I have come across oil that titrates @ 21, and I have used it. I learned the acid esterfication process, and now use it for all batches. I use less KOH and Meth, and have greater yields. I don't titrate until the first stage acid process is complete. I can normally get the titration to be < 1 after acid stage.
THe 1ml oil you have is great, since you are new to this process, enjoy the 1ml oil, it will be easy to work with and your results will be easy to test as well.
The 10ml oil ... I would keep in storage and learn how to use the acid process, that way you will never be limited. You will be able to process any oil you find.
To learn more about acid esterfication check out this link
http://biodiesel.infopop.cc/eve/foru...rm/f/629605551
THer is a lot of information there, if you find you need some help PM me, as I will not process oil without using the acid process. The acid cost is @ $0.008 per gallon of oil, but I use 18% meth, not 22% as sugessested by most manuals. There is alos a saving in KOH, as my titrations are < 1.
JayM
