titrating? - Diesel Forum - TheDieselStop.com
Old 03-24-2005, 11:18 PM   #1 (permalink)
titrating?
i've read alot on here and haven't been able to find out what titrating is. all i have found is that it should be done so i know how much lye to add to the bd. anybody wanna let me in on the secret.
<span style="color: #FF0000">#18</span> not all trucks are created equal
THE COWBOY'S CADILLAC,<span style="color: #FF0000">my pics.</span>, 96 F-350 XLT SC DRW PSD, 4x4 conversion(D60),more oil than you, auto tranny by faubion motorsports, tuned by a backwoods hack(thanks tony), 230cc injectors, D66 turbo, head studs, 910 valvesprings, open element intake, homebuilt fuel system, 3-4"DP, intercooler with homemade spider and piping, 5" chrome stacks with turnouts, front hitch(for my weight bar), member of the <span style="color: #FF0000">WNYPA</span>
on the way: more power
bullridin_fool is offline
Old 03-25-2005, 09:04 AM   #2 (permalink)
My Photos: (6)
Re: titrating?
Making biodiesel is all about a reaction. We have to know exactly how much of one thing is in the waste veggie in order to add the right amount of another thing so it will balance out. In this case, its figuring out how much free fatty acids are in the veggie. We balance this with caustic (lye). Titration is a neat sounding lab word and can sound intimidating. But, as one online article stated, it will take you longer to read the article than to actually do the titration.
Todd T
ToddT is offline
Old 03-25-2005, 02:32 PM   #3 (permalink)
Re: titrating?
Here are three awesome sites for good info.
http://forums.biodieselnow.com/
http://biodiesel.infopop.cc/eve/ubb.x
http://www.veggieavenger.com/avengerboard/
Look for posts by Girl Mark, She provides excellent info.
2001 F350 DRW Lariat 7.3 4 X 4,
1985 Mercedez Benz 300D 5cyl turbo diesel
1978 Mercedes Benz 300D 5cyl NA diesel
1994 Buick Roadmaster LT1 inside
1984 Cutlass Supreme Broham
1985 Barth Motorhome 28' 454 Gasser
1959 Gravely Model LI,1963 Gravely Model L8,
1973 Gravely Commercial 12
wodnek is offline
Old 03-25-2005, 09:14 PM   #4 (permalink)
Re: titrating?
Titration is the chemical determination of the volume of free fatty acids in an oil source.
The process is simple yet requires that all components be present for it to work.
First one takes 4ml of the oil to be tested (waste vegie oil mostly) and 40ml Isopropyl alcohol sitting in a jar which is sitting in a warm water bath. Mix the iso and oil together until disolved.
Then either using an electronic PH meter (what I use) or phenolphthaline solution in the mix slowly add some 1% lye/distilled water solution until you hit 8.5 PH on the meter or until the phenolph turns a redish purple for 10 seconds. The number of drops of 1% lye solution divided by 4 (because you made a 4 fold testing solution) is then added to the stock amount of 3.5gr/liter oil to get the amount of catalyst required to complete the reaction.
If you used 4 drops, you divide by 4 = 1. add 1 to 3,5 and you get 4.5gr lye (sodium hydroxide)/liter of wate oil you want to convert to biodiesel. this amount myust be disolved in a 20-25% volume of methanol(Methyl Hydrate/wood alcohol...).
An 80 liter batch at 4.5gr = 360gr lye in 16 liters methanol competely disolved and then added slowly to oil that has been heated to 55C (130F) and processed for a couple hours, either by a stirring mechanism or circulating pump.
The end result must then be allowed to settle (8hours or more)so that the glycol can drop to the bottom and the biodiesel can stay on top. Decant the biodiesel and wash it with warm water at least three times or until the water coming out is as clear as when it went in. Drain the water out, and set aside to allow any residual water to further settle (a few days to a week is plenty) Siphon off the fuel and run it through a diesle fuel filter. Mine in it's upgrade form will go through a 10 micron water seperating filter and then through a 3 micron hydrolic oil filter for polishing before use.
The end user (you)cost minus any time and labour and depending on the cost of the methanol (the most expensive ingredient) is about .43/liter before methanol recovery which can yet further decrease the cost factor.
And that is it, in a nutsheel. You can get more complete instructrions at the sites mentioned above and also at :
http://journeytoforever.org/biodiesel_make.html where I learned how to. For an idea of how to build a reactor/wash tank combo my unit is also on the processor page:
http://journeytoforever.org/biodiesel_processor12.html This is the unit prior to the upgrade.
Have a nice day.
1983 Mercedes 240D 4 speed
Runnin' on B100
My Biodiesel Reactor/Processor
http://www.b100wh.com
biobenz is offline
Old 03-26-2005, 03:54 PM   #5 (permalink)
Re: titrating?
Luc,
what are you doing on the Ford diesel forum when you drive something different? Most people on this forum (or other forums) dont' recommend journeytoforever for anything.
mark
Homebrew biodiesel crazy:
...several years with a couple of different 6.9's... now running a (gasp!)1998 GMC 6.5 van... don't shoot me.
girlmark is offline
Old 03-27-2005, 12:35 AM   #6 (permalink)
Re: titrating?
I would recomend Journeytoforever website as it contains alot of good info not found on any other website.
I don't fully agree with everything that website has to offer but it still contains alot of valid info. I don't agree with alot info posted on this website, but there's not another website like it that has alot of good info like thedieselstop has.
There's good and bad in any website but since I don't own or maintain the website, I surley don't have room to complain about it as I do have a off button if I don't like what I read.
[img]/ubbthreads/images/graemlins/smokin.gif[/img]
T_Bone
02 F350, 4X6, Crew, DRW, LWB, PSD, 6spd, 3:73, Island Blue, Stock, AEB2, Phoenix Az
Buy UNION work UNION. It pays off in the long run
Define Union:
A labor Union is nothing more than united workers with a common goal for better working conditions.
We all are in some sort of labor Union, some are just larger than others with better working conditions!
T_Bone is offline
Old 03-27-2005, 02:16 PM   #7 (permalink)
Re: titrating?
well, excuuuuusssseeeee me. I had no idea it was proprietary. Once again looking for a fight eh? Haven't we been down this road once already ?
And just because "no one" recommends something other than me, whom you seem to have a problem with, does not in and of itself make the information invalid.
And FYI I do not participate in the JtF forum list any longer, reasons for which are really none of your business, but if you continue to dog me from forum to forum trying to discredit every and anything I have to say that would be tantamount to censureship and I am certain that others here and elsewhere have not anointed you the Queen Censor of anything, so if you don't mind taking another tone and being civil then we shall get along just fine and learn from one another as it is supposed to be.
I am offering ideas, alternatives to the norm and no one is so mentaly incompetent to not be abel to decide for themselves what they will or will not aceept and follow. Kindergarden was over a long time ago.Grow up.
Runnin' on B100
biobenz is offline
Old 03-27-2005, 03:55 PM   #8 (permalink)
Re: titrating?
B100 i appreciate the right up. this is exactly what i was looking for and have not been able to find. thanks
Old 03-28-2005, 07:54 AM   #9 (permalink)
Re: titrating?
You are quite welcomed. The way I figure it that is what it is all about, information sharing, kinda what the net was created for eh? All the thought police and speech censors are having a really hard time with all this open dialogue as are those with "star quality" in their minds who seem to think that they are the only ones with anything valid to offer, but that pettiness will just have to wait until the claws of Big brother get firmly sunk into net traffic as well to be happy. Until then I shall continue to apply my right to freedom of speech as well as my freedom of assembly.
Have a nice day. [img]/ubbthreads/images/graemlins/grin.gif[/img]
Runnin' on B100
biobenz is offline
Old 04-03-2005, 08:52 PM   #10 (permalink)
Re: titrating?
Luc,
mark
Please see Girl Mark's referencing Journey to Forever at Info Pop. Oops... People who live in glass houses...
http://biodiesel.infopop.cc/eve/ubb....51/m/990600361
Down near the bottom. [img]/ubbthreads/images/graemlins/eek.gif[/img]
Runnin' on B100
biobenz is offline
