Are my stock fuel lines ok for B20? - Diesel Forum - TheDieselStop.com
Old 05-10-2009, 06:24 PM   #1 (permalink)
It is a 93 F350 7.3 with ATS turbo. I just want to burn B20 at the most and was hoping the stock lines would be fine.
84 F250 4x4 "leaky" 6.9 with banks turbo.
I love this truck but why wont you stop springing leaks?
93 F350 4x4 ATS turbo crewcab.
magking1971 is offline
Old 05-11-2009, 06:52 PM   #2 (permalink)
Spencnaz's Avatar
My Photos: (14)
You should be fine, it's not like they'll dissolve over night if they're not compatible. Just keep an eye on the fuel filters, they'll clog up due to the biodiesel cleaning out the tank and lines.
Spencnaz is offline
Old 05-21-2009, 09:48 PM   #3 (permalink)
fro
does anything else have to do done to the engine to run B20?what about B99?
Sorry for the thread jack(same motor btw)
94 F250 IDI turbo e40d with 367k on her.
Hypermax exhaust,cowl induction hood and AFE air filter added
Vegas baby!!
fro is offline
Old 05-21-2009, 10:49 PM   #4 (permalink)
1987IDI's Avatar
My Photos: (14)
I'm trying to change all my lines to handle biodiesel, and by reading on here, i've learned that Goodyear SAE 30R9 fuel injection hose from auto zone will handle bio fules. Chang the hose from your frame to your lift pump and all your injector return lines with the stuff. Also the o-rings should be replaced with Viton o-rings. They will hold up too.
I believe that Spencnaz was the first to help me, but it takes a while for biodiesel to eat through regular rubber. On b100 i think it takes close to a month before it starts swelling and breaking down.
1987 F250 XLT Lariat
Regular Cab 2x4 6.9L 5-Speed
Homemade Propane Injection.
RUNS ON PURE WASTE MOTOR OIL!
No more diesel for me...
1987IDI is offline
Old 05-21-2009, 11:15 PM   #5 (permalink)
fro
Wow,even with the upgraded fuel lines its that fast?I guess Ill stick with b20 since I dont feel like doing my fuel lines every month.
Vegas baby!!
fro is offline
Old 05-28-2009, 01:52 PM   #6 (permalink)
Rickie's Avatar
With a '93 I would suspect that no rubber or plastic fuel system components are compatible with even B20. When we converted to bio-diesel (we eased into a B5, then B10, then B20, B50 to B70 blend), we noticed that a few of our suspect components, that we thought could be okay, began to deteriorate at B20.
just my $0.02 worth.
'00 F250 XLT 4x4 (born on 6/00), manual tranny & hubs, SPA Techniques EGT/Boost Gauge, Homemade HX Crossover Mod & Return Fuel Regulator, Toro Liner, 203* T-stat and Coolant Filter, LUK Clutch, flywheel & pressure plate, Amsoil Dual Bypass Filter
Rickie is offline
Old 05-28-2009, 04:05 PM   #7 (permalink)
1987IDI's Avatar
My Photos: (14)
What i meant was with the factory lines i believe that it takes close to a month to start wearing down, with the proper rubber in the fuel system it should never be affected by bio-diesel.
Also, since Rickie has seen a problem with B20 eating things, i wouldn't trust that on the factory rubber. I just ran it one time to try and clean out my fuel system.
1987IDI is offline
