Run used oil - Page 4 - Diesel Forum - TheDieselStop.com
Old 10-22-2006, 10:18 AM   #46 (permalink)
My Photos: (9)
Re: Run used oil
I came on this thread a little late but Cummins has been offering this system even recently even on their fancy electronic engines that meters a little bit of the sump oil into the fuel supply to be burned all the time. That way you have no oil changes. Basically they turn the engine into an oil burner. Selling point is it saves fuel and oil changes.
Birken
Birken Vogt is offline
Old 10-24-2006, 07:12 PM   #47 (permalink)
travis23's Avatar
Re: Run used oil
im running 60% used trans oil in mine get it a work free saved 120 in the past 3 weeks it runs good off of it starts good too i filter it 3 times before it goes in to the tank and no oil from killed units only trans flushes it runs bettter off of dex3 but the sp is really stinky going to do it for a while
1988 crew cab 4x4 idi in trash can 97 powerstroke engine in and running stong burning atf nothing like free fuel, update pieces of the head gasket laying on the frame stretched headbolt was the cause oops
travis23 is offline
Old 10-26-2006, 03:03 PM   #48 (permalink)
AggiePSD's Avatar
Re: Run used oil
I've got 50 gals of clean used oil waiting for me, just need time to get it and put together a filter system. We'll see how it works. Having a hard time getting waste veg. oil around here, everyone is getting paid for it.
Travis
1997 F-250 HD 4x4/OR SC LB XLT PSD E4OD 3.55LS, TDE1, Baby Swamps (150/146/A), BTS Trans, BTS programming, Front and Rear Replacements, Gooseneck, Autometer Pyro, Trans Temp and Boost in Rockin' S Pod, Cab/Clearance Lights installed, Tymar style intake, 6.0 Intercooler, Tru-Cool Max tranny cooler, Warn Premium Hubs, Shimmed FPR, Gutted EBPV, Super Duty 3" DP, 4" Exhaust, 175,000 mi., 7400 lbs., 310 HP 559 TQ
Truck & Other Pics - More Truck & Other Pics
1968 IH Travelall 4x4
Work truck - 2008 F-350 6.4 PSD XL Crew Cab, Long Bed, Single Wheel, Torqueshift, 3.73LS, 4x4
AggiePSD is offline
Old 06-17-2007, 05:49 AM   #49 (permalink)
Re: Run used oil
ok up date.. its been a while. I have stopped making BIO , just because I don't have the time, but I had about 30 gal of left over WVO and I started dumping my waste motor oil in the drum and when it got full, I filtered it through a toilet paper oil filter into the next drum, then filtered it through a screw on fuel filter rated @ 5-8 microns , then put it in my back tank mixed with diesel at about 30-40 % mix....ever time my main tank got low the trucks tank computer would just refill the main tank till it was all gone. I ran about 50 gal through the truck in February and march ( not that cold I am in south AZ ) , my truck ran fine , no smoking , no hard starts. matter of fact the truck ran great.
chadjones99 is offline
Old 07-14-2007, 02:25 PM   #50 (permalink)
Re: Run used oil
There have been thousands of diesels burnind millions of gallons of waste motor oil for many, many years. If filtered right, no problems,I run 25% to 35% mixture in my 94 IDI , not a problem. Maybe in newer engines more reserch is needed, I dont know. Also, as far as the people claiming the bad efects on the environment, you can buy waste oil burners for your home and shop that are EPA approved. Many buisneses burn waste oil, at open nozzel pressure, in oil burners. The internal combustion diesel engine also adds compression to the mix. I for one dont see an issue with it. Tim
94 Ford F250 4x4 E40D OEM turbo with upgrades
timsmitty is offline
Old 07-16-2007, 07:32 PM   #51 (permalink)
Re: Run used oil
smitty--and the pressure at the nozzle in the waste oil furnaces is a whole lot less than in our idi's!!!!!!!!!--so i wonder which will burn cleaner??????? [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
94_turbo is offline
Old 07-18-2007, 08:33 AM   #52 (permalink)
milner351's Avatar
My Photos: (5)
Re: Run used oil
I have a clean burn brand waste oil furnace in my shop.
I got it used, I think it's a late '80's unit.
It was a bit finicky to get running at first, but once I learned a bit about it's operation and changed a few parts, it's been a great heat source.
I use an old basement fuel oil tank which I fill with used oil atf etc, (no gasoline or paint thinner /etc)
The ignition source is literally an arcing spark across two electrodes about a 1/4" apart, the injector nozzle sprays the pre heated oil into that spark and you get your "torch" flame. The flame is contained inside a basic steel drum heat exchanger which has a big fan next to it.
This unit is old an I'm sure could use a minor overhaul - I can still tune it by adjusting oil and compressed air pressure so that the exhaust coming out my chimney is totally clear and has only the faintest smell of combustion - much cleaner than a wood burner - no smoke and no ash at all.
I can heat my 1500 square foot 12ft tall walled partially insulated pole building from 20F to 70F in about 20 minutes with this 185k btu (max) unit.
I would recomend one of these to anyone that spends time in their shop in the winter. Start telling friends and neighbors you'll take their old oil, they'll be happy to drop it off to you - right now I have more than I need and I'm still collecting for winter!
Belleville, MI (Detroit / Ann Arbor)
'01 F350 cc lwb srw, Rebuilt engine, Rosewood rebuilt injectors, rebuilt turbo, soon to have 3.5"dp and 4" magnaflow exhaust, gauges, etc.
'69 Mustang 428CJ(ongoing project)
'86 Ranger 302/aod/8.8
'02 Focus wagon commuter
'86 Supra classic ski boat 351W PCM power
'54 Belair sedan, all original
milner351 is offline
Old 07-25-2007, 11:39 PM   #53 (permalink)
Re: Run used oil
Here is my experience with used motor oil. 1st time I ever used any I mixed 1 oil change in 25 gal of my 50/50 WVO/diesel mix. About 1/2 of it then went thru a 5 micron water filter into the truck, and the tank was topped off with dino diesel. 1/2 tank later I have 2 junk injectors. Truck has 85,000 on it and I had been running WVO and diesel mixed for quite some time with NO troubles. 1ST time I threw motor oil into the mix I am buying new injectors.
USED MOTOR OIL = EXTREAMLY BAD INDEA IN MY OPENION AFTER THIS EXPERIENCE
marksuttonjr is offline
Old 07-26-2007, 10:31 AM   #54 (permalink)
Send a message via AIM to VD350
Re: Run used oil
mark what is your truck?
I ran probably 30 gal through my tanks this summer with no problems
1986 F-250: 6.9L XL 4x4, 4.10 rear, 4 speed, Wellman GPs, 127,000 and chuggin along like new
1985 Mercedes 300SD: Daily Driver, straight piped
www.Fordemblem.com
My Truck and My Yamaha Tri-Z
VD350 is offline
Old 07-26-2007, 02:04 PM   #55 (permalink)
Re: Run used oil
2001 F250
2001 F250, extended cab, short bed, 7.3, 6 speed,
adjustable 2-18K mod
4" turbo back exhaust
Ford Severe Duty AIS intake with fender sleve
AFE Torque Booster tube
modified IDM
ITP overboost eliminator
Beans Stage 2 split shots
AIH delete
Firestone 5,000lb air bags in the rear
leveling kit up front custom built from OEM Ford springs instead of buying aftermarket stuff
FORD ball joints modified to be greasable instead of using aftermarket stuff
clear turn signals and brake lights
IF YOU ARE GONNA MOD. IT BEFORE 100K DON'T CRY WHEN A REP. FROM FORD OR INTERNATIONAL VOIDS YOUR WARRANTY
Old 07-27-2007, 11:02 PM   #56 (permalink)
Re: Run used oil
Hi. Been a while since I have been on this board.
I will give you my experience (2001 F350).
I have only run UMO (and ATF) with bio. I mixed ~10-15%. (Well settled UMO - I think settling helps a lot). When mixed (straight) it made the bio very dark and dirty. Ran great though, no problems, maybe a little better mileage. Could smell it some.
I also added the oil to the WVO before brewing bio a couple times. The resultant bio much MUCH clearer (although still somewhat darker, you could easily see through a fair amount of it). So (for whatever reason) i think that brewing it with the bio cleaned the UMO up quite a bit. In any case, I did think the bio was a little tougher to wash.
So one time I am driving down the road, and I notice some smoke (a little more than normal), then it got worse, etc. I topped off with diesel, and put some BK 44 (whatever that good stuff for the diesels is anyway). No improvement, and the truck keeps smokeing, gets noisier (almost like it was "nailing" or something. I think (%$^&*), and start "shopping" for new injectors, etc. I keep driving it (a couple/few tanks of diesel. Then the truck starts to "clear up" (smoke/noise, etc.) Then it runs as good as before.
Then I came to the conclusion that that I had used synthetic oil (Rotella from my last oil change etc.). The other stuff I had been builing up for (years...LOL) of non-synth stuff. I used that first because it was well settled.
Well, I used up all my (no snthetic), and I like to run synthtic in the truck and certainly in a VW TDI I pickedup /put together also).
So I have had to further experience except a year and a couple months (about 20K) later, my truck still runs great (bio when temperate, otherwise diesel).
Me personally,, if I used non-synthetic, I would use it up as fuel in my truck). But I would not "seek out UMO". Although I have heard the UMO can lower the gell point of bio significantly.
One lesson for sure: If you do get "ballsy" and try some UMO, DO NOT use synthetic.
A funny postscrip. I friend of mine who had a shop for a while had a UMO heater laughed when he heard this. He said, "I thought everyone knew synthetic motor oil does not burn". (He apparelty got some in his heater and had a time of it....LOL
2001 XLT 4WD Crew Cab Long Bed. 170k - Mostly stock except: In-tank and pre-pump (and harpoon),AIS (zoodad and fender sleve to come soon). DP tuner.
macinco is offline
Old 08-09-2007, 12:17 AM   #57 (permalink)
Re: Run used oil
Sounds like mine, except the fact that the oil I ran was NOT synthetic. It is starting to clear up a bit. I am not driveing it any more than I absolutly have to. Have some of Beans split shot stage 2 injectors ordered. Hope to get them this week, and install them Sat.
modified IDM
AIH delete
Old 08-09-2007, 03:25 PM   #58 (permalink)
spg
Re: Run used oil
In blends of 5 to 15% synthetic Oils and Trans fluid burn just as well as petroleum based oils in my experience
2001 International 4700LP T444E 210HP Fuller Six Speed 3.38
spg is offline
Old 08-11-2007, 05:44 PM   #59 (permalink)
skunk's Avatar
Re: Run used oil
my sig says about my truck. it burns a bit of oil. i may need a ring job or something. burns like a quart a week or so. i drive about 50 miles a day. so if he wants to put some UMO in his tank who cares? i put UMO in my heated WVO tank all the time...
Northern Woodland & Tree Care work trucks:
old smokey
- 86 Ford F250 6.9 IH navistar non-turbo idi diesel 4x4 dana 60 rear w/ limited slip, dana 44 front wishbone style, w/ 3.55 gears, C-6 w/ oil coolers, manual walbro frb-13 fuel pump, manual wellman glow plugs, K&N air filter no soup bowl and a homemade cold air intake, 3 inch pipe, class 31 heavy duty tractor truck batterys, lots of real gauges.
big drippy - 86 Ford F350 4 door crew cab, long box, 7.3 Navistar IDI non-turbo diesel, 2wd Dana 70 dually rear with 4.88, c-6 w/coolers.
The Swan - 87 chipmore wood chipper chuck and duck old school style. vm motori sun 4505 3.9 air cooled non-turbo DI 4 cyl diesel, rockford pto.
skunk is offline
Old 08-11-2007, 09:18 PM   #60 (permalink)
Re: Run used oil
I'm not trying to dis anybody for running UMO. I just stated my experience with it. I guess that I should also meantion the fact that I am seeing this girl with an extreamlt jealous EX. 1 night when I was at her house my truck went from 1/2 tank to full while I was inside. It had a gasoline smell when I drained the tank the next day, but who knows what else was added. That was the tank of fuel before the UMO went in, so maybe my BAD experience had nothing to do with my actual usage of UMO.
modified IDM
AIH delete
