Trash Pumps - Diesel Forum - TheDieselStop.com
Old 11-17-2005, 05:28 PM   #1 (permalink)
Trash Pumps
I have made my second pickup with my trash pump now.
The first one I put the sucker all the way to the bottom and got 20 gal H2O and 10 gal of oil in an emulsion (From the pump?), What a mess!! 30 gal of foul smelling glop.
My second pickup I was more careful before I took the oil, got about 15-20 gal of oil.....no water, but when I started to drain the oil at home to put in my settling barrel it came out looking like the glop, but not nearly as soupy. Is this just aerated oil from the pump impeller?
You other guys that collect this way, does this happen to your oil too?
[img]/ubbthreads/images/graemlins/confused.gif[/img]
Will it settle back out fairly quickly?
Y2K F250SD 7.3PSD AUTO 4X4 CC Lariat 8'Bed 4"Rise Fiberglass Cap, Hypertech Programmer, K&N Drop in Filter. Otherwise Stock.
Pray for our troops.
seetrout is offline
Old 11-17-2005, 08:22 PM   #2 (permalink)
Re: Trash Pumps
I havent had this happen to me. Sounds like your still pulling water from the bottom. There's a chance your pump is pulling too much and making too much suction and pulling the water off of the bottom along with the oil. When i get oil, i just let my pump idle and keep the hose closer to the top so that doesnt happen.
1995 F250 Xcab 5spd 4x4. TYMAR, 5" Mitre Cut STACKS, Skyjacker lift, 35" Mud terrains, powered by Home made Bio Diesel, Cobalt C2 gauges, DIY INJECTORS by www.DIY-Injectors.com , 6 position chip by Fat Kid Performance Diesel(sn: house22), intercooler on the way within the next few weeks...
Nitro454 is offline
Old 11-17-2005, 08:52 PM   #3 (permalink)
Re: Trash Pumps
I have a 2 stroke water pump, I just started using it about 2 weeks ago. The first time I used it in a known source it was about 45 degrees the oil didn't look like it would be something that I'd want to take, when I pumped it into my collection barrel; it looked like a white emulsion; when I heated it up in my settling tank it turned nice and dark.
I say try heating it up then go from there.
2005 Excursion Limited; build date 09/04. MBRP T-304 Turbo Back Exhaust. Sickening monthly payment.
rcdallas is offline
Old 11-17-2005, 08:54 PM   #4 (permalink)
h2odrx's Avatar
Re: Trash Pumps
i have found that you need to keep the suction close to the top, and follow the oil down. i messed up once and started at or to near the bottom. on the second can i set up near the top and it came out good. i poured the first can back in and keep on going it all worked out good. the bottoms of each can did have some glop in it after it set for a few weeks. oil was still good on top.
h2odrx is offline
Old 11-17-2005, 09:01 PM   #5 (permalink)
Re: Trash Pumps
There wasn't any water in the barrel I pumped out of today. Different place. There was a lot of thick sludge in the bottom, but no water. I did keep my hose near the top of the oil and followed the level down. The gallon I drained out of the bottom of my collection drum looks like it is starting to turn back into oil, but the light is going up like air not down like water. I hope. My pump is 6.5 hp, but it's cold and the oil is thick. I'm afraid the pump will stall at low rpm, but I could try running it at 1/2 throttle instead of wide open. When it starts to pump you can hear the engine speed drop till the governor opens it back up. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Thanks for your experiences guys [img]/ubbthreads/images/graemlins/grin.gif[/img]
seetrout is offline
Old 11-18-2005, 01:14 AM   #6 (permalink)
Re: Trash Pumps
weird. Mine is a 5.5 hp TP. I just start it and let her purr along at idle once the suction starts. It is nice and quiet and pumps rather quickly. Who would of ever thought there was an art to pumping off oil??
Nitro454 is offline
Old 11-18-2005, 11:08 AM   #7 (permalink)
My Photos: (13)
Re: Trash Pumps
I usually see cloudy oil going into my tanks, only to have it clear as the air mixed in by the pump bubbles out.
Keep the hoses high.
Y2k PSD; 60k miles SVO; Dieselsite 203 thermostat Greasel Nomad 140; Line-X; Frantz bypass oil filter; AFE intake; $10 AIC; Cup holder upgrade.
blitzlaw is offline
Old 11-18-2005, 08:16 PM   #8 (permalink)
Re: Trash Pumps
That's what I'm seeing now too, but it's taking some heat to do it. It's cold enough now that the oil is a bit like honey. It's warmer in the garage, but the air bubbles coming to the top are making a foamy head.
I'll try a lower setting on the throttle and see if that helps.
seetrout is offline
Old 11-23-2005, 07:25 AM   #9 (permalink)
Re: Trash Pumps
I use the same pump and I have my own tanks. I just pump it to the bottom and no matter whats in it it will settle out. When it rain it has water in it and its clears .
Abbey is offline
Old 11-23-2005, 10:23 AM   #10 (permalink)
Re: Trash Pumps
... Is this just aerated oil from the pump impeller? ...
You could use THIS pump - NO impeller and the least agitation! [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
MySpace.com/FishHarder
Don't be afraid of death - be afraid of a half lived life!
TurboHans is offline
Old 11-23-2005, 09:58 PM   #11 (permalink)
Re: Trash Pumps
$500 + for a pump?????? I use a donated hot water heater. (FREE) Hook up an air compressor (intake side) pull down to a -21 vacumme, and it fills itself. No noise. No mess. No cost other than a couple of connectors, 2 valves and some plastic pipe. When I get home I hook the compressor back up, push air in and the oil out.
Did I say "$500 for a pump?????" [img]/ubbthreads/images/graemlins/vomit.gif[/img]
08 F350 King Ranch LB, SRW, Black&Gold/373 gears, 20" tires, everything but a backup camera. Adding Firestone air bags & Tork Lift tie downs. Still Stock & liking it.
01 F350 4x4 off road pkg, auto w/373 gears, Lariet SRW Midnite blue. Dueler AT tires, 4 inch HOG SS exhaust with 5 1/2 " tip. Rancho 9000 shocks, Firestone Air Bags, HOG guages, Lance 1130 camper and 19' Lowe Roughneck
dssamp is offline
Old 11-23-2005, 10:16 PM   #12 (permalink)
h2odrx's Avatar
Re: Trash Pumps
yes i agree it's all about saving time and we know time is money!!!
how do you hook the air compressor to get a vaccum?
h2odrx is offline
