Question on type of fittings to use - Diesel Forum - TheDieselStop.com
Old 06-14-2008, 05:47 PM   #1 (permalink)
I have an aluminum tank with aluminum male -8 JIC fittings welded into it. Can I use fittings made of anodized steel and/or brass to adapt the tank fitting to the hoses coming into the tank? Thanks.
Patrick
lancaster,pa is offline
Old 06-15-2008, 09:26 AM   #2 (permalink)
i have mixed SS AN(same as JIC) fittings to AL AN fittings... no issues.
2005 Excursion 6.0l
wilson & Co is offline
Old 06-15-2008, 10:57 AM   #3 (permalink)
hheynow's Avatar
Brass contains copper. Copper is not recommended for VO. I've seen some of my brass fittings (hose barbs) develop the classic copper green oxidation where there was a slow leak at the threads. Go with stainless steel.
'97 F-350 7.3L PSD RC LB 4WD E4OD - Plant Drive VO kit
'84 Mercedes Euro 300D NA - Custom two-tank VO
Running on Veg Oil and Biodiesel since May 2006
hheynow is offline
Old 06-15-2008, 05:19 PM   #4 (permalink)
You won't have any problems mixing metals. Steel or Stainless Steel is preferable for SVO/WVO. Check out Discount Hydraulic Hose.com they have a good selection.
Leon
WVO Designs - A do it yourselfers guide - Home
leongriffin is offline
