step by step biodiesel processor build?? - Diesel Forum - TheDieselStop.com
Old 09-07-2007, 03:01 AM   #1 (permalink)
Cjhstang's Avatar
Well, i'm another new guy to this part of the site.
I've been looking into all these alternate fuels for my truck for a while now, n biodiesel has really caught my eye. I've learned alot from the journeytoforever.org site but i'm looking for a step by step process on building a biodiesel processor...without spending $2k+ for a pre built one.
pictures and layouts are always helpful too.
Thanks all...
7.3 IDI F-350 4x4 1990 150k miles
-Custom: '92 interior; '04 Hydroboost brake system; Volt/Temp/Oil Pressure/Oil temp/Trans temp/Boost/Pyro meters; Banks Sidewinder Turbo into 4" glasspack and dual 4.25" Stacks
-Reman'd: Heavy Duty E4OD and Billet Converter; Transfer Case; Water pump; Power Steering pump; Steering Box; Denso Starter
-New: Brakes; Engine seals and oil pan; Oil pump; RUST-FREE Cab and Bed
-Pro Comp "Holley Red style" electric fuel pump
-Dual 30micron to 2micron filter system... WMO WATF! Free Fuel!!
-3" Body Lift
-Fresh under coating on frame No more face full of rust under the truck!!
-16x10 Eagle Alloy 186 with 33's
-8ft snow plow
4.6l Mustang GT 1997 115K miles
GOTTA LOVE FORD MUSCLE
Cjhstang is offline
Old 09-07-2007, 05:32 PM   #2 (permalink)
Send a message via AIM to VD350
Re: step by step biodiesel processor build??
Basically you have a 55gal barrel with a cone on the bottom, a pipe line that connects to the cone and goes back to the top, with a pump somewhere along the line. and where it goes back to the top of the barrel you need another outlet so you can transfer the bio to your drying tank or another barrel for that matter. You'll also notice that we put a section o<span style='font-size: 8pt'>[/size]f pipe straight down from the main line (below the cone), remember you need a way to drain off the glycerin.
<u>Directions</u>
<u>Buy a sheet of thick plywood</u> (to place the barrel on)
<u>8 2"x4" pieces of wood to build a stand for the processor</u>(length will be determined when you get your plywood)
<u>Next cut the top and bottom out of a 55 gal barrel</u>
<u>Now cut two holes near the bottom of the barrel to weld in your nipples for the heating elements</u>
<u>Weld the nipples in</u>
<u>Now make a circle out of sheet metal</u> (needs to be much bigger than the barrel mouth)
<u>Cut a hole in the center of the barrel</u> (for the Nipple that goes to the pipeline)
<u>Now cut from that hole to the out side of the circle and over lap the metal on itself</u> (elementary shapes, a circle will make a cone).
<u>Weld the actual cone itself so it is water tight</u>
<u>Weld the nipple to the bottom of the cone</u>
<u>Now weld the cone to the barrel</u>
<u>Next Cut a hole in the plywood base</u> you built so it is just smaller than the circumference of the barrel
<u>Now you pipe it</u>, look at my pics and see where your shut offs should be
<u>Finally use common sense</u> </span>when piping the barrel up.
Pics of our setup
http://s46.photobucket.com/albums/f1.../Bio%20Diesel/
Ended up costing around $100 because we already had the piping, barrels, heating elements, and our buddy tig welded our stainless steel tank for free to put the stainless nipples in. We just had to purchase the pump and the shutoffs.
http://www.B100supply.com has everything you need.
Your hand pump for the methanol
https://www.b100supply.com/ProductDe...roductCode=217
And this is THE pump to use, we bought a different one and it didnt work at all.
https://www.b100supply.com/ProductDe...roductCode=107
1986 F-250: 6.9L XL 4x4, 4.10 rear, 4 speed, Wellman GPs, 127,000 and chuggin along like new
1985 Mercedes 300SD: Daily Driver, straight piped
www.Fordemblem.com
My Truck and My Yamaha Tri-Z
VD350 is offline
Old 09-08-2007, 12:48 AM   #3 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Cjhstang</div><div class="ubbcode-body">Well, i'm another new guy to this part of the site.
I've been looking into all these alternate fuels for my truck for a while now, n biodiesel has really caught my eye. I've learned alot from the journeytoforever.org site </div></div>
Do yourself a favor and let your previous visit to JTF be your last. Much of the information there is flawed. The Foolproof method is better called the Fools method, because it does not work.
If you want to learn about Bio Diesel processing go to http://www.biodieselcommunity.org/ and learn the right ways to do things.
Then come back here and ask away.
Norman
97 F250 CC PS Tymar intake, 3" downpipe, 4" exhaust, turbo muffler installed backwards, 299,000 miles, running B100 when possible. "NEW 90 F450
StorminNorman is offline
Old 09-08-2007, 12:52 AM   #4 (permalink)
Cjhstang's Avatar
yeah, i wasn't particularly thrilled with their setups and info, some was a little cloudy info.
Thanks for the step by step... thats what i was really hoping for...
-3" Body Lift
-8ft snow plow
Cjhstang is offline
Old 09-08-2007, 12:32 PM   #5 (permalink)
So you're asking where to find the best biodiesel processor plans?
Hmmm.. I might be able to think of a website or two... LOL
Seriously.. Some great links to start off from are posted above.
I did send you a PM. not sure if you got it.
Murphy2000 is offline
Old 09-08-2007, 10:17 PM   #6 (permalink)
Cjhstang's Avatar
yeah, just checked out the pm. nice site, thanks alot!
-3" Body Lift
-8ft snow plow
Cjhstang is offline
