shortening ?? - Diesel Forum - TheDieselStop.com
Old 08-27-2008, 02:55 PM   #1 (permalink)
shortening ??
having trouble getting grease now with all the recyclers paying it. i have a line on getting some shortening from a donut shop (he gets this stuff in a 50 lb block from his supplier). i was wondering if it is ok to use to make bio with the methanol and lye combo? and if so once it is made will it loose the geling characteristic or will i just have to mix some regular diesel with it after processing when i put it in my truck. just wondering if anyone has had bad bad luck using this.
2000 excursion superchips progamer,(ole ladies ride) no fuel milage increase but the power is there.
2000 f250 4x4,hypertech tuner ,no kitty,4in exhaust turbo back , air raid filter
97 f350 psd, c/c, 4x4,3.55ls, 285/75 goodyear MT/R's
shimmed w/ calif. kit, 10k mod, ported snorkel,hypermax downpipe,ps2000 propane
45hp superchip,pcm code TDE1, TEXAS TROPHY HUNTERS decal!!
looking for hunting opportunities in the north mississippi area or s/w tennessee, deer and hogs , let the littles ones walk
missplaced texan is offline
Old 10-14-2008, 10:21 PM   #2 (permalink)
Shortening
I have had very good results from shortening and lard. Both are of a soft white creamy consistancy but they are also unused. I just made a 128L batch using 22 liters of methanol and 730 grams of KOH. After running through some puralite beads it looks like water. Have made probably over 500 gallons with no problems as of yet. A little trickier to deal with since its a solid, I use the good ole texas sun to melt it while still in the buckets.
2000 F250 4x4 standard 6 speed, Superchips programmer, southbend clutch
rkonvicka is offline
