Swing check valve?, Brass spring loaded check valve? - Diesel Forum - TheDieselStop.com
Old 03-21-2006, 10:17 PM   #1 (permalink)
I'd like to add a check valve onto my conversion to help prevent backflow of diesel to the veggie lines. Basically I have a two filter setup utilizing the existing stock fuel bowl. There is a T before the injectors where the veggie and diesel side meet. I would like to add a check valve right before the T on the veggie side. On McMaster there are a bunch of choices.. I like the spring loaded valves because they're low profile. What are people using here? I'm guessing there shouldn't be a problem with up to 1 PSI for cracking pressure to open valve? Thanks!
Rich
SLO_TAO is offline
Old 03-22-2006, 11:28 AM   #2 (permalink)
airfooter's Avatar
Re: Swing check valve?, Brass spring loaded check valve?
I was curiuos about this also. I wanna run FN74-style WVO set-up and I was suprised to see so many cv choices. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Choose wisely. Or PLEASE post pics of the carnage!!!
2001 F-350, DRW, 4x4, XLT Crew Cab, flat bed, 7.3, 6 spd, Dipricol Optix gauges on pillar - EGT, Boost, Fuel Press., HPO Press. - No Muffler, AIH delete, SB Con OFE, AC code injctrs, GTP 38R. Vegistroke-inspired WVO system w/150,000 trouble-free miles! BTS tunes, 203 t-stat w/billet housing, Evans coolant, coolant filter, boost relief valve, Dieselsite IC boots, Hella headlight harness, '07 grill/lites and big, bad front bumper!
2000 Excursion 4x4 Limited - BTS trans and tunes, AIS, Frybrid/V3 SVO conversion with over 100k VO miles so far!
That's 250k miles on SVO between them!
airfooter is offline
Old 03-23-2006, 01:15 AM   #3 (permalink)
I think I'm going to go with a couple of these from mcmaster.com
8549T24 Brass High-Pressure Spring-Loaded Check Valve 3/8" NPT Female X 3/8" NPT Male, Viton Seat
I'll go with the Viton.. never know when I might use B100 as the start/purge fuel.
SLO_TAO is offline
Old 03-01-2010, 10:24 AM   #4 (permalink)
Originally Posted by milly555 View Post
you may refer to [removed spam link] perhaps you may find suitable check valve.
This thread is 4 years old. He has probably bought something by now. However, I use a few check valves at the shop and my favorite ones are made by Generant.
444-4D is offline
