The guy at my local fuel jobber is leary of selling methanol in containers not made of steel. I can purchase methanol in five gallon quanities but I have to provide my own container.What plastic container is usable with methanol?
Bullwnkl.
1990 F250 4x4 nearly stock, Alcoa wheels, 2 1/4" dual exhaust w/glass packs, Air bag rear suspension assit. Motocraft glow plugs, two Optima gelcell batteries, diamond plate running boards, Cowboy Junkies in the CD player, Rust the original Loc-Tite
I think any would work
I use to race gocarts which ran off of methanol and we bought it in a plain clear jug like the kind viniger comes in. Menthanol is not that corrosive.
I would only use plastic that has "HDPE 2" embossed on it. Normally on the bottom somewhere. As for the previous post I like to point out this particular quote from the MSDS report. I think maybe you were lucky for a while.
10. Stability and Reactivity
Stability:
Stable under ordinary conditions of use and storage.
Hazardous Decomposition Products:
May form carbon dioxide, carbon monoxide, and formaldehyde when heated to decomposition.
Hazardous Polymerization:
Will not occur. Incompatibilities:
Strong oxidizing agents such as nitrates, perchlorates or sulfuric acid. Will attack some forms of plastics, rubber, and coatings. May react with metallic aluminum and generate hydrogen gas.
Conditions to Avoid:
Heat, flames, ignition sources and incompatibles.
Check out the link below..if it doesn't work search for "methanol msds"
PLEASE TAKE THE TIME TO READ AND BEWARE OF THE RISKS. It can have serious effects on you and anyone around you.
v/r..david
08 F350 King Ranch LB, SRW, Black&Gold/373 gears, 20" tires, everything but a backup camera. Adding Firestone air bags & Tork Lift tie downs. Still Stock & liking it.
01 F350 4x4 off road pkg, auto w/373 gears, Lariet SRW Midnite blue. Dueler AT tires, 4 inch HOG SS exhaust with 5 1/2 " tip. Rancho 9000 shocks, Firestone Air Bags, HOG guages, Lance 1130 camper and 19' Lowe Roughneck
I was using a stainless steel beer keg for a meth/KOH mixing tank.
But what I do is size my biodiesel batches so they require only 5 gallons of methanol per batch. This way I can use a clear plastic carboy for mixing.
The beer keg was just too heavy even for me, and I couldn't tell if all of it was dissolved.
What do most people use for methoxide mixing tanks? Carboys?
I've seen a few people use those plastic cone bottom tanks on a stand. Is there any advantage to using a cbt for this stage? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
