Super Sucker Help - Diesel Forum - TheDieselStop.com
Old 06-11-2008, 10:03 PM   #1 (permalink)
jposes's Avatar
Super Sucker Help
Ok so I came across a water tank that I hope will work for my Super Sucker setup. It is the bladder type though so I am not sure it will work? It has a valve stem at the top of the tank (the type you would find on a tire) and a 1" or maybe 3/4" pipe fitting coming out of the bottom. My question is do I need to remove the bladder and if so how? Also not sure how to go about connecting my vacuum pump....Do I try the area where the valve stem is or should I leave that alone? Seems like that would be a spot to add pressure to empty the tank out. I have a much larger propane tank I would like to set up eventually but I will need a trailer to haul it around. This tank looks to be about 80 gallons or so, so if it will work it will get me started.
Black 2002 F350 XLT 4x4 Crew Cab 7.3L (build date 11-01) - Goodyear Wrangler Duratrac 325/65/R18 mounted on KMC XD Monster 18x9 Wheels, 4 inch ProComp Lift w/ dual front shocks, Ranch Hand-Full replacement front/rear bumpers, Leer Camper Shell Autometer Triple guage pillar pod with Autometer Sport Comp Pyro and boost gages, Autometer Ultra lite digital Trans temp gage, DP Tuner (60hp econo, 60hp tow, 100 hp performance) w/ in dash mounted ex switcher, AIS, Bosch Alternator, Viper 3000 alarm, NFab Nerf bars
Cosmetic upgrades: 2010 Tailgate, 2011 power folding/telescoping towing mirrors,
In the works: 2009 FX4 door panels with OEM switches, OEM backup camera and LCD rear view mirror, OEM Overhead console
jposes is offline
Old 06-12-2008, 07:38 PM   #2 (permalink)
jposes's Avatar
Anybody have any idea?
jposes is offline
Old 06-12-2008, 08:50 PM   #3 (permalink)
Do you know if the bladder is good? If not remove it if you can. If your tank can hold a vacuum -bladder in or out then its a moot point from where i stand. Im getting ready to use teh same kind of tank but mine is 200+ gallons. the schrader valve will come in handy. As long as you can hold a vacuum and then figure out your oil in/ oil out scenario you should be ok.
1993 Crewcab 4x4 coverted extendcab,7ft bed , upgraded rebuilt E4OD w/ shift, new shocks, 3.55, Eagle aluminum wheels,1996 bumper, front buckets, ATS turbo w/ 4inch custom exhaust in process,60 gal aux tank for alt-- err extra fuel
1984 300SD single tank mix doing great
1998 Mountaineer FOR SALE
1994 Bronco w/ 1995 Lightning motor..wa hooo
jski55 is offline
Old 06-13-2008, 12:34 AM   #4 (permalink)
jposes's Avatar
How are you planning on pulling the vacuum? Does yours have another place that you can use to hook up the vacuum pump?
jposes is offline
Old 06-13-2008, 04:04 AM   #5 (permalink)
We use a propane tank. Keith
2004 F350, Lariat, True Blue/Arizona Beige, CC, LWB, 6.0 PSD, Torqshift, FX4, Camper package, captains chairs, power & heated TT mirrors, adjustable pedals, AIC, dual alternaters, power sliding rear window. C-Betr mirrors, ARE K series cap, Bedrug, BFG MT 285/75r16,overhead DVD player, DPPI turboback dual exhaust, gauges, Husky mudflaps, Weather tech vent visors, and Lund bug deflector. Date ordered 12/23/2003. Delivered 2/5/04
http://community.webshots.com/album/122797684QJFiJY
MD-TDC Secretary
ktpauley is offline
Old 06-13-2008, 11:33 AM   #6 (permalink)
DHTD's Avatar
Im building one out of an old 60 gallon air compressor tank my buddy had lying around his shop, but I have done research on using the well tanks.
I believe after reading a bit and doing some searching, the way you convert the tank is to puncture it by inserting a sharp object inside the bottom fitting, so the bag deflates and you have more tank space. Theres so much info out there its retarded. Im sure you can find the same article with some searching. Good luck buddy!!
01' 7.3 4X4 DRK MTLC BLU, DP Tuner F5, AEM Intake, 4" Turboback Silverline Exhaust, BTS VB, AEM digital gauges(pyro, boost controller, trans temp), CCV mod, Rebuilt Injectors, Fuel tank Mods, 203T, 6.0 Trans Cooler, 185,000K and original tranny, so far so good.
DHTD is offline
