I retested 3 times and came up with a titration of 7 over the base 7
Im using Red Devil
It was real hard getting the 1 gram measured out right for the liter of distilled water.
Im thinking that my test KOH/water solution is not right and giving me false info.
Go to your local Dollar Tree store, get a 3 liter bottle of Shasta Root Beer for a buck, enjoy the frothy liquid whilst you make a 3 gram to 3 liter solution. Or some variant of the above.
You either have some really nasty oil, or you do have an issue with the titration. I always check it twice if it is not oil I use regularly and know what to expect, or if I get a reading other than normal for that supply.
AND you are overloading the lye. Base is 5, not 7. Titration over 3 with Lye is for use after a little experience with the better stuff.
Besides all the above, I could not get the picture link to work either. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Norman
97 F250 CC PS Tymar intake, 3" downpipe, 4" exhaust, turbo muffler installed backwards, 299,000 miles, running B100 when possible. "NEW 90 F450
Yep wayyyyyyyy too much NaOH in there. Consider using KOH next time, KOH is much more tolerant of overloading and will not form a hard soap if you use too much.
try it again and only use 6-7 grams for that oil! i bet you get a good batch!! try and try again!!!
Remember, we aren't eating this stuff, we're turning it into diesel fuel. Your truck only cares about viscosity, acidity, and BTUs. Nothing else. -unknown?
NC State law defines biodiesel as ''any fuel or mixture of fuels derived in whole or in part from agricultural products or animal fats or wastes from these products or fats.''
They even sell it on Ebay. Make sure that it is 100%, but even better use KOH (potassium hydroxide). The base amounts will be different with NaOH and KOH.
--Hugh
p.s. a titration ammount of 7grams NaOH is aweful high for bio making.
1991 F250 XLT, 2WD, 7.3L IDI, 5 speed, 168K.
Red Devil is no longer 100% NaOH. In order to keep the methamphetamine cookers from making more they reduced the NaOH content in Red Devil to something like 50%, far below the proper concentration needed for biodiesel manufacture.
If you must use NaOH, look for the brand Roebic, Home Depot and the larger chain hardware stores should have it.
IMO, KOH makes a more consistent product, is far more tolerant of miscalculations on it's use and will stay liquid instead of turning into a hard soap like NaOH will do.
