Re: A strange crust developed on my heating elements
I looked at a few elements the other day at Orchard Supply Hardware, most of the ones I looked at were zink plated, that may be the crust your seeing as the methoxide is going to chew the hell out of it.
I did manage to find a 3800 watt stainless steel one made by Kenmoore, can't recall the part number off hand but I still have it if need be. It was $17 and the others were around $7.
95" Extd Cab F250HD 4x4 DRW, /86"6.9 T19 GV o/d 3.73 axles, Hypermax Pulse turbo, intercooled / Modified Hypermax ram air induction, PowerShot 2000 LPG system "first design". Ride rites @ all 4 corners, Dana 50 mono Beam up front, Ford 10.5" in rear with 4 wheel disk brakes. Other Truck, 1983 IHC "S" with 14ton NoMar wrecker body, 30,000 GVW, 229"wb with a 340hp Detroit 6V92TA, Eaton 13spd RTO9513, 3.70 ring & pinion and LPG kit. Alcoa 22.5x8.25 with Michelin XVE 255x70x22.5
