Newbie to B20 with some? - Diesel Forum - TheDieselStop.com
Old 11-17-2005, 08:06 PM   #1 (permalink)
gmpt444epsd's Avatar
Well I just found out a station near me sells B20. What are somethings i need to do to prepare to run this in the truck? should i runa small amount and work up to a full tank of B20? Last night it got down in the 20s and in the teens tonight so do i need to put additives in with every tank to prevent gelling or am i good with the filter heater?
thanks
geoff
1995 F250 XLT 4x4 7.3L Power Stroke, E40D, 3.55 LS, 294K+ miles on stock engine, BANKS 3 inch downpipe, Cabela's winter and summer grille cover, WARN premium hubs,, 2 add-a-leaves in back, 33x12.50x16.50 BFG All Terrains, Pioneer DEH-2700 CD player, Hella Dual Beam Fog/Driving Lights, DeeZee bed rails, Isspro Pyrometer and Boost guages, TSC toolbox with cargo rack on top, Front Tow Hooks
gmpt444epsd is offline
Old 11-18-2005, 10:41 AM   #2 (permalink)
Re: Newbie to B20 with some?
Geoff,
First, make sure that you have a spare fuel filter or two and keep them in your truck. If you have been running petro Diesel, the bioD can loosen petroleum deposits in your fuel tank. This can plug your fuel filter. Don't worry about it, just change them when/if they plug.
I started running B20 with about 40,000 miles on my truck and did not encounter fuel filter plugging. You have a few more miles on your truck so you have had an opportunity for more crud to build up in your tank.
You do not need to work up to a B20 blend. Just go ahead and fill her up. I think that you will be suprised at how it quietens down your engine. That's the combined effects of the increased lubricity and higher cetane rating of B20. You should not have to put any additives in a B20 mix... other than what you would normally do in cold weather. The properties of B20 are nearly the same as petro Diesel. Most distributors deliver B20 that is good down to 0 F. Try to find out what yours does or better yet get a specification for the fuel. I believe in treating fuel when weather in the single digits is expected. The rest of the time, I leave it alone. Stanadyne makes a product called "Performance Formula" that is great for petro Diesel and your B20 blend.
Enjoy your veggie oil mix!
2003 F-250 4X4 Lariat Crew Cab 156" WB, Arizona Beige over Black, 7.3 PSD,Superchips 1705 "tow safe", auto, 3.73 limited slip, X-Monitor, ARE hard tonneau cover, Line-X bed liner, Ford splash guards, vent visors, hood wind deflector, 50 gal Transfer Flow in-bed tank, Powerslot cryo rotors (front) with Hawk LTS pads, Ford AIS with fender sleeve, V3 Back-up Camera, Marinco mod.
kc_maverick is offline
Old 11-18-2005, 05:16 PM   #3 (permalink)
thanks for the info...a girl ditched our date tonight and im about half full so i might spend that money on B20 rather than her [img]/ubbthreads/images/graemlins/grin.gif[/img]
