Rough Idle -- Cutts Off 02 7.3 - Diesel Forum - TheDieselStop.com
Old 09-23-2008, 08:27 PM   #1 (permalink)
2002 7.3 PSD NEED SOME HELP ----- BEEN running 2tank wvo / few gallons of motor oil -for a while -- but now I've run into some problems --truck runs better on veg than diesel-- while on diesel it idles up and down sometimes it turns off -- I have to keep one foot on the brake & one on the accerlerator for it not to turn off-- Diablo -- reads PO602-PO605-P1211-P1690 these codes are normal for tuned motor
- THAN PO603 KAM--KEEP ALIVE MEMORY-- CAN ANYBODY GIVE ME ANY IDEAS
2002 F350 4/4 4DR LNG BED
zusmar is offline
Old 09-23-2008, 08:30 PM   #2 (permalink)
Send a message via AIM to rockets10510
how many miles on the truck.
dont know what the codes are but could it be the pump?
just an idea.
anthony
1997 F-350 2WD SRW White Crew-Cab Bought in 3-05 w/196,xxx miles 280,xxx miles, 4" exhaust, tymar, oil bypass changed oil at 10k, TW 6 pos chip, stage 1 DIY injectors, fully build racerx trans, B & W turn over, coolant bypass filter, intercooler.
Parts Replaced:
Water Pump 213,000 $120.00 Napa
Alternator 224,000 $64.00 Ebay
Fuel Pump 221,000 $64.60 Ebay
Radiator Core 252,000 210.00 (All Alum) Preference Radiator
Fuel Bowl 262,000 NEW from Ford $348.00
rebuilt trans my self with racerX parts. 265,000 $2800.00
DIY Stage ones 267,000 $350.00
Waterpump 265,250 $70 Thedieselstop
Flexplate 280,000 $85.00 autozone
1997 Ford F350 2WD SRW Green Crew cab bought 06-07 with 232,000 miles, Now 238,xxx miles, AFE exhaust, oil bypass, coolant filter, , 6pos Tony Wildman Chip
Parts Replaced
Fuel Pump 234,000 $65.00 Ebay
Ford Reman Trans 234,000 $2100.00
rockets10510 is offline
Old 09-24-2008, 02:30 PM   #3 (permalink)
the truck has over 210k but i changed the pump back in Jan 08 --I got it from ebay may be it's bad ---- the funny thing is if I purge the system by swiching the selanoid on ---it idles up & smooths out
zusmar is offline
Old 11-04-2008, 05:19 PM   #4 (permalink)
klhansen's Avatar
My Photos: (169)
The P1211 means that the HP oil pressure is uncontrolled. It can be because of a tuner demanding more oil than the HPOP can keep up with, or it can be because of a sticky IPR, which would also cause the wild idle. Could also be a bac ICP sensor.
Hard or no-start? Check Here
klhansen is offline
