Go Back   Diesel Forum - The Diesel Stop.com > Other Topics > Bio-Diesel and Alternative Fuels
Old 08-01-2009, 04:20 PM   #1 (permalink)
Peanut oil use as lubricant?
Someone gave me several gallons of unused peanut oil. Just wondering if I could use this in the diesel as a lubricant? Would I have to filter it first? Not an expert in this area so thought I would ask those that are. Thanks for any inputs.
2000 F250 7.3
tbpower is offline
Old 08-13-2009, 02:37 PM   #2 (permalink)
I don't think so.
Most vegetable oils polymerize when they get too hot.
That means it could end up plugging the oil ports in your engine.
longwolf is offline
Old 08-13-2009, 05:22 PM   #3 (permalink)
I was talking about putting it in the diesel fuel. Maybe I did not word it correctly.
2000 F250 7.3
tbpower is offline
Old 08-13-2009, 05:51 PM   #4 (permalink)
FryerJim's Avatar
2% soybean oil in kerosene will raise it's lubricity to above the required specification for automotive fuel.
2% in diesel will absolutely ensure it is above the spec!
2% of 29 gallons is .58 gallons.
Throw 1/2 gallon in at each fill up and you should be fine. Just make sure there is no water in it!
-Jim
Early 1999 F350 6sp Manual, CC, Dually, Long bed, 2WD, 3.73 rear end.
Almost stock, PO dualed the exhaust out after the rear axel.
Purchased 3 April 2009 with 122,500 miles on it.
9 June 2009 has 127,000 miles on it.
Mods to come later...
FryerJim is offline
Old 08-13-2009, 06:19 PM   #5 (permalink)
ok, thanks. I went ahead and put some in the other day. Seems smoother at idle and quieter. Longwolf's reply had me scratching my head for a minute.
2000 F250 7.3
tbpower is offline
Old 08-13-2009, 09:20 PM   #6 (permalink)
To me, it sounded like you wanted to pu it in your crankcase
longwolf is offline
Old 08-13-2009, 09:33 PM   #7 (permalink)
re
That is probably why I did not get any replies in almost two weeks. It has been sitting at my Parents for a few years. Probably more valuable as cooking oil but we try to use olive oil for cooking. Hopefully, it won't clog my trucks arteries......
2000 F250 7.3
tbpower is offline
Old 08-14-2009, 04:10 PM   #8 (permalink)
No big cooker for Deep Fried turkeys? What a shame.
Although, I have heard of the peanut oil having a shelf life, and possibly going a tad sour for cooking. So, you'll probably get better results mixing it with your diesel.
just my .02 cents worth
short_stuff
Y2K F250 CC PSD Auto, Short-bed Lariat, Woodland Green/Gold, ordered 07/10/99, born 09/12/99, delivered 10/08/99, Access bed cover, Bed Rug, Zoodad mod, Viper Remote Start Alarm, Fumoto valve, 103K somewhat error-free miles (so far) [never back to dealer for anything]
Repairs: CPS, Water Separator Valve assembly, rear axle bearings, VSS, batteries, brakes, alternator, serpentine belt (x2), driver door pwrlock actuator, water pump
2009 VW Tiguan 2.0 l turbo 200 hp gas engine (TDI engine not available for it yet)
short_stuff is offline
Old 08-21-2009, 12:37 PM   #9 (permalink)
Spencnaz's Avatar
My Photos: (14)
IF you must add it to your diesel fuel, do it in limited quantities. That oil has been sitting for quite a while and will probably have water dissolved in it.
Also, only draw off the top of the containers to further reduce the risk of water getting into your injection system.
I'm not a fan of WVO usage (the jury's still out over blending), torn down one too many engines trashed by its use. Biodiesel solves most of the problems of WVO use, but since you only have a small amount of peanut oil to use, there's no point in climbing the biodiesel learning curve at this time for you.
Do you have some friends who make biodiesel? They'd be able to turn that peanut oil into biodiesel for you. I've done that for my friends when they needed fuel.
The POWERSMOKE
1986 F250 4x4 XLT Lariat Explorer, 6.9 with Hypermax Turbo and cowl induction.
221k miles and climbing, C6 Transmission. Gear Vendors. Dual tanks with 50 gallon tank added to bed, locking canopy. Dana 50 TTB with Ford 10.25 rear and 3.55:1 ratios. Running B100 with no ill effects. Homebrew BioD. 80 gallon biodiesel processor with custom machined vacuum venturi
1973 Dodge Monaco aka 'Elwood', 64K original miles, Dodge steel cop rims with dog-dishes. 400 B-block with single exhaust, due for dual exhaust. Up for sale.
Other wheeled 'secret weapons' in the works.
Spencnaz is offline
Old 09-02-2009, 02:02 PM   #10 (permalink)
soupdog's Avatar
use anything in my ole hoss including corn oil, lamp oil and if it was given to me, peanut oil, remember first diesel ran on peanut oil,, but my ole hoss is old but can handle, don't know about your newer one
91 f250 4x4,, e rated tires,,cab lights,,,straitpiped to rear,,,,brand spankin new cd player,,,flatbed with gooseneck,,,one hellava bale hauler,,,
International 856 wide front and a super h wide front ,, both have three points for haulin those bales.
63 w200 power wagon 17.5 inch e rated tires,,4 spd, 410's plus a six popper, she's a lil slow but she'll go anywhere yu point her
New to fleet 95 dodge 3500 EXT CAB 4x4 5 spd cummins power, 4 inch exhaust,
soupdog is offline
