Signs of injector coking? - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 12-03-2005, 04:26 PM Thread Starter
My Photos: (6)
What are signs of injector coking? I've noticed my truck idles fine at first but once warm has a bit of a rough idle. I crank up the 18k mod knobs just a bit and it smooths out while increasing the idle to 750rpm, rather than the stock 650/675rpm.
I do not detect any miss under accelleration. The truck runs great except for a slightly rough idle. I doesn't ever die, just a little rough.
I have yet to run any biodiesel and hope this will clear it up. I'll try some more Power Service.
We haven't had any really cold weather yet... some mornings at freezing but mostly 40's to 60's. Right now its 82 degrees!
Todd
ToddT is offline
post #2 of 4 (permalink) Old 12-03-2005, 04:29 PM
My Photos: (6)
Re: Signs of injector coking?
Not sure exactly, but I hope it shows up before messing something up inside the chamber.
Get those EGT's up to 1300......seems like that would help. Not sure, but I try it anyway. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
Diesels:
Duramax, ZF-6, CAT 2, B50++
VW TDI 5 speed, 50 MPG
Kubota L4300 DT, custom pintle type hitch on box, avocado hauler
83 Volvo 244 GL, 2.4L NA, Diesel, Manual, 140k+, For sale!
biodiesel from leoco.com
What Would Reagan Do?
mannytranny is offline
post #3 of 4 (permalink) Old 12-03-2005, 06:28 PM
My Photos: (13)
If you want to give injectors a good cleaning try a couple of cans of diesel purge, it's a bit more of a pain to use, but does a great job.
-------Robert
'92 F-350 Crew Cab dually,7.3 5 spd+ 3 speed Spicer 5831 Brownie, Solid Flywheel w 12 1/4" Kevlar Clutch, ATS turbo, Hypermax Cowl induction, MS Tech Fan Clutch, Custom Aluminum Rodney Red Radiator, 4" Exhaust, Air seat, Western Hauler bed.
RLDSL is offline
post #4 of 4 (permalink) Old 12-03-2005, 06:51 PM
Spencnaz's Avatar
My Photos: (14)
In my experience the only way to make sure of injector coking is to pull the injectors.
On the 6.9 this is pretty straight forward, but on the newer Powerstrokes it would I think be a real hassle.
A very detectable miss in the engine would a sure sign that an injector was either plugged of blocked.
Try the simplest solution first, the liquid cleaning agents for diesels are very good at removing deposits.
The Green Monster
: 2001 F250 Powerstroke, 2WD, ZF6 transmission. Bully Dog GT Tuner set in tow mode. MotorSilk boric oxide added to engine, transmission and diff. Showing 30mpg on the freeway running home brew biodiesel. NTZ 1/2 Micron bypass oil filter. Dieselsite coolant filter. 4" open turbo back exhaust. Ford AIS intake. Donaldson ELF7405 oil filter. Caterpillar ELC next on the list.
Spencnaz is offline
  Diesel Forum - TheDieselStop.com > Other Topics > Bio-Diesel and Alternative Fuels
