Straight Vegetable Oil in a 6.9 - Diesel Forum - TheDieselStop.com
Old 12-18-2005, 08:46 PM   #1 (permalink)
I found a source for virgin vegetable oil for $1.00 per gallon. I live in central Arkansas where the nights seldom get below 20 degrees F in winter and the days are almost always above 40 degrees except for a cold spell or two. I would like to try running the SVO mixed with pump diesel at a ratio of 50/50. Do I need a fuel heater/warmer? IF so, can I make one? If not- which do you recommend to buy? I will put the 50/50 mix in one tank only perserving my other tank for pump diesel for starting and running a few seconds before I kill the engine. Do you think this is feasable or should I wait for warmer weather to try it? It will be 30 degrees tonight and a high of 49 tomorrow.
Central Arkansas- Just bought my first diesel- an 84 F250 4X4 with 6.9L automatic trans. 355 gears-225,000 mi. Gets 16.6 mpg
New starter,radiator,steering parts,rear-end,ATS turbo,just put in a ring gear on flywheel..
Cogburn is offline
Old 12-22-2005, 12:00 AM   #2 (permalink)
Re: Straight Vegetable Oil in a 6.9
I live in Alaska and I was running 30% veg until it got to 45-50 degrees and then it didn't like stating in the morning without being plugged in. I would onlu recommend it for summer time as I have heard of problems coking(the brownish black stuff you can never clean off of the bottom of your frying pan) up the injectors. Just a thought. Also you can safely run 20% biodiesl with #1 diesel down to 0 degrees. Hope it helps.
Sold it!!! 1993 F350 rebuilt 7.3IDI Turbo Crewcab running 4.10 and 35x12.50x16. Who needs mufflers... straight pipin' with banks downpipe upgrade and 3 in exhaust all the way back and gettin 18mpg if my foot wan't so dang heavy. Biodiesel home brewer and convertion to WVO almost ready for install. Electric Facet fuel pump conversion.
2006 Dodge 2500 Megacab Cummins...stock...for now..hehehe
ak_cowboy is offline
