The truck is running very well on it. I changed my fuel filter 2 days after fueling up with it, and noticed the old filter and the fuel in the bowl were dark brown. My chassis has 188K on it but my engine only has 68K. Is this the B20 cleaning everything up?
Tim
2001 F-250 Crew Cab, short bed, 4x4, 4R100 with VB tuned by Travis's Automatic Trans, Lariat, Snugtop shell, Line-X bedliner, 265/75/R16 GY Silent Armor. DIY open element air filter. DIY 4 inch exhaust, from stock DP back to 45 degree turn down. Quadzilla Recon XZT moniter- EGT, Trans temp, Boost. DP tuner Stock, 40T, 40T high altitude, 80E, Curt MFG Q5 20K slider hitch, P3 brake controller, ATS housing. Blue Bullet
Sold-- Bright RED 1996 F350 XLT, 4X4, CC, 4.10 gears ,E40D, SRW, Rebuilt E40D at 190K with a 3yr/36K mile warrenty, by Travis's Auto Tranny 719-574-8104. Big Red
Proud Member of the NRA, helping to protect our American Rights!
It will. It'll take longer than if you were using B-100. You're new filter should be good for quite awhile. Carry a spare just in case.
I've been using b-15 since new about every other tank. I've had both fuel filter sets (2 on the 6.0) go to 15k & both looked like they could go longer. I've not seen any water in my bio-d fuels, the 3 -4 times I've drained.
Previous owners did not have air filters installed correctly and engine got dusted. Found out later that they even replaced one head in it before me getting the engine. And that on one bank of cylinders the valves and rings were bad.
Tim
TCH777...are you making your own or buying? I'm down in East of Fountain (Little Ranches) and make my own. Running about75% right now. My 2001 sounds like the new 6.0 now...kinda miss the clacking...
David
08 F350 King Ranch LB, SRW, Black&Gold/373 gears, 20" tires, everything but a backup camera. Adding Firestone air bags & Tork Lift tie downs. Still Stock & liking it.
01 F350 4x4 off road pkg, auto w/373 gears, Lariet SRW Midnite blue. Dueler AT tires, 4 inch HOG SS exhaust with 5 1/2 " tip. Rancho 9000 shocks, Firestone Air Bags, HOG guages, Lance 1130 camper and 19' Lowe Roughneck
I dont know about the 99+ but the 94-97 have a fuel filter light. Its actually a vacumm sensor that senses the restriction between the filter and the 2nd stage of the fuel pump.
