Running WMO in a 6.4L? Anyone? - Diesel Forum - TheDieselStop.com
Old 01-29-2009, 03:02 PM   #1 (permalink)
are any of you guys running WMO in a 6.4L? What concentration? Whats your filtering process? Can you post pics of your filtering setup?
2008, F-250, FX4, Crew Cab, Short Bed, Oxford White w/ black interior, Dual Alternators, Sat. Navigation & Radio, Overhead DVD System, ESOF, Solid Rear Window, 3.73 Limited Slip, Upfitter Switches, Tow Command System w/ Power Scope Mirrors, Power Seats, and the Reverse Aid Sensor - Edge Insight Monitor, 2.5" Donahoe Racing Lift Kit, Fox 2.0" Piggy-Back Shocks, KMC Beadlocks w/ 35" Toyo M/T's, MBRP DPF back exhaust, Recon mirror lights, Fitch Fuel Catalyst, Randy Ellis Design Light Bar, Line-X, MotoBar, Gentex Temp/Direction Mirror
RRose is offline
Old 02-16-2009, 06:52 PM   #2 (permalink)
I've been told by a very good Ford Fleet Service manager that running anything other then ultra-low sulfur diesel in the 6.4 WILL not might but WILL clog the emissions system. He also went onto say run wmo in a mechanical inj. system. The debate rages on about running in a PS 7.3 most say no in a 6.0 and in a 6.4 no way. Do what you want but in anything newer then a 7.3 no way would I do it.
By the way. I do run it some in my 7.3.
2002 EX 4x2 Amsoil front to back with Amsoil oil bypass filtration, Cyclone Power fan, HX oil line, Dieselsite prepump and tank mods, local high performance transmission, MagHytec pans,MBRP 4" exhaust, AFE Stage II, BD EBV exhaust brake, Bright Box, Diesel Turbo Life Saver, Dieselsite 6pos. chip, Trans, EGT, Pyro and water temp gauges, Dieselsite tranny cooler, Dieselsite 203dg t-stat, Dieselsite AIH plug, rerout ccv, Coolant filter, Firestone Ride Rites, hellwig rear sway bar, Garrett BB turbo. Dieselsite hpop filter, Auto Enginuity program. Dieselsite Adrenaline hpop.
skibarefoot is offline
