Run used oil - Page 2 - Diesel Forum - TheDieselStop.com
Old 08-25-2006, 07:32 PM   #16 (permalink)
Maintain's Avatar
Re: Run used oil
I wouldn't do it. All those metal shavings and impurities scoring up your cylinder walls...
2001 F250 CC/SB Platinum
11.62 @ 115.79
SWAMPED
Maintain is offline
Old 08-25-2006, 09:34 PM   #17 (permalink)
Re: Run used oil
cardiac
You are on the wrong board. There is info on burnign WMO on the alternative fuels board.
It is a different clan of folks there.
Check it out [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Early 99 F 250, Walker Big Truck Muffler, Otherwise bone stock at present.
HenryE is offline
Old 08-25-2006, 10:14 PM   #18 (permalink)
Re: Run used oil
Hey why try to change his mind.If he thinks he can pull it off, let him. Its his engine and his money. When he ruins his injectors(perhaps). I would bet we won't know about it [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
01F350 CC 4WD 6SPD Arrow Canopy, 305/70/16's on 16"X8"wheels, HX mod, IAH plug, AFE Stage I w/pro guard 7 filter and overcoat. Evo tuner, WW, 4"exhaust,zoodad, Amsoil, Isspro gauges, GOS headlight harness,coolant filter
Endowment Member NRA
01crewcabtg is offline
Old 08-25-2006, 10:26 PM   #19 (permalink)
klhansen's Avatar
My Photos: (169)
Re: Run used oil
I'm not convinced I'm running such a risk. As for the reason, I live 40 miles from the nearest place that will take waste oil.
If you change oil on a regular schedule (3000-5000 miles), they you'll be changing maybe once a quarter, which amounts to one 5 gal bucket of waste oil. And you're saying you can't get by that recycle place once a quarter? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
When I weigh that "inconvenience" against the possible damage to a set of injectors, even the cost of running that 40 miles immediately after changing the oil makes sense to me.
Hard or no-start? Check Here
klhansen is offline
Old 08-25-2006, 10:42 PM   #20 (permalink)
Banned
Re: Run used oil
Look at it this way.... you can put whatever you want into your fuel tank. By the same token, many others have warned you that they don't believe that this is a good plan...
But, then, you return, still seeking justification... someone to tell you it's "OK".... Offering little "but if I"s.... Still no takers.
Being semi-impervious to criticism, it is left up to me to ask "what part of NO don't you understand..."?
Disclaimer... it ain't my truck... it ain't my motor and it ain't my wallet. Any of us will state an opinion - none of us can make your decision for you....... Some of us will not pass up the opportunity to say "I told you so....".
If you still decide to pursue this misadventure, I suggest pouring the same amount of used motor oil into your wifes car.... used oil isn't on the approved fuels list for it, either...
GrampyJim is offline
Old 08-25-2006, 11:25 PM   #21 (permalink)
My Photos: (21)
Re: Run used oil
Grampy,
Your presence on these forums is valued by many, including myself. But you can be extremely smug and condesending at times when it's completely uncalled for.
I'm not seeking justification and I don't care if it's ok with anyone else or not. I personally know a fair number of people that burn WMO in their diesel pickups. Do I blindly follow them? No! But anecdotally, they seem to do so without issue. I asked - repeatedly I grant you - why exactly is it not a good idea to do it. So far, the only thing I've heard is that WMO contains wear metals and contaminants that can cause excessive injector wear. If that is in fact the only compelling reason not to do it, I believe I'll filter it carefully and run with it. If there are other reasons - other than "because it's not recommended by Ford, Navistar, or Grampy" - then I'd like to know.
Btw... Nice attitude. It's good to know you're willing to have a civil discussion [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
-john
1999 F-350 6-Speed SRW CC LB 3.73
jas10 is offline
Old 08-25-2006, 11:31 PM   #22 (permalink)
Re: Run used oil
It's a GREAT idea! But I do suggest a 50/50 mix as it will lead to quicker confirmation of what everyone has tried to tell you. Why trash a 10K engine for $3.00 per tank of fuel. What do you have to gain?
Early 99 (couldn't wait to get my butt in the seat of the new SD) Crew Cab 4X4, 6 speed, AIC, 5" lift, 38X14.50 Nitto Mud Grapplers (awesome mud tire, noisy though), Bushwhacker cutout flares, 4" straight exhaust w/6" tip, open element filter, cowl induction hood, custom grill, stereo upgrade, and most importantly - new style cup holder. 'Pane. H2O soon to come. Kill Record: 1 Honda Accord
Sold the SCMT and replaced it with a DP Tuner, and aint looking back!
byantdt is offline
Old 08-26-2006, 06:13 AM   #23 (permalink)
Re: Run used oil
"As for the reason, I live 40 miles from the nearest place that will take waste oil."
I'd be surprised if you could rebuild your engine for $2K. If
disposing of used oil is your concern, have you thought of
synthetic oil, high quality bypass filtration, and extended drain
intervals? That would drastically reduce your used oil disposal
and is safe when used in conjuction with oil analysis. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
1997 F250 HD PSD 4x4 OR Auto 3.55LS CC SRW SWB 265x75x16 Michelin LTX DP 211K mi.; Ford AIC; Fuel milege; 20.3 mpg @ 70 mph. 12.5 mpg pulling my boat,12.5K, along two lane rural roads. A number of mods ordered from DaleI. Nice round replacement DP. FS2500 by-pass oil filter installed. Fumoto drain valve. Tymar Intake installed! HX mod from Tymar installed. TFI fillneck kits installed. Auto-Rx cleaner in engine & transmission done. Switched from Rotella dino to Rotella synthetic. Amsoil 5W-30 Series 3000 installed!
FS-2500 Bypass filter installed.
Velvet rides installed. Joe Servo IDM mod installed. Rear air lift springs.
Sparkydm is offline
Old 08-26-2006, 08:36 AM   #24 (permalink)
Re: Run used oil
Ok, but a micron is 39 millionths of an inch. And don't the fuel filters on our trucks filter to 20 microns? Seems that unless the fuel we put in is really really clean our injectors are on borrowed time anyway. If I run waste oil through a sub-micron filter and put in one gallon per tank I just can't see it causing problems. I could be wrong, but that's the way I see it.
-john
Your math is a little off. There are 25400 microns per inch. Most fuel filters for diesel, at the engine, are 2 micron filters. Is it that the oil is hard to dispose of or is 3.75 gallons of old oil, worth about 12 bucks as fuel if that, financially important to burn as fuel every 5K miles?
2002 F250 7.3L PSD, bought new now at 195K miles, 4R100 Auto, Crew Cab, Short Bed, ITP Regulated Fuel Return system, ITP head to head SS oil cross over, Hutch in tank mod
Harpoon de tank vent, DIESELSITE Dahl 100 Pre-Pump Fuel Filter, DIESELSITE Return Fuel Line Cooler, DIESELSITE Engine Coolant Filter, DIESELSITE Auxilliary Transmission Cooler, DIESELSITE Gage Package, Pyro, Trans & Boost, Extreme Diesel AD injectors, Ford AIS Air Filter System, BTM straight through muffler, Moog Ball Joints, Rancho Shocks, Rotella ELC Coolant ,Stock Engine Program
Modified for I-Pod Connection
We b playing Scotland The Brave to Jimmy Hendrix
Oneof6 is offline
Old 08-26-2006, 02:04 PM   #25 (permalink)
Re: Run used oil
[/ QUOTE ] That's funny. You told him he was wrong and then told him he was right.
Anyway, how can [ QUOTE ]
The fitment between these tow parts (think fitment of piston to cylinder wall) is on the order of 20-30 millionths of an inch.
[/ QUOTE ]- which is about 1/2 to 3/4 of a micron- when the fuel filter is filtering to 2 microns? Engineered failure?
Devo
Work like there is a tomorrow and play like there isn't.
87 F250 Lariat SC LB 4X4 with an NA 6.9, C6 with deep pan and 4.10's. Dana 50 IFS up front. 263K mi. 3" exhaust, Ram air. New aluminum radiator and coolant filter Sep 09.
96 F350 CC LB 4X4 AT 292K- creamed by Brain Dead Cager turning left 02/18/10 RIP
DevoK12RS is offline
Old 08-26-2006, 06:43 PM   #26 (permalink)
Re: Run used oil
Ok, this answer is coming from a Tech from Freightliner who I trust completely.
You can't filter the impurities, dirt, metal etc down enough to where it won't harm these newer injectors & do it affordably. In the old days it was common practice. Also, you cannot remove the HIGH acid levels found in WMO by filtering, which also damage injectors. Also, the additive packages being used in todays diesel oils are designed to not burn under heavy load, high compression diesel engines. The additives are non combustable & flat out don't burn, in order to protect the internal parts of our engines. Since it doesn't burn easily & needs to be mixed with diesel to even pass it through the engine. Then it produces less power which requires more of it. So the savings are even less.
It's just a bad idea & not just for one, but for multiple reasons.
My Photos----- BTS BUBBA "Life Member"
2002 7.3L Excursion 4x4, FTVB, MBRP 4" SS Exhaust, Rancho 9000X shocks, "V" code Front Springs & "B" Code Rear Springs, Ride Rite AirBags, Rear Hellwig Swaybar, Cut Front BumpStops, DieselSite Ext Trans Filter Kit - Coolant Filter Kit & 203 stat, "Scotpart" mod, "Hutched & Pooned", "LandYot" Radius Rods US Gear Overdrive 75mph @ 1750rpm's
2001 7.3L F350 CC LB 4x4 5" Exhaust, pillar guages, BTS Trans, US Gear Underdrive, DP 6 pos chip, V10 Trans Cooler, DieselSite - Coolant Filter Kit, Evans Coolant, 203 stat, DI reg Fuel Return, GT38R BB Turbo, AFE 2 Intake, Banks Intercooler, Air Rite Bags,
2000 Excursion Limited V10 4x4 7" Lift
"Family of 5 saved by Grace"
Snowman269 is offline
Old 08-26-2006, 07:08 PM   #27 (permalink)
Re: Run used oil
Very good answer. I am certain it will be ignored by many. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
97 F250 CC PS Tymar intake, 3" downpipe, 4" exhaust, turbo muffler installed backwards, 299,000 miles, running B100 when possible. "NEW 90 F450
StorminNorman is offline
Old 08-26-2006, 07:10 PM   #28 (permalink)
My Photos: (21)
Re: Run used oil
Thanks Snowman. That's the kind of information I was looking for.
-john
jas10 is offline
Old 08-26-2006, 08:11 PM   #29 (permalink)
Banned
My Photos: (38)
Re: Run used oil
I had wondered the very same thing about the ACIDITY of the oil, but didn't know enough about motor oil to comment one way or the other regarding that.
gregrob is offline
Old 08-26-2006, 11:57 PM   #30 (permalink)
h2odrx's Avatar
Re: Run used oil
-john
in my 87 if the CDR fails and oil gets in the intake it causes higher temps in #7 & #8 then may cause a head gasket failure? so if oil burns hotter why do it? [img]/ubbthreads/images/graemlins/confused.gif[/img]
Remember, we aren't eating this stuff, we're turning it into diesel fuel. Your truck only cares about viscosity, acidity, and BTUs. Nothing else. -unknown?
NC State law defines biodiesel as ''any fuel or mixture of fuels derived in whole or in part from agricultural products or animal fats or wastes from these products or fats.''
Exemptions from the excise tax
h2odrx is offline
