Old Diesel Fuel - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 12-02-2007, 11:41 PM Thread Starter
KEG
Old Diesel Fuel
I have an a rental house with a 250 gallon tank of fuel oil (#2 Diesel) that has been in the house for about +30 years. Now I need to get rid of it.
So what can I do with it? Does old diesel go bad? And if so, can it be replenished to work in my '97 7.3L F-250? I need a solution that puts $3.25 per gallon fuel oil to good use. Looking for any good ideas!
KEG
KEG
'97 F250 4x4 7.3PSD auto, crew cab-short bed, 200,xxx, Michelin M/S, front receiver hitch,
MBRP 4" exhaust.
KEG is offline
post #2 of 7 (permalink) Old 12-02-2007, 11:55 PM
Re: Old Diesel Fuel
After a while it will go bad...gets Algae and starts to smell really stale. As far as time frame im not sure. Do you know how old it is? I have used diesel that is 2 years old before I topped it off with fresh diesel and every chance I got when it used some I would keep topping it off.
I have taken diesel that is older than 2 years old and ran it through my bullet kerosene heater. Ran just fine...little stinky but it was used in a open car port in winter.
I did use a biocide in the old diesel to help kill off any algae that had built up.
2000 Ranger V-6 115K miles
2001 F-350 Fummins
1998 Dodge 2500 SC SB
Lee Haenschen is offline
post #3 of 7 (permalink) Old 12-03-2007, 06:57 AM
Send a message via AIM to VD350
Re: Old Diesel Fuel
Are you saying the tank is 30+ years old or the fuel is ?
I've used stuff up to 7 years old in sealed 55 gallon drums, but it went in my tank with ALOT of additive added.
1986 F-250: 6.9L XL 4x4, 4.10 rear, 4 speed, Wellman GPs, 127,000 and chuggin along like new
1985 Mercedes 300SD: Daily Driver, straight piped
VD350 is offline
post #4 of 7 (permalink) Old 12-03-2007, 09:12 AM Thread Starter
KEG
Re: Old Diesel Fuel
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: VegieDiesel250</div><div class="ubbcode-body">Are you saying the tank is 30+ years old or the fuel is ?
</div></div>
The tank is probably 80 years old, but the fuel that's in there is probably +30 years old.
I was thinking supplements might make it usable (along with some filtering). But this is not something I want to guess at and screw up my 7.3L. However, I thought Diesel is a lower grade fuel that could have retained its minimal octane (if that's the right word) and would still burn if it has some of the other key elements reviatalized (i.e., supplements) and then filtered, etc.
I'm open to ideas. I just don't want to throw away $3.25/gal. fuel that could be put to use.
KEG
KEG
MBRP 4" exhaust.
KEG is offline
post #5 of 7 (permalink) Old 12-03-2007, 02:21 PM
spg
Re: Old Diesel Fuel
I would not be afraid to filter it and run it if it has not been contaninated. You could run anywhere from a 5 to 50% blend easily. I have seen 20 year old #1 mixed with no problem.
2001 International 4700LP T444E 210HP Fuller Six Speed 4.10
spg is offline
post #6 of 7 (permalink) Old 12-03-2007, 10:43 PM
hheynow's Avatar
Re: Old Diesel Fuel
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Lee Haenschen</div><div class="ubbcode-body">
I did use a biocide in the old diesel to help kill off any algae that had built up. </div></div>
That would be the first thing to do. Then filter it to 2 microns and check to see if there is any moisture in it. If so make sure to NOT pump from the bottom of the drum and have a good water separator filter like a hydrosorb filter .
'97 F-350 7.3L PSD RC LB 4WD E4OD - Plant Drive VO kit
'84 Mercedes Euro 300D NA - Custom two-tank VO
Running on Veg Oil and Biodiesel since May 2006
hheynow is offline
post #7 of 7 (permalink) Old 12-11-2007, 08:16 AM
Re: Old Diesel Fuel
Were it me, I'd pump some from several inches off the bottom (avoiding water) into clear glass container. If it looked good as in no green or brown slime and smelled like diesel, then run it. I would make sure I carried a extra filter just in case.
Good luck, RJR
1995 3500 Cummins, 4x4, 5spd, 4.10, pac brake, TST #5, 3k gsk, 215 injectors, BHAF, 50lb. boost, egt ga., TAG, 35/40, ported 12cm2 ex. timing 16.5
moparguy is offline
  Diesel Forum - TheDieselStop.com > Other Topics > Bio-Diesel and Alternative Fuels
