Red Kerosene?? - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 05-14-2008, 06:49 PM Thread Starter
Red Kerosene??
Im getting ready to start my process and have read ALOT of this forum and am ready to start asking dumb questions. I went out and got a 55 gallon drum of Kerosene and it was Red in color? I have used kerosene before in a heater but it was white or clear I should say.
Whats up with it being red? I have heard that it may be red dye diesel...is that correct? I did get it at a gas station for 4.19 a gallon.
I am going to use the DSE mixing instructions but I need to know if I use it in a 20% ratio recomended with petro diesel or use the recomended 10% ratio with Kerosene?
tregrad is offline
post #2 of 7 (permalink) Old 05-14-2008, 09:02 PM
The pump you got it from should have had some verbiage about it being for non-taxable use. I don't know of any on-road use for kerosene.... but i suppose since it is sold at service stations they could dye it and declare it tax exempt.
Diesel fuel is dyed and declared tax exempt use only. If you are at all scared of the tax man you may want to re-think using that dyed kerrosene. the tax man will not care what fuel was originally dyed... if his "sniffer" finds that dy in your tank you could be subject to large fines. He will not care to hear any story involving tax exempt fuel.... But you may or may not be scared of the tax man.
sinner in need of The Savior.
2001 F250 Extended Cab 7.3L Superchips. Air Raid Intake. DieselSite 203* T-stat. DieselSite AIH Delete. Dieselsite Valley Boots, DieselSite Turbo Master, Tekonsha Prodigy. B&W Turnover Gooseneck.
WVO conversion, installed and then removed.
Wife's= 2002 VW Jetta TDI. Coolant Heater.
YergInGA is offline
post #3 of 7 (permalink) Old 05-14-2008, 11:25 PM
DIESELDUTTON's Avatar
I have used both red and clear, but the last 100 gallons or so I have used diesel at the normal DSE ratio with no problems at all. Good luck
Frank
2004 Pitbull Motorsports rigid chopper...Traded on 2010 F-250 5/30/14
121 TP 130rwh 250 avon
04 CRF250 mine....Gone
02 CR80 sons...Gone
03 XR100 daughters..Gone
425 Polaris magnum
500 Polaris sportsman and 300 lakota everyone
2011 Cougar 325 SRX Toyhauler
2010 F-250 4 door 6.4 with all the fixins
DIESELDUTTON is offline
post #4 of 7 (permalink) Old 05-15-2008, 07:54 AM
If you are using it as a "cutter" use the same ratio as diesel #2.
1993 Crewcab 4x4 coverted extendcab,7ft bed , upgraded rebuilt E4OD w/ shift, new shocks, 3.55, Eagle aluminum wheels,1996 bumper, front buckets, ATS turbo w/ 4inch custom exhaust in process,60 gal aux tank for alt-- err extra fuel
1984 300SD single tank mix doing great
1998 Mountaineer FOR SALE
1994 Bronco w/ 1995 Lightning motor..wa hooo
jski55 is offline
post #5 of 7 (permalink) Old 05-15-2008, 06:49 PM Thread Starter
Thanks for the input fellas.....as the tax man goes I am buying "Kerosene" I will go and take a pic of the store or a video of it or something to back my play . a reciept may even do the trick lol .
again thanks alot
tregrad is offline
post #6 of 7 (permalink) Old 05-25-2008, 02:26 PM
It doesn't matter where you bought it, or if it was kerosene, if they check you and you run any dyed fuel in your vehicle, including kerosene, its a $10,000 fine. In certain parts of the country they stop and check a lot of trucks.
SunWizard is offline
post #7 of 7 (permalink) Old 05-26-2008, 11:37 AM
again thanks alot
Like the others have said, the dye is for tax purposes. They will not care if its kerosene or not, if its dyed, it has no business in your truck. You are guilty of tax evasion. Fines will vary depending on several things, but will be severe, and not worth the pennies you save puring it into your tank.
BTW, K1 is used in winter fuel to help lower the gel point, so claiming that "its kerosene" won't cut it.
OMC
OMCUSNR is offline
  Diesel Forum - TheDieselStop.com > Other Topics > Bio-Diesel and Alternative Fuels
