Ok so im ready to start making my own Bio only problem is i dont know how to! is there some place i can buy a book that teaches you how and tell you what parts you need... i allready have a old water heater so someone please HELP ME!
If i piece all the parts together how much money do you think everyhting might end up costing... im hopeing alot less then the $2,500 kits i have seen.
If you do it right you can build one for under $400.00 or even allot less. First things first, buy the book and it will show you how to do it for less. All together I have about $300.00 in my setup and I can make 80 gallons a week.
Ok this might be a stupid question but does everyone that makes there own biodiesel have to go to restaurants and get the old oil from them or do they buy oil from somewhere.
I just ordered the book. I'll see if it looks like
something I can do in the old "burb". [img]/ubbthreads/images/graemlins/shrug.gif[/img]
1997 F250 HD PSD 4x4 OR Auto 3.55LS CC SRW SWB 265x75x16 Michelin LTX DP 211K mi.; Ford AIC; Fuel milege; 20.3 mpg @ 70 mph. 12.5 mpg pulling my boat,12.5K, along two lane rural roads. A number of mods ordered from DaleI. Nice round replacement DP. FS2500 by-pass oil filter installed. Fumoto drain valve. Tymar Intake installed! HX mod from Tymar installed. TFI fillneck kits installed. Auto-Rx cleaner in engine & transmission done. Switched from Rotella dino to Rotella synthetic. Amsoil 5W-30 Series 3000 installed!
FS-2500 Bypass filter installed.
Velvet rides installed. Joe Servo IDM mod installed. Rear air lift springs.
Please fill in your personal profile, so we know where you are located and what you are driving.
Check out www.craigslist.org in your area. Click on the nearest town to you, then use the search fuction in the upper left hand and choose sale/wanted in the drop down, type in electric water heater, then search. Only go after the electric water heaters that are lightly used. Old ones are free, newer ones are 10-50% of new prices. If you don't see any, then post your own ad in the wanted section. 50 gallon is a great size to get, but 40 gallon will work too. Those should be $100 or less.
I recently bought a one year old 80 gallon Kenmore for $150.
--Hugh
1991 F250 XLT, 2WD, 7.3L IDI, 5 speed, 168K.
My kit cost less than 150 to build. I used a 55 gallon drum turned upside down with the heater screwed into a reducer and put into the large bung and pick pipe into the 1 inch bung and then cut any size hole you want in the top to pour oil in. I personaly welded in a 3 inch bung so I could seal it once I add the meth. Real cheap(I mean thrifty) but hey it works great). oh yeah cut a 1 inch hole in the side at the top for recirculating the mix. Hope it helps
Sold it!!! 1993 F350 rebuilt 7.3IDI Turbo Crewcab running 4.10 and 35x12.50x16. Who needs mufflers... straight pipin' with banks downpipe upgrade and 3 in exhaust all the way back and gettin 18mpg if my foot wan't so dang heavy. Biodiesel home brewer and convertion to WVO almost ready for install. Electric Facet fuel pump conversion.
What I found out is these companies that sell these new tankless water heaters will contract with a plumber to install them. The plumber will take the old water heater out and install this new tankless system. Find and contact these plumbers. Lots of times they will give the old water heaters away. The one here in Dallas just sits the old ones out back and someone (Wholesaler probably) will come pick them up. The guy told me to just get here first and you can have your pick.
