New tank delivered, filtration questions
The freight company just dropped off my new 60 gallon tank/toolbox combo unit from Northern Tools ($500 not including freight from FL). Overall, the tank looks good... polished diamondplate. It makes a nice fit behind the cab of my truck leaving 60" of bed space between the tank and the tailgate. I'm going to add a 1 1/2" deep coolant chamber beneath the tank. This will provide some heat as well as elevate the overall tank a bit so it won't hit on the curve of the side walls as they radius to the floor. With the coolant chamber beneath, the overall height will be only about an inch above the sides of the truck.
It has a filler neck, manual fuel gauge and four ports: vent (next to the filler), supply (to fuel pump), return and drain. The drain is on the absolute bottom, driver's side. The supply and return lines are on the front edge (closest to the rear window of the truck) about mid-ways across the tank.
The toolbox has 6" of interior height available. It will be plenty of space for a fuel pump, some filter elements and some tools. But, where would you mount the filter? There isn't enough space on either side of the tank between the tank and sidewalls. I could go beneath the truck but would rather have something topside. Without giving up cargo space in the bed, what about running a filter horizontally and placed inside the toolbox compartment? Other than making a mess when changing elements, is there any problem running a pressurized filter sideways?
My plan is to weld a heavier bar across the width of the tank, toward the rear. This will give a place for securing the load as well as stiffening the tank from shifting cargo.
Any suggestions?
Todd T
