Transfer hose - Diesel Forum - TheDieselStop.com
Old 08-11-2009, 08:31 PM   #1 (permalink)
Transfer hose
I've got a cheap 12v pump from Harbor Freight to move used oil to a 30 gal barrel in the back of my van.
(I got a one year, 'no questions asked' warranty on the pump)
I'd like to keep the pump near the van.
What kind of hose, and how long, would y'all recommend.
I was thinking of getting a $30/ 50ft heavy duty garden hose from Home Depot.
Do y'all think it will hold up without collapsing?
Is 50FT a good length?
Thx in advance.
longwolf is offline
Old 08-11-2009, 08:48 PM   #2 (permalink)
RoGrrr's Avatar
Send a message via AIM to RoGrrr
I use a piece of garden hose with an adaptor to go to a piece of 1 inch PVC. On the PVC, I placed a coupler, which I filed out the web so I can slide it up to the top of the tube. Then I slide an O-Ring (what fits over the tubing) all the way up to the adaptor.
The garden hose then goes to the pump (I use a 6.5 HP engine driven pump from Horrible Fright) and when I light it up, it REALLY SUCKS ! I can pump 100 gallons in about 10 minutes. Then I can GET OUTTA DODGE !
The reason for the adaptor and o-rings is that when you withdraw the pipe from the tank, it’s covered with oil. I then slide the adaptor down to the end of the pick-up tubing. The O-Ring acts as a squeegee, getting most of the oil off so you won’t have to wipe it off to clean it. You’ll still have some to wipe but it isn’t as nasty as wiping your butt.
Have a spare O-Ring or THREE. The reason for having spare O-Rings is that you’re gonna drop one into the holding tank. And don’t ax me how I know this. Fortunately, I had a spare ring. (even tho I REALLY didn’t need it, since I didn’t drop that first one into the tank. Tha’ssss my story and I stickin’ too itt !)
The garden hose is stiff enough that it won’t collapse from your 12 volt pump. I have one of them too so I have that experience. I used it when I couldn’t get my truck in to make the pickup. I wheeled in a small tank and used my battery pump.
I like BIG, LOUD, heavy trucks, light, tiny women, shooting, and BIG glasses of heavy beer (not necessarily in that order, either ).
http://www.youtube.com/watch?v=-TC2xTCb_GU
The little gal I bought my truck from called it her "COWGIRL HARDWARE".
I call it "LURCH" !
96 F250 4WD, 35 INCH TIRES over a inch lift kit, DUAL 5 INCH STACKS (sounds pretty darn good), BLACKed OUT WINDOWS, SNOW PLOW
CENTRAL OHIO
Oh yeah, I LOVE my carbon footprint !
RoGrrr is offline
Old 08-12-2009, 08:35 PM   #3 (permalink)
Thx RoGrrr,
About how long does it take with your 12v pump?
longwolf is offline
Old 08-12-2009, 09:23 PM   #4 (permalink)
my own opinion---garden hoses, no matter what quality, aint going to stand up to wmo or wvo for very long--
94_turbo is offline
Old 08-12-2009, 09:26 PM   #5 (permalink)
So, what would you use?
longwolf is offline
Old 08-13-2009, 01:03 AM   #6 (permalink)
arthurgoboom's Avatar
oil/fuel rated hose is expensive...might be able to replace a cheap garden hose every so often...
1986 F250 2WD Super Cab XLT Lariat w/ 1996 front clip. Dually bed & van rearend (2" wider, allows spring clearance). 6.9 w/ approx 120,000mi. Banks non-wastegated turbo system, Wellman G088 glowplugs, Delphi BB injectors, Kenworth pyrometer, vac/boost gauge, electric water temp/oil psi/voltmeter mounted in dash. 3" Mandrel-bent open exhaust. C6 trans, 3.54 gears. Okiegringo idler pulley. R134a A/C conversion. WMO/diesel blend in one tank.
arthurgoboom is offline
Old 08-13-2009, 04:35 PM   #7 (permalink)
BiodieselPlace's Avatar
Garden hose will probably collapse under even a slight vacuum and heat. It will not hold up to WVO for very long. A good hose to use would be Polyurethane based such a the Superthane hose (braided or not). Has thicker wall so will not collapse under pump's succion and is compatible with WVO and biodiesel. I use it all the time to transfer from a 275 gal tote to my automated processor. See here.
* 96 F250 PSD, CC, SB, 2wd, auto, 3:55s
* 280,000 miles
* Tymar Performance intake
* 10K mod
* FPR shim
* DIY Exhaust Brake
* 3" downpipe
* Rotella Synthetic Engine Oil
* B100 all the way!
BiodieselPlace is offline
Old 08-13-2009, 07:30 PM   #8 (permalink)
RoGrrr's Avatar
Wolfie
I pumped about a gallon per minute with my 12 volt pump thru the garden hose. However, I wasn't in any hurry at that time and it wasn't all that warm when I was using it.
RoGrrr
Originally Posted by longwolf View Post
Thx RoGrrr,
I call it "LURCH" !
CENTRAL OHIO
RoGrrr is offline
Old 08-14-2009, 11:22 PM   #9 (permalink)
I know omega has a listing of hoses and what fluid they handle well...I would also use a wire or plastic spiral, vacuum rated hose for suction.
'00 F250 7.3L, 4x4, 6-spd, SCT X3, ATTA 90 gallon tank/toolbox, Air Lift Loadlifter 5000 kit. WVO kit in the making...now if I could just finish getting the CANbus code written for that HE431VE.
'96 Impreza "WRX" coupe time attack car
Homemade WRX is offline
Old 08-15-2009, 03:02 PM   #10 (permalink)
Thx for the help folks.
I found some heavy duty, 8 ply garden hose in 15ft lengths at Northern Tool.
They where selling them for about $5 each, so I grabbed 3.
It's pretty stiff stuff.
I'm on a very thin shoe string, with luck, they'll do at least for a while.
longwolf is offline
Old 08-15-2009, 05:13 PM   #11 (permalink)
RoGrrr's Avatar
Wolf
I doubt you will have problems with your heavy duty garden hose. I would use that stuff in a heartbeat (well, I already do). And since you bought spares, take an extra one with you and if suction side starts to collapse, use it for the output and put the new one on for suction. However, I bet you will be able to use it for many MANY years b4 you show any hint of trouble.
RoGrrr
I call it "LURCH" !
CENTRAL OHIO
RoGrrr is offline
