, 04:50 PM   #1 (permalink)
I have tried the little electric pumps from Northern tool (seized 2 up) not powerfull enough and not quick enough. And I have tried a 5.5hp trash pump and have yet to get it to pump veggie only water. What have you guys had best of luck with?
I tried getting the places I get my oil from to put the oil back in the carboy's they get them in and all places said they rather have a larger company come and pick it up that its less of a hassle.
2000 Ranger V-6 115K miles
2001 F-350 Fummins
1998 Dodge 2500 SC SB
Lee Haenschen is offline
Old 12-27-2005, 05:38 PM   #3 (permalink)
Re: Most effecient machine for removing oil ?
is your oil really slushy or something (rather than liquid)? at that point you might need to exchange barrels, take the solid one home and heat it up- a lot of hassle.
Mark
Homebrew biodiesel crazy:
...several years with a couple of different 6.9's... now running a (gasp!)1998 GMC 6.5 van... don't shoot me.
girlmark is offline
Old 12-27-2005, 07:13 PM   #4 (permalink)
I use an oil pump from a small block V-8 Chevy. It is made for oil, and is positive displacement, which means no priming, Just stick the hose in the oil tank, adn the outlet hose in your barrel. I turn it with a 3/8" electric drill. i can pump 50 gallons in about 10 min. or less.
Here is a thread on another forum with info: V-8 oil pump for moving Veggie oil on InfoPop
'99.5 F250 crew cab, stock
'02 Excursion stock
Check out my blog: The Fixit Shop
scbaguy is offline
Old 12-27-2005, 07:59 PM   #5 (permalink)
h2odrx's Avatar
i went to wally world and got a 450gph 12v bait well pump, it works good on warm days have had some trouble on cold days? i'm looking for a shallow well pump to hook up to my tank, how much is too much pressure?
Remember, we aren't eating this stuff, we're turning it into diesel fuel. Your truck only cares about viscosity, acidity, and BTUs. Nothing else. -unknown?
NC State law defines biodiesel as ''any fuel or mixture of fuels derived in whole or in part from agricultural products or animal fats or wastes from these products or fats.''
Exemptions from the excise tax
h2odrx is offline
Old 12-27-2005, 08:29 PM   #6 (permalink)
I use an old hot water tank...plumbed to accept a 3/4" valve and plastic hose...another to connect the intake side of my compressor. Pull a vacumme to -21, close the valve. When I get to the oil site put in the hose, open the other valve and the tank fills itself (35-40) gallons in about 20 minutes or so. Of course only works on liquid oil but mine are all pretty good..
08 F350 King Ranch LB, SRW, Black&Gold/373 gears, 20" tires, everything but a backup camera. Adding Firestone air bags & Tork Lift tie downs. Still Stock & liking it.
01 F350 4x4 off road pkg, auto w/373 gears, Lariet SRW Midnite blue. Dueler AT tires, 4 inch HOG SS exhaust with 5 1/2 " tip. Rancho 9000 shocks, Firestone Air Bags, HOG guages, Lance 1130 camper and 19' Lowe Roughneck
dssamp is online now
Old 12-28-2005, 04:14 AM   #7 (permalink)
Here is a good link that tells how to build what dssamp is talking abouthttp://wvosucker.blogspot.com/ [img]/ubbthreads/images/graemlins/eek.gif[/img]
92 F 250 Ext Cab Long Bed 2WD 5-Sd , All stock "for now" 60 Gal tank in bed for burning used cooking oil , If you smell frys you might be behind me.
93whitetiger is offline
