Running WVO with just filtering. - Diesel Forum - TheDieselStop.com
Old 06-01-2004, 06:31 PM   #1 (permalink)
After doing a lot of research. It seems we can run filtered WVO without any other mods. (especially in my hot state) they just recomend keeping a filter handy in case you have a problem and changing it evey 10k. Anyone else come to this same conclusion. I am gathering the gear to start picking up oil and give it a try. They have staed that purging is vital to get a good cold start.
http://www.greasecar.com/
04' 6.0 F-250 CC Long Bedwith canopy. 22ft of love.
why73 is offline
Old 06-01-2004, 07:59 PM   #2 (permalink)
My Photos: (24)
Send a message via ICQ to The Warden
Re: Running WVO with just filtering.
I could be wrong, but I seem to remember hearing that WVO being used at a temperature under 160° will not flow properly, possibly clogging the fuel filter early and certainly putting an extra strain on fuel pumps.
However, I believe that a 50/50 diesel/WVO mix can be run in warm weather with no modifications.
[img]/ubbthreads/images/graemlins/smile.gif[/img]
The Warden is offline
Old 06-01-2004, 08:05 PM   #3 (permalink)
I'm not running an exact 50/50 mix of wvo and diesel, but i live in the hot state of FL. Its about 60/40, filtered wvo, i'm using an old whole house waterfilter right now and seems to be working well after i let the oil settle. I also have an electric transfer pump to actually force the oil through the filter to try and get it cleaner, and faster. i also add power service (uggh i forgot which one, its the one in the white bottle not grey). I run that in the front tank. and i run straight diesel in the rear tank if i have a problem. (which i haven't especially in the summer heat). I'm contemplating the idea of getting another inbed tank to hold more veggie oil mix, and let that feed into the front tank, and when i do that i would heat the tank just because i'm going through all the trouble. Again i'd keep the rear for diesel just in case!
Dazed
Patrick
2002 F150 7700 Supercab lifted 6.5in w/ 32V 5.4L swapped in. Powered by Ford and Procharger (2nd "bulletproof" transmission and 3rd rear end, getting another motor)
1991 F350 Crew Cab dually 2wd ZF5 and missing 2 cylinders. (RIP thanks to a Suburu)
DazedNConfuzedV8 is offline
Old 06-01-2004, 08:06 PM   #4 (permalink)
The Direct Injection motors are a big Question Mark right now. However the IDI guys claim no problems with running stright WVO.
I believe there is a sponsor on this site who has offered to do a complete injector check for free for someone who runs WVO on their DI motor for an extended period.
The fear is that the DI motors arnt quite hot enough to burn the fuel correctly or something. The risk is coking the injectors and ring stick if you dont get a complete burn.
Ford_Forgotton is offline
Old 06-01-2004, 08:11 PM   #5 (permalink)
My Photos: (24)
What's the operating temperature on the PSD?
Assuming it's anywhere near the 190° that the IDI's run at, and that the fuel's being burned completely (which I would assume it is, unless you've heavily overfueled the truck), I have difficulty envisioning a problem...but I don't claim to know much about the PSD's either. [img]/ubbthreads/images/graemlins/smile.gif[/img]
Old 06-01-2004, 08:23 PM   #6 (permalink)
well, the motors both run 190-203 (if you have a 203 psd special thermistat), but its how the fuel is ignited.
The PSD injects all of the fuel directly into the cylinder (all at once, or split-shot depending on injector type). However the IDI engines inject into a pre combustion chamber before the full load is injected. This allows for the fuel load to be fired into an already lit chamber. The tolerance on the injector are lower also I believe.
Everything I have read about WVO is the IDI is fine, but everyone's skiddish to run it too strong on a DI motor.
Old 06-01-2004, 08:28 PM   #7 (permalink)
I guess I'll run a blend first and see how it goes.
why73 is offline
Old 06-01-2004, 08:42 PM   #8 (permalink)
was speaking to land yacht about this--the only problem with the idi's is you may start to burn the gps off slowly--which i did at first--but he said to keep the timing down--second-he said you wont burn the gps in a psd as the position of them in the fire chamber is different--so i say the psd is a good candidate--but the only problem is is that the fuel rail is dead end--how to get the wvo out of the fuel rail prior to shutdown--never thought of that, right??? but someone awhile back made a system so the fuel wont dead head---didnt the later psd's have continuous flow rails--with hoses at each end????? and with bio in the psd--nooo problem---
94_turbo is offline
Old 06-01-2004, 09:09 PM   #9 (permalink)
My Photos: (6)
Here is a great link about this. Linky
Apparently, DI engines tend to get the SVO on the cylinder walls, and IDI engines dont do that as much.
Diesels:
Duramax, ZF-6, CAT 2, B50++
VW TDI 5 speed, 50 MPG
Kubota L4300 DT, custom pintle type hitch on box, avocado hauler
83 Volvo 244 GL, 2.4L NA, Diesel, Manual, 140k+, For sale!
biodiesel from leoco.com
What Would Reagan Do?
mannytranny is offline
Old 06-02-2004, 09:49 AM   #10 (permalink)
There was a news story in the LA Times about a SoCal restraunt owner that put a Gresiel set up in a new PSD Excusion. He had it great, all the oil he could use. I belive the issue with the PSD is the viscosity of the oil, thats why you must heat the oil. IDI not so critical but most always deal with the it by heat or thining.
Just my .02, Don
PS this is a great site http://biodiesel.infopop.cc/6/ubb.x?...mp;s=447609751
The SVO guys know their stuff
84 6.9 250 xtra cab XLT/ 85 Banks
83 240D stick (sons,Kathern)
91 Accura GS (Go girl's)
00 Oddy (Moms)
Artic Tern
Standard Guilimont (mine)
Red healer Aussy Cattle dog,Murfy
One Mutant cat,r.i.p Tasha
2beeone is offline
Old 06-02-2004, 11:48 AM   #11 (permalink)
That would be SWAMP DONKEY.
MY TRUCKS
1996 PSD F-350 crew cab 4x4, AB CODE CALIFORNIA TRUCK, 5 speed,CON-O SMFW modified by Southbend Clutch, ORU Reverse Shackle kit, 4:10, u.s. gear chip, IDM MOD BY ME , down pipe, 4 inch straight pipe, boost and EGT gauges,PRO COMP A/T's 305-70's, Bilstein's, ditched the k&n filter for an open element Baldwin PA 2818, kenwood & polk audio sound system.
2002 Excursion PSD 4x4 XLT Premium- BB Turbo , 6.0 IC, 8 inch Sky Jacker lift, FOX shocks with remotes, 35-12.50R17 BFG Muds mounted on 17x10 Boyd Coddington Billet wheels, ORU Frozen rotors, custom hybrid intake, DVD/2 monitors, Billet grill, XM radio, DP Tuner
SOUTHERN CALIFORNIA POWERSTROKES MEMBER
mattymx is offline
