Thinking about it WVO/WMO - Diesel Forum - TheDieselStop.com
Old 09-16-2007, 10:25 PM   #1 (permalink)
Ok im new to all of this and think about trying to mix and make my fuel .I have read all the stuff about filtering on hear but theres the water that also scares me so after talking with my dad he came up with this idea of using a refrigant recovery tank 90 lb. and pumping in the filtered WVO or WMO and putting a vacume on the the tank for a day or more to remove all the water. It works on freon and the oil in it and the tank has a liquid and gas line so im looking for any and all thoughts on this Thanks
2001 Ford F350 Lariet 154,000 miles, CC, LB, 4X4, AUTO withstall and shift kit, 6 Stage custom Bullydog Chip. Garrett Ball baring turbo, 100 hp injectors, full magnaflow exhaust w/ 5.5 in tip. Aftermarket air intake. Full gages.
http://community.webshots.com/user/m...host=community
68 Bronco half cab,289,3 on tree uncut and restored
71 Bronco moded,302,double stick, mod 3 speed under restoration
76 Bronco almost restored with everything stainless thats possible,302,PS,PB,disk,
MarkSeve is offline
Old 09-17-2007, 01:49 PM   #2 (permalink)
firemediceric's Avatar
Re: Thinking about it WVO/WMO
That will get out the water, but will still leave any salts, sugars or other disolved contaminants in the WVO.
You could mist wash to get out the junk and then de-water by vacuum.
1999 7.3 F-350 and 2004 6.0 Excursion
Truck: Tymar type intake, Zoo Dad, muffler delete, By-pass coolant filter, Dahl 100 fuel filter Harpoon & Hutch mod, upgrade to 3/8" fuel line and HP oil X-over, Oil by-pass, Scan gauge II.
Excursion: All stock, so far.
firemediceric is offline
Old 09-17-2007, 06:53 PM   #3 (permalink)
Send a message via AIM to VD350
let the oil sit for 2 weeks. The water and other 'Stuff" will go to the bottom and the oil will be on top (Looks like this milky mix on bottom). Just make sure to leave some oil on top of the "Stuff" on the bottom to ensure that no water gets in. Now this is NOT full proof of course but it has worked for us for 2 years.
If you want a full proof method compile all the oil into a 55 gallon barrel with the lid cut off. Put a fish tank bubbler into the oil and put a box fan on top of the barrel. Usually dries out within 2 days.
1986 F-250: 6.9L XL 4x4, 4.10 rear, 4 speed, Wellman GPs, 127,000 and chuggin along like new
1985 Mercedes 300SD: Daily Driver, straight piped
www.Fordemblem.com
My Truck and My Yamaha Tri-Z
VD350 is offline
