Go Back   Diesel Forum - The Diesel Stop.com > Other Topics > Bio-Diesel and Alternative Fuels
Old 09-05-2008, 01:40 PM   #16 (permalink)
My Photos: (6)
amco22
i uploaded some picts to my profile. check em out.
05 6.0 F 250 fresh air intake home-brew biodiesel HHo generator 24.8 mpg hwy. 17.1 mpg w/30ft 5thwheel .Say it doesn't work!!!
bioman23 is offline
Old 11-10-2008, 07:07 AM   #17 (permalink)
I have been experimenting with HHO. built units with wire spirals mounted on persplex frame.
Fitted to independant persons vehicle for testes.He was a nayer.
Six diesel tank s full three with and three without over 3,000 Km and his assesment was approx 10 % saving.
Downside the wire was eaten away. But he still wants a unit.
Now building up a tube in a tube unit bigger and more surface area.
We will soon have the results of this unit.
Have a wire unit fitted to the "F" and also a Ford trader truck on 2/1 mix diesel and WMO.
No figures on these units as not suitable usage for recording.
The old nayer you dont get anything for nothing is right
But if you use x units of power to produce xx units of power adding the power of hydrogen you get a net increase.
More experimenting required when time allows.
Regards
Ron
2000 F350 king cab 4x4,No engine mods,Roo Bar,Headlight and bonnet stone protectors,Inlet snorkel,flares on front,Engine driven air compressor and receiver,Hot water tap,tyre temp and pressure monitor,95 ltr fuel tank under right hand side,aluninium side steps,flat trayback,50ltr water tank under left hand side,heavy wired front and back for 4500lb electric winch, Bilnstien shocks,converted to right hand drive,battery conditioner,electric trailer brakes,heavy duty tow bar,synthetic oil in tranny,extra tranny coolerand filter ,tranny temp & pyro,
Ride-Rite airbags all round.Full flow muffler outlet at rear of vehicle.Engine breather mod.HHO generator
knapp is offline
Old 03-06-2009, 09:45 PM   #18 (permalink)
I am in the process of building a smacks booster I was wandering what some results were thanks for the info!!!
TN Diesel is offline
Old 03-08-2009, 05:58 AM   #19 (permalink)
Before this thread gets out of control in a heated debate about physics and scientific principals, I wanted to bring up an idea that no one has ever suggested before in any of these threads.
I realize that it takes energy from the alternator to provide the power for the generator to produce hydrogen... but hydrogen is just a supplementary fuel. As I know it these PSD's can be pretty inefficient with the amount of wasted fuel they just spit down the tailpipe. From what I gather, it seems like some additional combustion in the chamber due to hydrogen would have a very similar effect to something like propane injection which is commonly regarded as a power and mileage booster. They just burn the excess fuel in combustion chamber, and that makes more power and therefore can increase mileage.
Any thoughts on this?
1996 E350 Club Wagon XLT 12 passenger, 7.3 PSD, 3.55 rear, K&N air, Eagle Alloys, Super Duty Telescoping Tow Mirrors, Fumoto Oil Drainvalve, TomTom Go720 GPS; otherwise dead stock. 236,000+ miles. - RIP
1983 Mercedes 300SD - 535,000+ KM's
RockinOnDiesel is offline
Old 03-08-2009, 08:14 AM   #20 (permalink)
Mark Kovalsky's Avatar
No, no thoughts on your idea. It would take a heated discussion on physics and chemistry, and that's been done to death.
But since we all know the PSD is so inefficient that it just spits raw fuel down the tailpipe, and we all know because of this a PSD will get worse fuel economy than a highly efficient V10 gas engine, this must be the new breakthrough the world is waiting for.
Mark
Mark Kovalsky is offline
Old 03-08-2009, 09:57 AM   #21 (permalink)
Originally Posted by RockinOnDiesel View Post
... wasted fuel they just spit down the tailpipe.
Also known as "white smoke" when fuel doesn't ignite at all and "black smoke" when fuel burns incompletely. Got any of that?
Douglas Campbell
November 5, 2008: The fat lady sang. Back to actually working for a living.
1986 Isuzu P'up, 177,673.8 miles. Hella headlights, (highly recommended) DOT C-2 back end. (also recommended) R-12 air conditioner converted to R-406a. 4.1:1 rear axle converted to 3.4:1.
9/22/2007, age 21: Still running well when reluctantly sent away for reincarnation due to rust.
Not affiliated with the Campbell Soup Company.
drcampbell is offline
Old 03-08-2009, 11:14 AM   #22 (permalink)
Super_Dave's Avatar
Exactly. How much should be expected from so much inefficiency? I don't see where hydrogen generation/injection is removing friction or heat and putting that into locomotion and efficiency. The amount of "wasted fuel put down the tail pipe" is how much? Simple science has numbers on that.
Super Dave
2003 Excursion Limited 4WD 7.3PSD - Prodigy brake controller, DP Tuner-60t/80e/AIC/exhaust brake, BG drive line fluids, Timbrin front & rear springs, 203* Tstat, Evans NPG+, coolant filter, Ford Transmission Cure
2007 Buell XB12R Road Racer
Super_Dave is offline
Old 03-09-2009, 01:36 PM   #23 (permalink)
soupdog's Avatar
i made some and put three on my lil 82 s10 ,,,worked good,,,and put two on my 91 f250,,,don't know bout mileage claims cuz my gauge don't work but it holds cruise on the hills now and has more power,,,am a believer,,,have a new one i am gonna put on when it gets a lil warmer, its made out of a water filter housing,,,will see then
91 f250 4x4,, e rated tires,,cab lights,,,straitpiped to rear,,,,brand spankin new cd player,,,flatbed with gooseneck,,,one hellava bale hauler,,,
International 856 wide front and a super h wide front ,, both have three points for haulin those bales.
63 w200 power wagon 17.5 inch e rated tires,,4 spd, 410's plus a six popper, she's a lil slow but she'll go anywhere yu point her
New to fleet 95 dodge 3500 EXT CAB 4x4 5 spd cummins power, 4 inch exhaust,
soupdog is offline
Old 03-10-2009, 12:01 PM   #24 (permalink)
Originally Posted by Super_Dave View Post
... The amount of "wasted fuel put down the tail pipe" is how much?
The unburned hydrocarbon content of a modern engine's exhaust gas, before aftertreatment, is typically less than 0.1% (1,000 parts per million) unless the engine's misfiring. The instruments we use to measure it only range up to 1%. (10,000 parts per million)
Even if you included the soot content of a Diesel engine running on the verge of overfueling, you'd still be under 1%.
Douglas Campbell
Old 06-04-2009, 07:11 PM   #25 (permalink)
HHO testing
Originally Posted by MarkEkberg View Post
Reading the ad's is fun to do with the claims they make for increased mpg's.
Working at the bottom of their claims I would take two years to break even.
Anyone else out there have one?
In a responce to your question I have been testing HHO on big trucks for the past two years and I have found out some really cool things. One 99.9 percent of the cells designs out there would not last over a month on a big truck, talking over the road trucks here. The cells turn to rust and over amp, I use my own design and I have been running 4 units on test trucks for the past 4 months straight the water inside of the cells is still clear as the day I started running them. In responce to your testing question I am seeing great repeatable results on all of my test trucks.
I have just made a deal with Stewart & Stevenson to give my units an offical test. we are going to pull the computer data from the Detroit engine before we install the cell and pull the data again after 30 days. The truck will be on a dedicated run from Denver co to Rock Springs WY it makes the run 5 days a week with the mail. This will answer once an for all if HHO works. I am also in contact with the Cummins rep, wish HHO luck.
hydrocolorado is offline
Old 06-04-2009, 08:18 PM   #26 (permalink)
Super_Dave's Avatar
Originally Posted by hydrocolorado View Post
...I have been testing HHO on big trucks for the past two years...
So, what do your logs say?
Super Dave
Old 06-04-2009, 10:17 PM   #27 (permalink)
I have posted my own owner operator results on my testing page on www.hydrocolorado. com
I will be installing the on the Detroit test truck June 17th 2009
