Starting to build the 2 tank system. - Diesel Forum - TheDieselStop.com
Old 03-19-2012, 08:30 AM   #1 (permalink)
JR3342's Avatar
Got the first piece built last night. Rolled 18 ft. 5/8" copper tubing around cat 1r0749 for a gc. Style filter heater. Filled the tube with salt to prevent kinks. Still needs fittings for heater hoses and brackets mounted. Should make a lot of heat.
Sent from my DROID BIONIC using AutoGuide.com App
Starting to build the 2 tank system.-uploadfromtaptalk1332163843030.jpg   Starting to build the 2 tank system.-uploadfromtaptalk1332163859233.jpg
99 f250 4Dr short box 7.3 auto 4x2, euro headlights. Diy 6637. 203 thermostat and billet housing. Diy wvo conversion.
92 Mercedes greasecar wvo kit,autometer gauges.
JR3342 is offline   Reply With Quote
Old 03-19-2012, 10:41 AM   #2 (permalink)
airfooter's Avatar
Oh yeah, that'll get HOT. I used compression to NPT and NPT to 5/8" hose barbs to get from tubing to heater hose. Also consider some kind of 'blanket' to mitigate heat loss from the 80mph air rushing past the filter. I had a modified soft-sided cooler I used over my VO filter with a coolant wrap like yours. (I only use 3/8" tubing though!! )
I also recommend an aux coolant pump. These are about $60 and will improve the coolant flow thru the aux fuel system loop. We typically tee into the heater core supply and return for coolant - and I recommend adding a valve on the heater core supply, so you can turn it OFF in summer. This will give you colder A/C and also more flow thru the new loop.
Have you considered tube-in-hose heated fuel lines? We run 3/8" alum fuel line inside 3/4" heater hose using 1/2" brass or black iron tee's at the ends. You have to drill out the stops in compression adapters so the tubing will slide all the way thru the tee into the heater hose. Heater hose is about $1.25/ft, alum tubing is about $1/ft and the ends can be made for $6ea. This is cheaper than 30R9 and most other 'hoses' rated for bio-d and the pressures we need in a PSD.
Choose wisely. Or PLEASE post pics of the carnage!!!
2001 F-350, DRW, 4x4, XLT Crew Cab, flat bed, 7.3, 6 spd, Dipricol Optix gauges on pillar - EGT, Boost, Fuel Press., HPO Press. - No Muffler, AIH delete, SB Con OFE, AC code injctrs, GTP 38R. Vegistroke-inspired WVO system w/170,000 trouble-free miles! BTS tunes, 203 t-stat w/billet housing, Evans coolant, coolant filter, boost relief valve, Dieselsite IC boots, Hella headlight harness, '07 grill/lites and big, bad front bumper!
2000 Excursion 4x4 Limited - BTS trans and tunes, AIS, Frybrid/V3 SVO conversion with over 100k VO miles so far!
That's 270k miles on SVO between them!
airfooter is offline   Reply With Quote
Old 03-19-2012, 12:10 PM   #3 (permalink)
X2 to everything Jason said. HIH gives you the best heat transfer.
Nice heater wrap by the way.
2001 F-350 Nondually. 192K miles. Pretty much stock. DIY SVO Vegistroke style 2 tank conversion April 2010. 70K miles On Vegi!!
simone0414 is offline   Reply With Quote
Old 03-19-2012, 06:06 PM   #4 (permalink)
JR3342's Avatar
It's getting it all . Tih, mb coolant pump, wvo designs pump and heated pu. Going to wrap the coil in black rubber then large exhaust band clamp w/mnt bracket. The tank , pump , filter, coolant filter are all going into a tool box. Fphe only thing going under hood. Hunting cragis list for deep tool box now. Getting many parts from local / craigs / Ebay to keep cost down and do a quality system at a good price. Had the copper tube already plus the rubber and clamps. Total into filter wrap is $.68 in salt. Beats $300 for a gc with generic filter. Got about 75 of the cats in the shed won't be buying any filters fot a few years.
Old 04-06-2012, 08:07 PM   #5 (permalink)
JR3342's Avatar
Just got the tool box $75 off craigs. And a aluminum tank that fits good in the box $100 with shipping off ebay. Staying way under budget. More pics soon.
Old 05-28-2012, 05:29 PM   #6 (permalink)
JR3342's Avatar
Recent progress.
The tool box everything goes into.
The recycled fuel tank from a boat.
The tank heater 5/8 alum tube hand rolled.
The filter. Insulated, painted and ready to install.
And a fuel cart I made to quit carrying jugs to the driveway.
More pics soon.
Old 05-31-2012, 08:56 PM   #7 (permalink)
Keep the info coming JR. Good work.
Jerry
2000 F250 Superduty 180K and counting 4X4 4R100 Glow Shift gauge - EGT - Boost - Tranny Temp Fuel Pressure on an A pillar mount Diesel Site boots Transgo shift kit K & N Stage II air filter 5" exhaust RiffRaff AIH to boost mod CCV mod DP-Tuner with W85 settings Amsoil Bypass oil filter 6.0 tranny cooler, W80, Cooling Mist water injection.
F250Truckin is offline   Reply With Quote
Old 06-11-2012, 11:05 PM   #8 (permalink)
JR3342's Avatar
Tank is cut. And heater installed.
Old 06-12-2012, 08:36 AM   #9 (permalink)
Beautiful work. I like your workshop. Looks real comfy.
Jerry
Old 06-12-2012, 10:35 AM   #10 (permalink)
JR3342's Avatar
The other side of the deck goes into the pool. In case it gets to hot working.
Also got the 53 ft step deck for a jumbo work bench.
Old 06-14-2012, 07:03 PM   #11 (permalink)
JR3342's Avatar
Hatch installed. Pu tube in place.Starting to build the 2 tank system.-uploadfromtaptalk1339718530082.jpg
Tube in hose fittings ready to go.
Old 06-15-2012, 10:30 AM   #12 (permalink)
airfooter's Avatar
You need to secure that tubing in the tank. Just the wave motion will kill it eventually, but design it with a root beer float in mind. A chunk of semi-solid oil floating around in your tank (cold weather) is alot like a wrecking ball.
Either do a big baffle around the tubing like a Frybrid in-tank HE or build a cage that tacks to the tank bottom - just keep that stuff from being able to move around or you'll wind up with coolant in your fuel!
I would consider a baffle in the tank that your set-up drops into. Put some 3/4" dia. holes a few inches off the bottom and only have a couple 3/8" holes AT the bottom and put them on the front (of truck) part of the baffle. This way, when tank is low and ya go up a hill or around the corner - all the oil won't run away from the pick-up. Oh, and make sure pick-up is as close to the bottom as possible, but keep in mind the tank will change shape a little with temp swings and load.
Old 06-15-2012, 02:01 PM   #13 (permalink)
JR3342's Avatar
Ill have to see what I can come up with. Alum scarce around here. Luckily it never gets cold enough here for solid oil.
Old 09-22-2012, 02:12 PM   #14 (permalink)
JR3342's Avatar
Progress update.
Heres what I've done so far today.
Starting to build the 2 tank system.-uploadfromtaptalk1348341016618.jpgStarting to build the 2 tank system.-uploadfromtaptalk1348341031359.jpg more pics later today.
1999 f250 7.3 4x2. Diy 6637, diy wvo conversion underway.
Old 09-22-2012, 05:03 PM   #15 (permalink)
JR3342's Avatar
Plumbing done. Wiring next , then top of engine work.
I call it the spaghetti bowl.
