My home WVO filtering setup - updated - Diesel Forum - TheDieselStop.com
Old 10-29-2004, 01:01 AM   #1 (permalink)
Since I can not edit my original post, I decided to use more virtual paper and am cutting pasting and updating in this new thread, with all new pics and details!!
After a lot of trial and error, and plenty sticky goey messes, i have come up with what i hope to be a fairly pain free filtering/settling setup. Below are some links to pics and an explanation
THIS is the setup as it sits complete. the bottom barrel on the left is my "dirty" barrel filling my heating barrel using my air hose and PVC pickup. The top rear TANK is a 175 gallon final product tank that I scored from a carwash for free. The middle, "blue barrel" is my heated oil and settling tank, with a valve about 1/3 the way up from the bottom. I installed a replacement hot water heater element, wired to a thermostat at the top. I made sure to place the element below the level of the valve, so that it is never "dry". There is a little more to what appears to be a white bucket sitting on top of the bottom barrel. The bottom barrel is my prefiltered oil, from there it is pumped by a SUMP PUMP That I picked up used from a local industrial supply outlet. It has a float switch so it comes on automatically, and shuts off when done. From the sump pump the heated prefiltered oil is then pumped through a DONALDSON P555823 fuel filter that I picked up at my local Peterbuilt shop for 7.69. It is the same filter that I have mounted in the ENGINE COMPARTMENT on my truck.
Finally the magic inside the white BUCKET, and with FILTER REMOVED . I have a piece of 5/16 allthread going through the bottom of the bucket into the lid of the barrel, with a nut and washer on each side holding the bucket and barrel together. The dots on the outside are metal roofing screws with rubber washers that help secure the bucket to the lid. The dots on the inside are holes that go through the LID into the barrel where the PREFILTERED OIL passes.
TOP OF FILTER. This is an air filter for a 92 Dodge cummins, that I get from Autozone as STP SA6629 and goes for 14.99. Schucks has them in the fram CA6629, and will proce match the zone. this filter has a metal top with a rubber/metal washer, and a sponge foam bottom. I am ususally able to filter between 60-90 gallons per filter.
BOTTOM OF FILTER
FILTERING IN PROGRESS
FINISHED PRODUCT. This is from the donaldson and into the 175 tank. The donaldson is good for about 200 gallons.
I simply dump the oil in the top 30 gallons at a time, let it heat and settle for a few days, then open the valve into the bucket, where it is then pumped through the donaldson and into the 175gl holding tank. I then place the 30 GALLON plastic jugs under the valve to transfer to the truck. I am so far very happy with the ease and lack of mess. [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
fordnut74 is offline
Old 10-29-2004, 08:56 AM   #2 (permalink)
My Photos: (5)
Re: My home WVO filtering setup - updated
That's a great system you have set up there. That final filtering setup with the Donaldson filter makes a real nice finished product.
Thank you for sharing your work.
Kwikkordead is offline
Old 10-29-2004, 09:12 AM   #3 (permalink)
DONALDSON P555823 Whats the micron rating?
jt911 is offline
Old 10-29-2004, 12:35 PM   #5 (permalink)
I haved attempted repeatedly to find a micron rating, without success. Even crossed part #'s to baldwin, wix, fram, duestch, etc. The Baldwin is however the OEM primary fuel filter for the Caterpillar 3406 series industrial engines, and that is good enough for me. Also, for what it is worth, since using the Donaldson on my truck, i have yet to have to replace the factory filter. Going around 7,000 miles since I last replaced the factory filter. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Old 10-29-2004, 05:26 PM   #6 (permalink)
BlueMule's Avatar
My Photos: (12)
If you go HERE and enter the filter # it will cross the # over to several dozen more manufactures and maybe you can find the micron rating from their website. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
FWIW I have several Donaldson P551000 and Fleetguard FS1000 (same exact filters) that are OEM on Cummins M11 engines and they are rated at 98.7%@10 micron 96%@8 micron and 83%@5 microns.I would suspect that the ratings would be very close for the P555823/cat
BlueMule is offline
Old 10-29-2004, 07:36 PM   #7 (permalink)
Ahhh Yess- the beta ratio thing. I believe if I understand it right, then your filters are a B-10=75? I understand that this is the new standard that all filters will be judged by shortly.
Old 10-30-2004, 09:14 AM   #8 (permalink)
Fordnut74
I hope you don't mind a few more questions [img]/ubbthreads/images/graemlins/confused.gif[/img]. Do you know what the pressure rating is on the Donaldson filter and if it has a built in bypass? What type of thermostat are you using to control the heating element? Also what is the brand and model of the sump pump you are using? I am setting up a simular system but I will use a bag filter to pre filter (free supply [img]/ubbthreads/images/graemlins/cool.gif[/img]).
Thanks,
99.5 F250 CC, SB, XLT, RED, PSD, R4100 + cooler & fan, 3.73 L/S, TT PKG, HEATED TTT MIRRORS, RANCH HAND BUMPER, REMOTE START & TURBO TIMER, ZOODAD RAMAIR w/AFE AIR FILTER, SONNAX, TRICUMU SPRINGS
metoo is offline
Old 10-30-2004, 09:33 PM   #9 (permalink)
Fordnut74
Thanks,
No problem on questions. I do not know what the pressure rating of the donaldson filter, but I do know that it does not have a bypass. I don't think any fuel filters do. When it plugs up, game over. i don't remember the brand of the sump pump, but am about to do a good cleaning of all the tanks, so I will take a look. the thermostat I am using was the cheapest hot water tank replacement I could find at Home Depot. It is adjustable from 90-180. Cool beans on the bag filter score. [img]/ubbthreads/images/graemlins/bleh.gif[/img]
Old 11-02-2004, 10:27 AM   #10 (permalink)
My Photos: (5)
I looked at this thread again, VERY nice work.
Old 11-06-2004, 02:28 AM   #11 (permalink)
ADTMan's Avatar
Well hello there board. I am a "newbie". A little about me. I live in Oklahoma, own a Home Theater/Satellite installation company. I put about 70k miles an a truck per year. (This gets REALLY expensive!) 31 married and I am hooked on this BIODIESEL! Ok, now the reason I am here.
I currently own:
2003 Chevrolet .5 ton
1997 Chevrolet Z71.
Now I am selling both! I go through a truck every two years and spend almost 10K dollars on fuel per year. When I bought my '03 I almost bought a new Ford PSD. But didn't because the price difference in fuel was not that much. However, the longevity and durability of a diesel engine almost swayed me. I have been glued the the computer researching biodiesel. B100 on the Ford PSD does not seem to have any major effects on the performance of the engine. Is this true? I prefer a Ford diesel over any other diesel out there. Hope I don't offend anyone with that statement. Sorry if I do! LOL So, how do I get started making my "home brew". I love fordnuts system. What additives, LYE, racing fuel,..... do you add? For the "home brew" system what is your estimated cost per gallon? Just a start guys, I hope I don't wear you out with questions. Please bear with me. I will not be satisfied until I have accomplished this!
Thanks and I appreciate you accepting me to the forum.
John Lowry
918-812-4551
1993 F250 Ex-Cab 4WD 5SPD 7.3IDI Factory Turbo
2005 Chevrolet 3500 CC Dually D/A 4WD
1998 Bobcat 863 SkidSteer Duetz Diesel
2006 Bbocat 430ZHS Track-Ho Kubota Diesel
2010 Kubota ZD326P ZTR Kubota Diesel
ADTMan is offline
Old 11-06-2004, 09:23 AM   #12 (permalink)
you arent wearing anyone out john--just keep asking--thats what Jason put this one up for-----
94_turbo is offline
Old 11-06-2004, 03:28 PM   #13 (permalink)
ADTMan's Avatar
I ordered a book today on amazon.com.
From the Fryer to the Fuel Tank: The Complete Guide to Using Vegetable Oil as an Alternative Fuel
I am hoping this will answer my questions.
Any input on how much money you save brewing your own would be a great help. Thank You.
ADTMan is offline
Old 11-07-2004, 10:07 PM   #14 (permalink)
ADTMAN- I guarantee that the once you go diesel, you will never go back. [img]/ubbthreads/images/graemlins/biggrin.gif[/img] I appreciate the comp on my system, but keep in mind that I do WVO, not Bio. I do not have to use chemicals, and worry about mixing ratios, and getting rid of the leftovers. But I have done some extensive mods to my truck to "easily" run WVO. Good luck in whatever way you go!!
Old 07-30-2009, 04:28 PM   #15 (permalink)
If you're still out there, can you update the links to your setup? I'd really like to see it!
Looks like MSN shut down their groups almost a year ago ...
Thanks!!
dhbmedic is offline
