Transmission cooler in radiator - Diesel Forum - TheDieselStop.com
Old 07-04-2004, 08:18 PM   #1 (permalink)
I am converting from auto to manual and was wondering about the tranie cooler,in the radiator to heat fuel/wvo before filter after pickup pump. I was thinking it would get about 160 deg and help to keep radiator cooler. Has anyone done this; and with the extra capacity will the lift pump keep up? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
85 f-250 ext cab 4X4 with a 93 cab Line-x underneith,2" body lift,6.9 bored 20 over,1999 P.S.wastgated turbo,Banks power elbo,2002 P.S.intercooler,K&N filter,ARP head studs,hypermax pistons,Hypermax piston pins,crane reground cam,Moroso 3qt oil accumalator,210 Deg fan clutch,Powershot 2000 propain, ZF-5 speed with luk clutch spicer 3 speed Aux 2.14 low 1-1 direct .74 overdrive, 2003 axles 3.73 ratio limited slip,PS steering box and arm,1 ton front springs,Firestone air bags front/rear, 3" strait pipe,A piller guages,carter electric fuel pump
woodie is offline
Old 07-07-2004, 02:33 PM   #2 (permalink)
Re: Transmission cooler in radiator
Good question. I think my t-stat is a 205F if I remember right. Plenty of heat. Give it a try, take or install temp of vegy or test oil after trans cooler and post back.
1995 F-250 PSD, Auto, 2 wheel, Ext Cab, stock
Oklahoma is offline
