Running LPG and H2O with WVO - Diesel Forum - TheDieselStop.com
Old 06-02-2004, 04:44 PM   #1 (permalink)
My Photos: (22)
Can you? What kind of limitations should I set if I can. I plan on adding one or the other in the future, but want to know if it is as safe to do with WVO as it is with diesel. Also, should I still limit myself at 12-14 psi boost in the IDI?
-Bobby
<font color="blue">True Blue BOOB Man</font>
IDI Help Registry
Lone Star IDI Rally and Events
My Pictures
The Gray Ghost
Manufactured 08/92 F350 N/A CC, 362k Miles, 4x4 w/ E4OD Intstalled, '''Convereted to 6.9L''', 7.3 Maxed IP and 'D' code injectors, Ghost Tube Open Element Filter, Dana 60 pullin' a Sterling 10.25 w/4.10's, 33" Dakota RVT's on American Racing Outlaws, 3.5" w/ Flowmaster 40 series Single Out, Westach Boost and Pyro Gauges, Custom Turbo on the Drawing Board
The Buckin Bronc--'90 Bronco, Eddie Bauer, 302, Auto, Electronic 4wd
"...If wantin' the good life is such a crime, Lord then put me away...", Nothin' But a Good Time - Poison
"It's not a truck, it's a lifestyle."
turbo69 is offline
Old 06-02-2004, 04:47 PM   #2 (permalink)
Re: Running LPG and H2O with WVO
I guess it depends on what the cetane rating of the oil you use is. You may need to advance or retard your timing accordingly.
adding propane to the mix is sure to mess with timing again.
Bio-D has a HIGHER cetane rating, not sure what WVO cetane rating would be tho.
Ford_Forgotton is offline
Old 06-02-2004, 06:46 PM   #3 (permalink)
My Photos: (22)
well, I plan on being able to run the truck on either WVO or D2, depending on the temperature, the length of the trip and the power I need. So, I can not change the timing too much at all, but would like to have the benefit of water or LPG if I need it on both fuels. I am thinking that I should find out how to check the cetane level of my WVO, and use additives and or RUG to bring it to where it is within a point or so of my D2. How bout that?
-Bobby
IDI Help Registry
My Pictures
The Gray Ghost
turbo69 is offline
Old 06-02-2004, 11:08 PM   #4 (permalink)
My Photos: (9)
The compression is kind of high on the IDI's to run much more than this. In fact, if it's a 6.9 block, with 3/8 head bolts, it's probably already too much. Are you running a stud kit, or bolts?
'01 Excursion Limited, 4x4, 7.3L PSD, Oxford White/AZ Beige, Rancho 9000's, Slotted FrozenRotors & Pads, Helwig rear sway bar, AIS, Prodigy, PSD badging, towing a 27' OpenRoad TT
2003 F250SC, 6.0L PSD Pic
'86 F250SC, 6.9IDI, 254,000 miles... SOLD! Truck Pic w/old Camper , Another Pic
rvassar is offline
Old 06-02-2004, 11:10 PM   #5 (permalink)
Well if the timing is only slightly advanced or slightly retarded, it won't cause much problems. I think most veggie oil has a cetane value of around 45-50, if you are running summer #2 with stanadyne or PS, you're probably close to that anyway. By all means find out what your oil's value is if you can and talk to a fuel injection shop about the timing issue. I don't see why water injection or LPG inj. wouldn't work with WVO just as well as with diesel.
J.D.'s Fords: 1986 F-250 6.9 diesel Solid State Glow Plug System 3.55 gears C-6 2WD 178,960 miles.... it still runs pretty good!
Wishlist H-max turbo, T19 tranny,
1989 Ford Ranger ga$$er, non runner, soon to be donated or scrapped!
jdkline is offline
Old 06-03-2004, 08:58 PM   #6 (permalink)
My Photos: (20)
Send a message via ICQ to GraemeDiesel
From what I've read veggie oil burns just slightly hotter that diesel. Therefore water (which has the promary effect of cooling the exhaust temps) should be just fine. Propane should also be ok with WVO, but you might want to be slightly more moderate with it than with diesel. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
2003 F350 SRW Crew Cab 6 liter PSD, Torqushift Transmission, 4x4, 606,000 kms
1996 F250 XL, Powerstroke, Swamp's Baby injectors and TS 3 position chip, Tymar intake and downpipe, 4 inch straightpipe, amsoil engine oil bypass filter, coolant bypass filter, 203 thermostat, chevron synthetic oils front to back, 4x4, 5 Speed, Luk single mass flywheel
382,000 kms
GraemeDiesel is offline
