I already have two tanks so I want to add a second/separate fuel filter.
I'm leaning towards WMO for now and was wondering if this filter will work. Perma-Cool Fuel Filter and Water Separator.
It's abut the least expensive I've seen.
I do plan to pre-filter before putting anything in the tanks.
Also, in the stock configuration, the fuel pump pushes the fuel through the filter and then to the IP.
Will it create a problem if I move the filters before the fuel pump so that the fuel is pulled through them?
I have the same question rather than an answer. I am in the same position, relatively, and wonder what rules there might be as far as pulling or pushing fuel. There are some threads that I remember reading, so if and when I see them i will connect you. Thanks to anyone with the answer.
sam
__________________ 1996 PSD 2WD Auto, 190,000 miles
203 TStat, Napa 6637 open air filter
High Torque starter, Bilsteins, Toyo A/Ts, DIY electric fuel
I *think* what I did with mine was pre-fill my pre-pump filter than did the "turn the key for 30 seconds" bit three or so times.
When we installed the ITP pre-pump filter on my friend's 2001, we just cycled the key about a half dozen times until we saw the fuel pressure gauge respond (he had the ITP regulated return system with fuel gauge).
I recently added a pre-pump fuel filter to my 02 7.3 and the unit I found allows me to select elements from 2, 10, or 30 micron ratings in 45, 60, 90, or 120 G.P.H. flow rates. The other features I liked about this filter head was that it has a built-in primer pump with a bleed valve on the top. Should I ever add a second fuel tank, it also has two inlet / outlet ports so I will be able to plumb both tanks into one pre-pump filter. I used 3/8” fuel injection hose with a “J30R9” rating which is designed to hold up very well with diesel / bio-diesel.
One thing, if you add the second tank so that you can use wvo or wmo, you'll want a separate filter for each tank.
Otherwise you'd have very long purge times when switching back to diesel.
longwolf,
I was able to buy the complete filter assembly for $85.00.
Thanks for the heads-up on the purge time required before shut down after switching to back to diesel. I agree with you, two filters would be the way go unless you are going to run diesel in both tanks.
